David Gladwin
Score: 100 Joined: 2/5/2002 Last Login: 3/20/2010 From: Sydney, AUSTRALIA Status: online
Hi Guillermo, I tried to keep the anaology to fullsize jets quite basic although I have made hundreds if not thousands of coupled approaches on real jets, many terminating in Cat 111 autolands, it can get complicated. Models don't have any ils/vor, or irs track guidance, just you on the sticks controlling heading by adjusting bank angle and maybe some gyro stabilisation ! Even fullsize jets on Autoland may NOT have the nose pointing into wind when the autopilots begin the runway alignment mode !! As I said it gets involved ! Here is the text of the article I wrote for RCJI but you'll need to get the mag for the pictures etc. Hope it helps, Regards, David. Gyros., Smoothing it out and keeping it stable ! One of the hot topics of conversation at the Jet World Masters in Northern Ireland was the use of gyros for stabilization. The use of such devices is allowed by the IJMC rules and most of the top fliers were using them either as yaw dampers, or stabilizers, or to hold attitude, particularly bank angle, when no control input was being made. Whilst opinion varied as to whether these devices should be allowed in a flying competition what was agreed is that modern gyros can vastly improve the smoothness, precision and accuracy of flying as proven in the superb performances displayed by many competitors at the event. Clearly, modern gyros have been developed to an exceptional degree of accuracy and reliability and, whether or not they will continue to be allowed in competition, they can greatly enhance the flying of all model aircraft, jets or otherwise. The aim of this article is, therefore, to describe modern gyros and their application but perhaps to give a better understanding some gyro theory (and a little history) will be useful. The first working gyros were made almost 200 years ago but it was an American, Elmer Sperry, who made the first practical application of gyros in navigational instruments in the early 1900s, firstly for marine use in the gyro compass, and later for aircraft, both in flight instrumentation and in autopilots. The Sperry Gyro Company continues to this day and many modern, and not so modern, aircraft incorporate Sperry equipment. Original gyros were mechanical devices utilizing a spinning mass or flywheel to provide the stabilization. Such a rotating mass exhibits two important properties, that of rigidity and that of precession which is a form of conservation of angular momentum. It’s rigidity means that the rotating mass will stay in a fixed position unless acted upon by an external force and if such a force is applied the mass will tend to move in a direction at 90 degrees, in the direction of rotation from the point of application of the force. There are two basic forms of gyroscope dictated by the form of gimbal mounting. There is the free gyroscope, used in instruments such as aircraft artificial horizons, or attitude indicators, which have virtually total freedom of movement dependant on gimbal design, and the rate gyroscope which was, and is, used to measure rate of turn in aircraft, this latter known simply as the turn indicator and it is this latter form of gyro which has the most widespread commercial application and is the type used for model aircraft stabilization. The adjacent diagram explains how a rate gyro works. The flywheel is mounted in a gimbal which is restrained by a system of springs. When the gyro case is turned by aircraft movement a force is applied as shown. This force , due to precession will tend to rotate the gyro axis and that twisting force, restrained by the spring system will rotate the gimbal at 90 degrees to the direction of rotation. The greater the rate of turn the greater the precessional force and the greater the deflection of the gimbal as there is more force to overcome the spring system. By connecting a pointer to the gimbal the instrument will show the direction and rate of turn. If we replace the pointer with potentiometer a voltage can be created to drive an electronic circuit which will operate the rudder servo in the opposite direction to the yaw thus damping any unrequired turn or yaw. This is the basic principle of the yaw damper used in so many swept wing jet aircraft and used originally in model aircraft to control the tail rotor in model helicopters. The rapid advance of model helicopters soon revealed the shortcomings of the spinning mass gyro; they were somewhat imprecise, and subject to wear from the vibration present in helicopters and the development of solid state resonator gyros for commercial applications ( as distinct from the complex, highly accurate and very expensive ring laser gyros used in aircraft navigational systems) led to their use in model gyros. These Piezo electric gyros such as the JR 1000 offered vastly improved performance with a ten fold increase in sensitivity, lower current drain and, being sold state, a virtually unlimited service life. Piezo electric gyros comprise of a cylindrical piezo electric ceramic oscillator rod on which are printed polarized electrodes When a voltage is applied to the rod it torsionally vibrates. When the rod rotates it outputs voltages in proportion to the rate of rotation as a result of Coriolis * effect. The downside of the PE gyro is that it is quite susceptible to changes in temperature but its accuracy and reliability resulted in very rapid acceptance in the model helicopter field for stabilisation of the tail and such gyro units (the actual sensors are all made by specialist companies) were, and are, made in large numbers by such companies as JR and Futaba.. The latest development of the solid state gyro (or MEMS , micro electrical mechanical system) is the silicon ring gyro from Silicon Sensing Systems, a sub division of BAe Systems which also uses Coriolis effect to detect rotation but has the added advantages of increased sensitivity, resistance to shock and vibration and very little reaction to temperature variation, in other