RE: Nasty 1/10 scale on-road cars using .21 or larger engines....come inside    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> RE: Nasty 1/10 scale on-road cars using .21 or larger engines....come inside
Page: <<   < prev  85 86 [87] 88 89 90 91 92 93 94   next >   >>
Login
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 2/24/2012 8:11 PM
nitrohead5300
Score: 100
Last Login: 5/22/2013
Status: offline
that should be very interesting and fast!
Hide Signatures
(in reply to ziggy12345)
       Post #: 2151
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 2/26/2012 8:15 PM
ziggy12345
Score: 100
Last Login: 5/20/2013
Status: offline
The story so far.....
More later...
Hide Signatures
(in reply to nitrohead5300)
       Post #: 2152
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 2/27/2012 12:29 AM
nitrohead5300
Score: 100
Status: offline
It looks wicked to me You going to use some custom tires I suspect ?
Hide Signatures
       Post #: 2153
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 2/27/2012 11:43 AM
ziggy12345
Score: 100
Status: offline
The 1/8 circuit tyres are good for 189mph. Thats what they did unofficially on the rocket car
Cheers
Hide Signatures
       Post #: 2154
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 2/27/2012 4:11 PM
nitrohead5300
Score: 100
Status: offline
Ziggy do you make your own gears or do you have someone make the for you??
Hide Signatures
       Post #: 2155
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 2/27/2012 6:07 PM
ziggy12345
Score: 100
Status: offline
http://www.hpcgears.com/
I get everything from here. Belts, Pulleys, Gears, Motor couplings, gearboxes, etc...
Hide Signatures
       Post #: 2156
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 2/27/2012 10:53 PM
nitrohead5300
Score: 100
Status: offline
Thanks Ziggy
Hide Signatures
       Post #: 2157
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 2/29/2012 3:24 AM
JohnP2
Score: 268
Last Login: 5/23/2013
Status: offline
THAT is freaking awesome! I only hope one day to become as skilled as this to where I can design/implement my own ride like this. Great job! Please send more pics and hopefully a vid of it running.
_____________________________
Mugen MBX6R, HB D8T, Losi 8 2.0, Savage X 4.6, Losi 810, Hyper 7, Exceed Forza
http://www.youtube.com/user/NitroRCNerds
Hide Signatures
       Post #: 2158
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 3/1/2012 8:46 PM
ziggy12345
Score: 100
Status: offline
I managed to figure out the mechanism for dynamically tuning the pipe. Here is a short video.
http://www.youtube.com/watch?v=-k1ZTzaxYUo&feature=youtu.be
It goes from 275mm to 330mm. 290 is supposed to give me 26000 rpm so a little "extra" just in case..
Hide Signatures
(in reply to JohnP2)
       Post #: 2159
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 3/3/2012 4:09 PM
fdjizm
Score: 110
Status: offline
That's a serious machine ziggy, that pipe system is amazing!!
I am working on a new single speed RS4 where I don't have to use a monster clutchbell and baby spur gears.
I really want to put that HPI .36 in it because of the torque to pull this drive ratio, but I heard mixed reviews about that engine.
< Message edited by fdjizm -- 4/4/2012 8:09 PM >
HPI Super nitro RS4 RB .28-HPI RS4 Nova flash 21
HPI RS4-3 RB Xenon-R .21-HPI Racer 2 OS .18-HPI R40 OS .18
Hide Signatures
       Post #: 2160
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 3/4/2012 1:15 PM
ziggy12345
Score: 100
Status: offline
You will have trouble with the clutch if you just increase the gearing. Try machining new clutch shoes from brass and use the strongest springs you can find. This might help.
Cheers
Hide Signatures
(in reply to fdjizm)
       Post #: 2161
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 3/4/2012 8:50 PM
fdjizm
Score: 110
Status: offline
Yea I end up with damaged/melted aluminum shoes alot, I was thinking there has to be something else out there.
But I guess I can break out the dremel and try to make my own out of brass.
You're running brass shoes?
I wonder if these will do better, they have kevlar pads on them, hmm...
http://www.dragraceconcepts.com/1-8th-SCALE-KOMPOSITE-SHOES-AND-SPRINGS-2015ABK.htm
quote:
The Buku Komposite material is almost pure Aramid (Kevlar) fiber and is extremely wear resistant outlasting even the hardest aluminum shoes by 300% OR MORE! In addition the Komposite causes virtually NO WEAR to the clutch bell!
The Komposite material does not burr or deform in any way preventing virtually all clutch failures related to these causes.
The extremely low wear rate and uniform friction characteristics of the Komposite coupled with no wear to the clutch bell create the most consistent and reliably performing R/C clutch in the world!
