Poulan chain saw engine...HELP!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> Poulan chain saw engine...HELP!
Page: [1]
Login
Poulan chain saw engine...HELP! - 6/4/2003 1:22 AM
ZmOz
Score: 100
Last Login: 11/22/2009
Status: offline
I'm thinking about buying an 18" Poulan chain saw with a 40cc engine to make something out of. The only thing I'm confused about is the crankshaft...how exactly do I attach a clutch or something to it?
Hide Signatures
       Post #: 1
Poulan chain saw engine...HELP! - 6/4/2003 2:51 AM
bn120
Score: 100
Last Login: 12/18/2008
Status: offline
what are you going to use the engine in.
Darin
_____________________________
sooo....was that a soft crash or a hard landing?
Hide Signatures
(in reply to ZmOz)
       Post #: 2
Poulan chain saw engine...HELP! - 6/4/2003 3:15 AM
ZmOz
Score: 100
Status: offline
[QUOTE]Originally posted by bn120
Darin
[/QUOTE]
Not exactly sure yet...but some sort of car/truck.
Hide Signatures
(in reply to ZmOz)
       Post #: 3
Poulan chain saw engine...HELP! - 6/4/2003 3:42 AM
Volfy
Score: 100
Last Login: 1/30/2009
Status: offline
I talked to a guy here locally that builds 1/4 or 1/5 scale monster trucks with Poulan chainsaw engines. He said he used the stock clutch assembly that came with the chainsaw. I never actually saw the trucks he made, but he was going to bring them into the LHS for show some weeks ago.
The idea sounds pretty workable, since the chainsaw clutch already has a gear on it, which can be used to gear down the drive shaft speed. I suppose you could also use the centrifugal type clutch in weedwackers if you want an "automatic" clutch, though I would recommend a failsafe engine cut mechanism in case the car/ boat get into a runaway situation with the throttle somehow stuck wide open. Judging by how much at hit by my E-Maxx can hurt, a 40lbs car can do some serious damage.
Si vis pacem, para bellum.
Hide Signatures
(in reply to ZmOz)
       Post #: 4
Poulan chain saw engine...HELP! - 6/5/2003 1:35 PM
ZmOz
Score: 100
Status: offline
So nobody knows what the crankshaft looks like? Using the stock clutch might be an option...but I would still like to know what size/shape crank it has...
Hide Signatures
(in reply to ZmOz)
       Post #: 5
Poulan chain saw engine...HELP! - 6/5/2003 2:49 PM
Antique
Score: 557
Last Login: 3/21/2012
Status: offline
The crank has a taper shaft on one end with a flywheel on it for the spark, and a straight shaft on the other end with a centrifugal clutch on it for the chain....they're all the same....
the taper end has an 8mm right hand thread on it, the straight end has a left hand thread for the clutch....
RC Ignition
Hide Signatures
(in reply to ZmOz)
       Post #: 6
Poulan chain saw engine...HELP! - 6/6/2003 6:19 AM
ZmOz
Score: 100
Status: offline
[QUOTE]Originally posted by RCIGN1
[/QUOTE]
What size are the threads for the clutch side?
Hide Signatures
(in reply to ZmOz)
       Post #: 7
Poulan chain saw engine...HELP! - 6/6/2003 7:29 AM
Antique
Score: 557
Status: offline
The Poulans I have are 46cc, the thread is 8mm by 1 pitch...
RC Ignition
Hide Signatures
(in reply to ZmOz)
       Post #: 8
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> Poulan chain saw engine...HELP!
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.344RCU1