words, perfect for model use. It is now being produced, in the millions per year, for a wide variety of applications from car stability systems to video games and camera image stabilization. This device is used in the ACT Fuzzy gyro which will be described later. The first sold state gyros on the model scene, such as the JR 1000 were purely rate gyros which dampened the swinging of tails in helicopters but were also used on rudder and nosewheel steering on fixed wing models . Such a gyro was used with great effect on my BVM T33 which had very poor ground handling with the original landing gear (vastly improved with BVM’s own, excellent, landing gear units) and many tailwheel models were “tamed” with a gyro controlling the rudder. Following the appearance of solid state rate gyros a British company, CSM , developed a gyro system, the ICG 360, which would not only detect a rate of turn but would calculate the amount of turn and apply a corrective control input to return the helicopter to the original heading. It is possible to switch between modes in flight using the gain control. This breakthrough device was extremely effective and when hovering a helicopter the heading of the machine remained absolutely solid , even when lifting off in a very strong crosswind. The device was called heading lock but heading could only be held in the hover as in forward flight the heading of a helicopter is controlled by lateral cyclic, as the ailerons of a fixed wing aircraft, and if heading hold remained active on the tail rotor the machine would be very difficult to turn as the gyro would attempt to hold the nose in a constant direction. Clearly, if used on a fixed wing aircraft a heading lock gyro cannot be used on rudder as rudder inputs would then oppose normal turning and result in large yaw angles as a result of rudder deflection, but such a gyro CAN be used to maintain a constant bank angle or pitch attitude and it is in these two axes where “heading” hold gyros are being increasingly used in fixed wing models. So then, a standard single axis, single channel rate gyro can be used on rudder and /or noswheel steering and if necessary the control out put from one channel can be modified (in direction , throw and center) by the use of a Match box type unit to fine tune both the rudder and n/s servos to achieve just the degree of control required. The gyro can be placed after the receiver and before the Matchbox thus acting as a damper on both channels or after the Matchbox to act as a damper on just one Matchbox output. Such gyros have a sensitivity or gain pot to allow the response of the gyro to be tailored to the aircraft requirement so that any yaw oscillation is opposed by instant correction generated by the gyro. Most of my jets, including the BVM F4 and Sabre, are so equipped and the use of a gyro has been particularly beneficial to my two BVM BobCats. This model uses the landing gear doors as airbrakes and the turbulent and uneven airflow around these flat plate, and very simple but effective, brakes causes some directional instability, oscillation, when the gear is down. By using a gyro on the rudder channel such instability is eliminated as the gyro gain channel is slaved, via a mixer, to the gear channel so that the gyro operates at high gain with the gear down, but at very low rate with the gear retracted. As the nosewheel steering is also controlled by the gyro take off and landing rolls are very straight with minimal control input as any heading deviation is instantly opposed by gyro output. I t should be noted that the yaw deviation is opposed by the rate gyro but it will NOT be returned to the original heading in this mode. This function has worked flawlessly in the Bobcat, the same model as reviewed in RCJI, for 6 years. As the use of gyros for fixed wing aircraft began to take hold Futaba released a gyro specifically aimed for aileron use on these models and this unit incorporated a “hold “ facility and processed two channels on a single axis making it ideal for use on aircraft which utilize a servo on each aileron. Mark Savage was one of the early users of this gyro on his superb Vampire and has made this relatively small model rock solid in the air, no doubt aided by Mark’s super smooth piloting ! The Futaba GY 351 processes two channels and can be used as a rate gyro or in the “hold” mode. . The gyro has two servo reversing switches so that the gyro output can control servos in the correct sense. In addition the unit has two gain pots and these, respectively, adjust the gyro sensitivity, or gain, and the other adjusts the servo output allowing fine tuning of the gyro effect on the model. The gain of the gyro can be manually adjusted without receiver input (but then the gyro will work only as rate gyro, the “beginner mode”) or a receiver channel can be connected via a fly lead and the effect of the gain by tx adjustment will vary dependant on the initial manual setting of the gain pot. Setting the remote gain switch or knob to neutral will reduce gyro effect to nil, whilst gain setting to one side will increase gain in “rate” to maximum whilst rotation to the other side will engage the gyro to ”hold “ mode with increasing sensitivity. Whilst in “hold “ mode any stick deviation from neutral will switch off the “hold” allowing normal control but as soon as the stick is released the gyro will hold the bank angle at the value present when the stick was released to neutral. Clearly, any trim input whilst in “hold” mode will be seen as a control input so any trimming should be performed whilst in “rate” mode and the neutral seen by the gyro when ”hold” is selected will become the new neutral setting. The 351 has a tiny, but bright, LED which is off when in manual mode or gyro gain is zero, steady red when in “hold” mode and flashes twice when it senses a stick deviation from stored neutral when in ‘hold ‘ mode. Futaba refers to their “hold” mode as AVCS, angular velocity control system. Sadly the Futaba 351 gyro is no longer in production but is still available from some model