Hide Signatures
       Post #: 2162
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 3/5/2012 1:04 AM
Car-Tune
Score: 110
Status: offline
These are actually really good
http://bukupower.com/
Hide Signatures
       Post #: 2163
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 3/6/2012 9:04 AM
ziggy12345
Score: 100
Status: offline
Now they look interesting! They just need to be a bit heavier for speed runs
Hide Signatures
(in reply to Car-Tune)
       Post #: 2164
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 3/7/2012 10:30 PM
roadrunner ss
Score: 100
Status: online
so what you planning on putting in your hpi racer 2 what kind of motor
IM JUST GETTING STARTED ON UR CANDY AZZ
Hide Signatures
       Post #: 2165
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 3/8/2012 4:19 AM
fdjizm
Score: 110
Status: offline
If that was to me, it's a super rs4 (little bigger) but I have a few engines to use.
RB WS7III, RB TM928, RB Speedline Xenon-R (holy jesus rpms from hell), Gotech 7-port (nova kangaroo clone), hyper mac 28 (ehh), axial 32rr (ehh)
just picked up a sportwerks .26 engine. (brand new from an ebayuser $86)
They can be had cheap and if modified nicely and a carb change they rev to around 45k.
They are the same engine as the losi mach 427 with a better carb.
Really a beast of an rtr engine, I can say it hangs with the WS7 easily after being modified.
Hide Signatures
(in reply to roadrunner ss)
       Post #: 2166
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 3/8/2012 5:49 PM
roadrunner ss
Score: 100
Status: online
i have a  hpi racer 2 that crazy its a one speed with a rb classico 11 pulling around 60,000 rpm i have a 36 spur gear and a 30 pinion gear so im ready for what ever
Hide Signatures
(in reply to NBCTANK)
       Post #: 2167
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 3/8/2012 6:24 PM
fdjizm
Score: 110
Status: offline
RB classico 60,000 rpm?? lol.
So you're getting right around 250mph out of it huh?
Hide Signatures
       Post #: 2168
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 3/8/2012 7:00 PM
MiamizFinest
Score: 140
Status: online
60k??? Outta a nitro!?!! Never in a million years
-= 100 Is Only The Beginning =-
-= Made In Dade =-
Hide Signatures
       Post #: 2169
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 3/8/2012 9:35 PM
ziggy12345
Score: 100
Status: offline
41,000 rpm out of a .21 engine highly modified is the very max. You can get 39,000 put of a street engine if your lucky
Cheers
Hide Signatures
(in reply to MiamizFinest)
       Post #: 2170
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 3/8/2012 10:50 PM
fdjizm
Score: 110
Status: offline
quote:
ORIGINAL: ziggy12345
Cheers
Not sure how accurate but XRC got 43k out of a losi mach 427...
Team Losi Mach 427
HP: 1.31 @ 26,750 rpm
TQ: 53.80 oz-in @18,750 rpm
Max RPM: 43,250 rpm
And that's a .26 engine.
Here is a dyno sheet from an RB xenon-r by ab mods...
You can see it spun to around 44k there as well.
Hide Signatures
       Post #: 2171
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 3/9/2012 2:41 AM
roadrunner ss
Score: 100
Status: online
I GOT MY MOTOR FROM THE BEST  RB MODS OKAY I TALK TO HIM HE TOLD THAT HE MOD MY ENGINE SO IT CAN GET AROUND 55,000 to 60,000 RPMS
< Message edited by roadrunner ss -- 3/9/2012 5:08 AM >
Hide Signatures
       Post #: 2172
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 3/9/2012 6:12 AM
MiamizFinest
Score: 140
Status: online
quote:
ORIGINAL: roadrunner ss
I gotta agreed with RB being the best, hands down he really is IMO while i ran nitro that's all i used, but if he really tolled you that.............he's getting to old to be doing, what he's doing....... NEVER will there EVER be a nitro motor hitting 55-60K EVER the internals will simply not hold up.
BTW who ever posted the specs of the MACH 427 motor I WILL VOUCH FOR IT, it is ONE NASTY ASS MOTOR, the silver head version spun faster which i asume the silver head was the specs you posted. I had one in mugen MRX4-R i used for messing around on the street since i didn't race it. All i can say is it was RETARDED fast. To bad not many people gave the motor a chance and used it for high speed projects it has potential. All the RPM of a high end 21 with 26 size displacement, and about 100 bucks for one new in the ebay chop shops!!!! I think i still have one laying around infact tho i know i will never use it again.
-= Made In Dade =-
Hide Signatures
       Post #: 2173
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 3/9/2012 12:03 PM
fdjizm
Score: 110
Status: offline
^I'll buy it off ya! lol
Hide Signatures
       Post #: 2174
RE: Nasty 1/10 scale on-road cars using .21 or larger e... - 3/9/2012 4:42 PM
roadrunner ss
Score: 100
Status: online
well he mod the engine only thing i can do is go by what he say any way were is everybody racing at
Hide Signatures
       Post #: 2175
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.422RCU1
