RE: Nasty 1/10 scale on-road cars using .21 or larger engines....come inside    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> RE: Nasty 1/10 scale on-road cars using .21 or larger engines....come inside Page: <<   < prev  87 88 89 90 91 [92] 93 94 95 96   next >   >>
Login
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 5/13/2012 1:00 PM
GT100
Score: 100
Last Login: 6/18/2013
Status: offline
I came across these really old pics in the forum from one of my proudest project. Actually still own the car but have been thru a couple of motor and gearing changes since. Same car that ran in Cali. Custom cut supernitro body to fit the Racer2
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Bartolone Racing
Born in Anaheim, Built in Dade.
Hide Signatures
(in reply to fdjizm)
       Post #: 2276
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 5/16/2012 10:14 PM
rx7devil210
Score: 105
Last Login: 5/14/2013
Status: offline
Alright i just called my local hobby shop to see if a .21 engine will fit in my rs4 3 evo + they said no its too big and will have some issues was wondering how to a put a beast of an engine like this in my car? Has anyone fit a .21 or larger engine in there rs4 3 and what would i have to do to make it fit. Im trying to get the most power and get faster any help will help thanks.
Hide Signatures
(in reply to GT100)
       Post #: 2277
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 5/16/2012 10:56 PM
Car-Tune
Score: 110
Status: offline
Yes. A .21 will fit. You will need new motor mounts flywheel clutch starter box header and pipe.
Hide Signatures
(in reply to rx7devil210)
       Post #: 2278
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 5/16/2012 11:08 PM
fdjizm
Score: 110
Last Login: 6/14/2013
Status: offline
rx7, check back one page... lol
HPI Super nitro RS4 RB .28-HPI RS4 Nova flash 21
HPI RS4-3 RB Xenon-R .21-HPI Racer 2 OS .18-HPI R40 OS .18
Hide Signatures
       Post #: 2279
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 5/17/2012 2:49 AM
Road Warrior
Score: 100
Last Login: 4/3/2013
Status: offline
I ran the 2 speed one racer today and can honestly say that car is scary fast. Went on the safe side with the gearing just to get a feel for the way it is going to handle. I am out of receivers for my good controler so I used a rtr one for now and I can see that its not going to work without having the fine tuning adjustments. The sensitivity is too much for speeds this fast. That ofna 2 speed works awesome on the racer so if you have one i would give it a try. I used the stock 18t pulleys with a 19/22 38/41 gears and ran the 1/8th rear tires since i'm going for top speed. This car has a front one way so I didnt have to worry about the size diference in tires. It is a rocket in first and the 2nd shift makes it hop a couple times but nothing that noticable. If you couldnt hear it you wouldnt know at all. It pulls in 2nd just as fast as first but I didn't wind it out all the way yet. There was too many kids in the area for a near 100 pass. Need to get a new radar because the one I got dont work unless you can fly by next to it but I feel pretty confident that if the 3.3 in there will get very close to that 100 mark
-SS MODS-
The road to greatness is paved one mod at a time!
Hide Signatures
       Post #: 2280
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 5/17/2012 12:33 PM
fdjizm
Score: 110
Status: offline
Get a garmin forerunner GPS on ebay (60-80 bucks)
I would trust them over a radar gun which can change depending on the angle it reads the car on.
gps is gps and pretty accurate in comparison with no human side to worry about.
Hide Signatures
(in reply to Road Warrior)
       Post #: 2281
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 5/17/2012 1:57 PM
Road Warrior
Score: 100
Status: offline
Thanks fdjizm I wondered what make that was. With those it will tell you your max at any point too. I will go there and buy one now. I highly recommend the ofna 2 speed. My motor moved on the 2nd tank and took the teeth off of first again so I need to figure out a way to make it stay put. I had that same problem with the firestorm when it was on there. Not sure but it think it is because of the way it turns and they mesh together. It works fine on the cd3s but when you put it in anything that the motor is on the other side of the spur it tears the teeth off every time just when you get comfortable and hammer down the motor just revs out.
I have more spur gears but will probably run that same motor in the other car with a 25/34 on stock pulleys and then change them to the 20t and see if they make that big of a change.
-SS MODS-
Hide Signatures
       Post #: 2282
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 5/17/2012 7:34 PM
fdjizm
Score: 110
Status: offline
go for it...
http://www.ebay.com/itm/Garmin-Forerunner-201-Black-Sports-GPS-Receiver-/180882739889?pt=GPS_Devices&hash=item2a1d7392b1
Hide Signatures
       Post #: 2283
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 5/17/2012 7:58 PM
Road Warrior
Score: 100
Status: offline
That's the one I am already watching in my ebay. Probably going to be a bidding war at the end but it is good as sold
-SS MODS-
Hide Signatures
       Post #: 2284
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 5/18/2012 1:51 AM
fdjizm
Score: 110
Status: offline
Hope you get it man, dropped a losi 454 (.28) to mess around with see what happens lol
Hide Signatures
       Post #: 2285
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 5/18/2012 2:26 AM
Road Warrior
Score: 100
Status: offline
How does a 427 do in one of these bad boys? And one more question what all do you have done to your motors?
