RE: CMP F4U Corsair 50 Build Log    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: CMP F4U Corsair 50 Build Log
Page: <<   < prev  1 2 3 4 [5]
Login
RE: CMP F4U Corsair 50 Build Log - 2/22/2011 4:02 PM
SHEPSTER
Score: 100
Last Login: 9/23/2012
Status: offline
i have a brand new tower hobbies starter but it junk as it has no power to it and also i cant get to spin cause of small nut spinner .it wont turn it.
Hide Signatures
(in reply to w1nd6urfa)
       Post #: 101
RE: CMP F4U Corsair 50 Build Log - 2/22/2011 10:44 PM
SHEPSTER
Score: 100
Status: offline
i got fuel in line but i dont think its going in carb.pulled line and fuel at tip.its definatly not fooded.as if it cant get any fuel
Hide Signatures
(in reply to SHEPSTER)
       Post #: 102
RE: CMP F4U Corsair 50 Build Log - 2/23/2011 5:59 AM
w1nd6urfa
Score: 100
Last Login: 5/21/2013
Status: offline
Shep,
I would break in the engine on the bench first. Buy an engine test stand, its sound investment, will save hours of frustration. And sort out the starter, you won't get anywhere without it.
_____________________________
A designer knows he has achieved perfection when there is nothing left to take away (Antoine de Saint-Exupery)
Hide Signatures
       Post #: 103
RE: CMP F4U Corsair 50 Build Log - 10/7/2012 1:41 AM
cwalke32477
Score: 100
Last Login: 2/3/2013
Status: offline
Well I just got my cmp corsair 50 today.
I will say, upon unboxing, I knew this plane is going to be a bit of a project.
I'm taking the Saito FA90-R3 radial, I was using in a hangar9 corsair 60, and putting it in this bird.
I hope my fancy radial will power this one much better than my 9 pound 60.
I had "upgraded" to a dle 20cc gasser for the hangar 9. Which is just perfect BTW
Since the radial is a heavy motor, I hope it will balance this model perfectly without adding extra weight.
Hide Signatures
       Post #: 104
RE: CMP F4U Corsair 50 Build Log - 10/7/2012 1:52 AM
cwalke32477
Score: 100
Status: offline
I ordered the same retract set for mine. I noticed the same thing you , apparently, did.
The spar interferes with the retract motor.
I see you cut your spar to make them fit. Is this safe?
I was thinking about adjusting the oleo further down the wire to get the extension that I need.
I found i can barely stuff the whole mechanism in the wing, far forward, without cutting the spar.
But then the wheels do not reach the wells.
Hide Signatures
       Post #: 105
RE: CMP F4U Corsair 50 Build Log - 10/7/2012 6:04 AM
w1nd6urfa
Score: 100
Status: offline
Which retracts cwalke32477 ?
Hide Signatures
(in reply to cwalke32477)
       Post #: 106
RE: CMP F4U Corsair 50 Build Log - 10/7/2012 8:47 PM
mike early
Score: 125
Last Login: 5/19/2013
Status: offline
quote:
ORIGINAL: cwalke32477
This tread just got serious.
Saito Club Member #578
P-40 Brotherhood #62
Hide Signatures
       Post #: 107
RE: CMP F4U Corsair 50 Build Log - 4/15/2013 5:40 AM
DYORD
Score: 100
Last Login: 4/26/2013
Status: offline
Hi!  Do you have to angle the glow engine to have down-right thrust?!  If I do that, i might have to cut the dummy engine cowling.
Hide Signatures
(in reply to mike early)
       Post #: 108
RE: CMP F4U Corsair 50 Build Log - 4/15/2013 10:08 AM
w1nd6urfa
Score: 100
Status: offline
DYORD
IIRC down-right thrust is built in the airframe, you don't need to change anything
Hide Signatures
(in reply to DYORD)
       Post #: 109
RE: CMP F4U Corsair 50 Build Log - 4/22/2013 3:10 AM
harleyman1
Score: 100
Last Login: 4/27/2013
Status: offline
WELL, I READ THIS ARTICALE ON THIS CORSAIR, WELL, I WILL TELL YOU, ITS A PIECE OF JUNK, NOTHING IS DESIGNED RIGHT, YOU HAVE TO MODIFY THINGS  TO MAKE IT WORK, EVERY TIME YOU FLY IT, YOU HAVE TO BRING IT HOME TO REPAIR IT AND FLY IT AGAIN, CMP SHOULD BE ASHAMED TO PRODUCE SOMETHING LIKE THIS, I KNOW, I HAVE HAD TWO OF THESE AND THEY JUST FALL APART ON LANDING OR TAKING OFF, THERE IS NO QUALITY IN THESE ,THE DESIGN IS POOR , BAD WOOD, THE WING IS WEAK, WILL BREAK ON  LANDINGS SOMETIME, FOR THE TIME AND MONEY, GET A HANGAR NINE 50 CORSAIR OR ANOTHER TOP LINE BRAND WHERE THERE IS GOOD CRAFTMANSHIP AND GOOD DESIGN THAT WILL HOLD UP AND NOT FALL APART, ID RATHER BE FLYING THAN PATCHING IT UP SO YOU CAN FLY IT AGAIN, CMP IS NOT WORTH THE MONEY, THEY ARE CHEAP JUNK, GOOD LUCK  FLYING
Hide Signatures
       Post #: 110
RE: CMP F4U Corsair 50 Build Log - 4/22/2013 3:39 AM
Capt Easy
Score: 100
Last Login: 5/16/2013
Status: offline
....other than that how was the play Mrs. Lincoln?
Spitfire Brotherhood #34
Ryan STA/STM Brotherhood #31
Hide Signatures
(in reply to harleyman1)
       Post #: 111
RE: CMP F4U Corsair 50 Build Log - 4/22/2013 6:01 AM
BubbasanJohn
Score: 110
Last Login: 5/23/2013
Status: online
Hmmmm.  Love my cmp planes.  Wait he might not be able to see that typed that way.
I LOVE MY CMP PLANES. SOME OF THE BEST ARFS EVER.
Hide Signatures
(in reply to Capt Easy)
       Post #: 112
RE: CMP F4U Corsair 50 Build Log - 4/22/2013 1:22 PM
Capt Easy
Score: 100
Status: offline
I have a highly modified CMP Spitfire 50-54 converted to EP and it's definately a fantastic ARF. I even bought a spare NIB I liked it so much. I would have bought a Corsair 50 based on the qaulity of the Spit but after reading several disappointing experiences with it I changed my mind. Some of their other stuff seems to be pretty good but I'm not familiar.
Dick
Hide Signatures
(in reply to BubbasanJohn)
       Post #: 113
RE: CMP F4U Corsair 50 Build Log - 4/22/2013 7:46 PM
w1nd6urfa
Score: 100
Status: offline
HarleyMan1
If you're wondering about CMPro quality, have a look here: CMP Bf-109F
Hide Signatures
       Post #: 114
RE: CMP F4U Corsair 50 Build Log - 4/23/2013 2:01 AM
harleyman1
Score: 100
Status: offline
now i agree, thats a nice looking plane, any problems building that, not like the corsair i hope.
Hide Signatures
       Post #: 115
RE: CMP F4U Corsair 50 Build Log - 4/23/2013 4:57 AM
w1nd6urfa
Score: 100
Status: offline
Well I got it 2nd hand already built but not flown, the only mod done to the ARF by the previous owner was to replace the elevator fork pushrod with a 2-servo setup and I fitted ESM scale 80-degree retracts and struts.
The rest was done with an airbrush ...
Hide Signatures
       Post #: 116
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.078RCU1