shops. Increase in gyro use led to the incorporation of a gyro function in the superb Weatronic Dual Receiver and the latest Weatronic DRs the 12-26, incorporate a dual axis gyro system although both gyros work only in the rate mode. The latest development in dual channel single axis gyros is the Fuzzy Airplane gyro from the German company ACT and one of these units was purchased at the recent Jet Power Show. This gyro contains the latest , state of the art, silicon ring sensor manufactured in Japan to a British design by SSS as mentioned earlier. The SSS sensor, highly protected by patents, uses an inductive effect vibrator and the manufacturers claim class¬- leading resistance to shock, vibration and temperature. This is the unit used by Tommy Gleissner in his Jet World Masters winning Hawk and can be used in both” rate” and “hold” modes. The ACT system is a two part unit comprising the electronic controller and the external gyro unit which is the SSS CRS03 angular rate sensor The unit processes two channels in one axis and each channel has its own reversing switch to enable servo output in the correct sense. There are two other dip switches, one to select “normal” or “rate” mode, (only) or, in the opposite direction, it selects “heading” which functions at one side of the remote gain control travel whilst at the other side of the gain channel travel the gyro functions in “normal” or rate mode. A fourth switch allows the unit to “learn” the maximum servo travel it is allowed to command to avoid physical control system restrictions. In addition there are two pots one of which controls stick” fade out” (the deflection from stick neutral at which the gyro has no effect.) and the other controls gain in manual mode (ie without receiver input) or dynamic gain when the unit has a receiver gain input. Only by flight testing can this latter setting be made and the optimum gain is when the gain is set as high as possible without the servos “hunting” or “wagging . The tiny LED on the main case indicates the active mode with one flash indicating manual gain, two flashes the normal mode and the three flash sequence indicates the unit is operating in “heading” or “hold” mode” . So, the “hold” mode can be used on ailerons to hold a constant bank angle, including wings level, (but it is NOT a wing leveler unless “wings level” was the starting point) , and that is the main application but care is needed when using a gyro for this function as there are hazards. Clearly, if the gyro is set in the incorrect sense the model WILL be uncontrollable and WILL crash. It should also be remembered that there is no speed input so even as the stall is approached the unit will still try and maintain bank angle by use of ailerons and at the stall that COULD lead to a spin so the use of “hold” mode at low speed s should be used with caution. The Futaba gyro was fitted on my BobCat on ailerons in the simple rate mode. Gain on both gyro sensitivity and control out put was set at 70 % of maximum. On the first flight the model was notably more solid in roll . However the ailerons were seen to be hunting, with quite large amplitude, low frequency oscillations. After landing the model the gain was reduced by about 20%and again the model was absolutely solid with no sign of hunting. As well as being much smoother it was very noticeable that when releasing any aileron input, the model stopped rolling very cleanly and with a positive “lock in”. Aileron exponential need slight adjustment to restore the same feel as when flying without the gyro but such adjustments were quite small. As well as a controller on the roll axis there is no reason why a gyro should not be used as a pitch damper to smooth out pitch variations, or to hold pitch attitude. . However, it should be used with great caution in the “hold” mode on this axis as the gyro will try and hold the attitude of the model such that it may rapidly lose speed and even if the model is stalled it will still make elevator inputs to try and hold the attitude at which the model was when the last stick input was made. Futaba cautions against the use of this mode during take off and landing and similar cautions were issued by Boeing in the use of an autopilot mode known as CWS (control wheel steering) which used the autopilot to hold a fixed pitch and/or roll attitude much the same as the “hold” function on model gyros. . A few other cautions when using gyros. It must be absolutely certain that the gyro outputs to the control surfaces OPPOSE the motion of the aircraft and an independent check to confirm gyro action is highly advisable. Several models have already been lost because of incorrect control outputs and a models with wrongly set gyros ARE uncontrollable even by the most skilled pilot. When mounting the gyro it is essential that they are mounted in a secure but not rigid mounting. If the sensor unit were to come loose it will continue to work and may sense a totally different axis to that intended with the result that the model may become uncontrollable. There is no doubt that gyros, correctly set, up can enormously improve flying performance and is the damping effect is particularly effective in gusty, turbulent conditions (when gyro gain increase usually has a very beneficial effect) and make even an average pilot look super smooth . You may care to give gyros a try, after flying with them I’m hooked ! * Coriolis effect. In a rotating system, every point rotates with the same rotational velocity. As one approaches the axis of rotation of the system, the rotational velocity remains the same but the speed relative to the axis of rotation decreases. Thus to travel in a straight line lateral speed must be either increased or decreased and this change of speed is an acceleration (plus or minus) and the Coriolis force is the mass times acceleration of the object whose longitude is to be maintained. References. Silcon Sensing Systems: www.siliconsensing.com Action Control Team (ACT) : www.acteurope.de JR: www.jrradios.com Futaba: www.futaba.com
Hide Signatures