-SS MODS-
Hide Signatures
       Post #: 2286
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 5/18/2012 2:29 AM
Road Warrior
Score: 100
Status: offline
Oh I also like your custom pipe on that one. I bet it is a bit louder now than it was stock
-SS MODS-
Hide Signatures
       Post #: 2287
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 5/18/2012 2:36 AM
rx7devil210
Score: 105
Status: offline
Alright i just decided to put a .21 in my rs4 3 evo. I was wondering if my chassis is even good enough for an engine that beast? Maybe i should sell and get a diff chassis? I should of bought a kit to begin with?
Hide Signatures
       Post #: 2288
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 5/18/2012 2:53 AM
Road Warrior
Score: 100
Status: offline
Your chassis should be fine they can withstand quite a bit of power and abuse before you get to where the chassis is a problem.
-SS MODS-
Hide Signatures
       Post #: 2289
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 5/18/2012 4:26 AM
Car-Tune
Score: 110
Status: offline
You can stack 2 chassis on top of the other.
Hide Signatures
       Post #: 2290
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 5/18/2012 4:30 AM
fdjizm
Score: 110
Status: offline
The stock rs4 chassis is 7075 aluminum, no issues at all with a big block.
And surprisingly the center axles hold up well, the rear axles are a problem so you're going to need spares, I've twisted off 3 of them so far. I did try a .32 though and really no need for that much torque and the car was a bit slower up top, .21 to .28 is all you will ever need. (modified of course)
Hide Signatures
(in reply to Car-Tune)
       Post #: 2291
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 6/8/2012 10:46 AM
bigbarraza
Score: 100
Last Login: 7/3/2012
Status: offline
Anyone running a Cen Racing ctr 5.0 v2? .30 engine claims 90+ mph outta the box...
Hide Signatures
(in reply to GT100)
       Post #: 2292
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 6/8/2012 1:28 PM
fdjizm
Score: 110
Status: offline
The cen doesn't run 90 out of the box, pretty much nothing runs 90 out of the box, it's all marketing.
Hide Signatures
(in reply to bigbarraza)
       Post #: 2293
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 6/10/2012 5:08 AM
Mufasa_719
Score: 105
Last Login: 6/13/2013
Status: offline
quote:
ORIGINAL: fdjizm
Well the X01 will. But anywho....
Hide Signatures
       Post #: 2294
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 6/10/2012 5:56 AM
bigbarraza
Score: 100
Status: offline
whats a cheap gps or whatever to find out the speed? Then i could find out for sure how fast the Cen ctr 5.0 v2 is when gets here in about a week...
Hide Signatures
       Post #: 2295
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 6/10/2012 1:26 PM
fdjizm
Score: 110
Status: offline
quote:
ORIGINAL: Mufasa_719
quote:
ORIGINAL: fdjizm
We're in the Nitro section of the forum...
quote:
ORIGINAL: bigbarraza
Look on ebay for garmin forerunners... I use 201's
It's the perfect size
Hide Signatures
       Post #: 2296
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 6/10/2012 7:51 PM
Road Warrior
Score: 100
Status: offline
I got that one from eBay and it is being shipped back tomorrow. The thing does not take a charge and it turned on long enough to find out it was dead. I had to open a case because the guy wouldn't take it back since it was on in th picture. Looking closer at the picture you can see that it was about to die on him too. I hate people like that. The cars have just sat since stripping the spur but I am going to mess around with one today.
-SS MODS-
Hide Signatures
       Post #: 2297
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 6/11/2012 3:54 PM
bigbarraza
Score: 100
Status: offline
Alright thanks i've read hours of pages on this "nasty 1/10" and i missed the gps part higher up on this page lol, thanks tho
I'm looking at foams and whats 35 or 40 shore? hard/soft? im new to foam....
whats a good width? 26mm, 30mm, 40mm, 44mm      rcmarket.com.hk has alot
Cen ctr 5.0 v2 w/.30 engine on way, currently bidding on garmin gps...
Hide Signatures
       Post #: 2298
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 6/11/2012 7:12 PM
Road Warrior
Score: 100
Status: offline
The lower the number the softer the tire will be. It is the color scale that throws me off yet. Tire width all depends on what you want to do with the car. I would go with a narrower tire if you are trying for top speed. It is all a learning curve to figure out what works best for your application.
-SS MODS-
Hide Signatures
       Post #: 2299
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 6/15/2012 4:18 PM
bigbarraza
Score: 100
Status: offline
Hide Signatures
       Post #: 2300
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.328RCU1
