WIng Filletts
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> WIng Filletts Page: [1]
Login
WIng Filletts - 6/3/2003 4:39:46 PM
propnut28
Status: offline
I have a small plane I'm building and want filletts around the wing saddle. How can I make them lite and evenly shaped on both sides.
       Post #: 1
WIng Filletts - 6/3/2003 5:11:55 PM
ED STEFAN
Status: offline
Is this wing glued to the fuse, or is it removable?
_____________________________
ED -- AMA 20464 -- A plane is 1000+ different parts all flying in very close formation.
(in reply to propnut28)
       Post #: 2
WIng Filletts - 6/3/2003 10:16:19 PM
propnut28
Status: offline
The wing is simi-perminant. It bolts on and will be removed for maintanance or repairs. I thought of using a spoon to put on some lite filler than sanding it. Whatever I use it will have to be the same or nearly the same hardness as the surrounding balsa.
       Post #: 3
WIng Filletts - 6/3/2003 10:47:33 PM
MinnFlyer
Status: offline
You can make a base from 1/64 ply and glue it to the fuse with triangle stock. Then, use your spoon method to smooth some lite filler over it.
Click to see fullsize image.
Click for fullsize
Mike B.
AMA# 42400 www.gettingairborne.com
"Those are my principles. If you don't like them, I have others." - Groucho Marx
       Post #: 4
WIng Filletts - 6/3/2003 10:56:41 PM
ED STEFAN
Status: offline
I've had good luck gluing 1/64th ply to the fuse saddle with the wing attached. Be sure to use wax paper, or plastic wrap between the wing and saddle area so as not to permanently glue the wing to the fuse. Let the ply stick out from the fuse aprox 1/8 inch. This will make a 90 degree support for the filler. The filler can be epoxy mixed with micro-balloons, model-magic, or several other combinations that you can search for on RCU. I prefer the epoxy and micro-balloons due to the ease of shaping and sanding. To shape, I dip a finger into a bottle of iso. alcohol and run the fillet into shape. Requires very little sanding after it sets up. Hope this helps.
       Post #: 5
WIng Filletts - 6/5/2003 9:06:22 AM
PilotFighter
Status: offline
I like the 1/64 ply and filler method myself. In the past, however, the filler has drawn up, (shrunk) pulling the fillet up. It generally isn't a problem at the front of the fillet where it is small. But near the trailing edge of the wing, where the fillet is its broadest, it pays to keep the 1/64 ply taped to the wing until the filler is completely dry. If that make any sense.
turn left, your other left
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.391RCU1
