Greg Covey -> RE: EDF Predator UCAV from Nitro Planes (1/29/2011 11:48 PM)
The ARC and Midi Pro is without a doubt a superior combination. RC Lander has designed a newer "Dynamic Power Series" of 90mm EDFs but unfortunately skipped the 8s LiPo range. By the way, the Lander 90mm DFs come with a clam-shell set of clamps to mount the fan unit. You can see them in the image below. When cost is not an issue, I sometimes use the Lander metal housing with and ARC, Neu, or Typhoon motor and Midi Pro rotor. The combination was used on my twin Cessna Citation and this Nitro Planes Starfire model.
