AirRayInc
Joined: 12/30/2001 From: San Pedro, CA, USA Status: offline
[QUOTE]I suppose my two main issues at this point are obtaining the updated wing and ailerons (my kit is a 1993 production), and obtaining the air cylinders shown in the instruction book for the inner gear doors. [/QUOTE] Juvatwad, you dont really need to get anything new. But here is in a nut shell what you WILL need to do, to keep your wing together. If you dont know anything about the plane or how it was built, I would route out a 1/4 inch slot 1/3rd of the span of the wing and drop in a spar of ply or other composite make up. Early wings did not have a very strong spar relative to the engines that were being used over the planes presentation, now pilots run as big an engine as they can shoe horn inside. I have built one with a 4.2 for a customer, lots of g62s, super tigers, lots of Mokis 1.8 and 210s and I am going to be doing a 4.2 for myself in about August. When the plane was first introduced, the masses were not running these kinds of powerplants. If you have the Yellow alierons use them, the fluttering issue as mentioned above is a result of the newer ailerons having the lead in the leading edge for mass balancing. But if you dont push the pivot point aft on the ailerons, use a very strong metal gear servo, solidly mount the servo into the bay and not on the hatch cover, and run at the least 4/40 wire from the servo horn to the control horn, you will lose the plane, trust me. The Jug coming out a big loop or split S gets a major case of the boogity boogity boogity...(or go fast) with all the mass and weight there is on the ailerons, things have to be solid and strong. Or you could throw away the glass ailerons and build them up light out of balsa and ply. Personally I use the Yellow parts, they look good and its a waste in my book to throw them out. Thanks Shaun for the props
_____________________________
My Blog http://www.rcgroups.com/forums/member.php?u=9311 http://airrayinc.com
