RE: OFFICIAL HPI Sprint 2 Thread (Sport and Flux)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric On-Road vehicles, race cars and more >> RE: OFFICIAL HPI Sprint 2 Thread (Sport and Flux) Page: <<   < prev  57 58 59 60 61 [62] 63 64 65 66   next >   >>
Login
RE: OFFICIAL HPI Sprint 2 Thread (Sport and Flux) - 10/7/2012 5:24 PM
drc35ca
Score: 100
Last Login: 5/17/2013
Status: offline
I find this combination easy on everything when geared to go around 40mph max on a 2S Lipo?  When I want it to rocket i put in a traxxas velineon 550 motor with a Larger castle creations Speedo (not sure what model)  with fan built in and run 3S geared up. Car must hit near 75-80 mph with a low body from onroad racing thats about 20 years old but gives good down-force.
Speed costs not only in faster wear but striking something at these speeds can destroy a car in a blink,but thats up to you?
Hide Signatures
(in reply to RocketCityDrifter)
       Post #: 1526
RE: OFFICIAL HPI Sprint 2 Thread (Sport and Flux) - 10/7/2012 8:15 PM
DarksideVR
Score: 105
Last Login: 3/11/2013
Status: offline
Hi I am new to the world of on-road and drift rc cars but have been thinking of getting a sprint to drift car. I would run a 2s lipo with the stock electronics. I don't plan on doing a ton of upgrades, I was thinking of getting a set of the hard plastic drift tires with wheels. My question is what upgrades would I need to start enjoying this car. and you would i need a lipo cutoff to run a lipo on the stock setup? Thanks for any info.
_____________________________
HPI E FIRESTORM
HPI SPRINT 2 DRIFT
Hide Signatures
       Post #: 1527
RE: OFFICIAL HPI Sprint 2 Thread (Sport and Flux) - 10/8/2012 2:53 AM
driftin007
Score: 100
Last Login: 10/8/2012
Status: offline
I run Sprint 2 Drift 350z and it will take any LiPo. just have to follow the directions in the manual it comes with to change settings although it comes stock set for LiPo, but you get a NiMh bat with the kit. go figure.
Hide Signatures
(in reply to DarksideVR)
       Post #: 1528
RE: OFFICIAL HPI Sprint 2 Thread (Sport and Flux) - 10/8/2012 1:39 PM
DarksideVR
Score: 105
Status: offline
sweet! Thanks!
HPI E FIRESTORM
HPI SPRINT 2 DRIFT
Hide Signatures
(in reply to driftin007)
       Post #: 1529
RE: OFFICIAL HPI Sprint 2 Thread (Sport and Flux) - 10/12/2012 3:45 AM
DarksideVR
Score: 105
Status: offline
Got the car it was easy to set up for my lipo. I have a question or two about the drive belts. The front belt seems to touching the upper chassis and the rear belt is rubbing on the motor. Is this normal? or how do I fix it? Thanks in advance
HPI E FIRESTORM
HPI SPRINT 2 DRIFT
Hide Signatures
       Post #: 1530
RE: OFFICIAL HPI Sprint 2 Thread (Sport and Flux) - 10/12/2012 7:07 PM
drc35ca
Score: 100
Status: offline
quote:
ORIGINAL: DarksideVR
Go with a Aluminum pulley on the rear and install a rear tensioner like I have done,this will pick up slack and stop belt from jumping on the pulley and keep the belt away from a hot motor !  Also changing over to TOUGH RACING BELTS will help. You have the new chassis and there are or should be cutouts in the chassis and bulkheads to stop debris buildin up and shredding the belts!   CVDS work well also.
Hide Signatures
       Post #: 1531
RE: OFFICIAL HPI Sprint 2 Thread (Sport and Flux) - 10/13/2012 3:30 AM
DarksideVR
Score: 105
Status: offline
Looking into the belts and aluminum pulley. How did you rig up that tensioner? Maybe point me in the right direction for some parts, if ya don't mind helping the new guy out.
Found your post about the tensioner and have some parts ordered. Thanks
< Message edited by DarksideVR -- 10/13/2012 5:54 AM >
HPI E FIRESTORM
HPI SPRINT 2 DRIFT
Hide Signatures
(in reply to drc35ca)
       Post #: 1532
RE: OFFICIAL HPI Sprint 2 Thread (Sport and Flux) - 10/14/2012 2:12 AM
rockydc
Score: 100
Last Login: 11/9/2012
Status: offline
Hello guyz I just bough a Sprint 2 Flux it will be my first on road RC and first electric , Im going to drift with it too.
< Message edited by rockydc -- 10/14/2012 3:09 PM >
Hide Signatures
       Post #: 1533
RE: OFFICIAL HPI Sprint 2 Thread (Sport and Flux) - 10/14/2012 11:41 AM
drc35ca
Score: 100
Status: offline
Rear tensioner is just a front pulley turned upside down,I use the center hole to mount which gives me just enough movement to adjust the belt so that it picks up the slack in the belt.
This stops the belt from bouncing on and off throttle and also makes it follow more of the surface of the upper pulley giving less chance to jump and do damage.
Use 2 tamiya type (5x8x2.5)  bearings on the tensioners instead of the bushings it comes with.
Aluminum Pulleys are available again on ebay,just got 2 from omni models.
< Message edited by drc35ca -- 10/14/2012 12:47 PM >
Hide Signatures
       Post #: 1534
RE: OFFICIAL HPI Sprint 2 Thread (Sport and Flux) - 10/16/2012 12:28 AM
ChrisJuliano
Score: 100
Status: offline
I bought RPM rod ends which are alot longer and wider than the normal stock HPI linkage ends, and me being dumb I didnt measure ball to ball before I changed them over and now my steering angle is completely off and I cant get it to work right, also got a new servo at the same time (properly setup and end points are at the max my XS3 will do, and travel is at max too) and I cant get it to go stock lock to lock angle.
Can someone please measure the linkage from the servo to the servo savor thing eye to eye? And then the middle rod that connects the right steering to left?
Or give me advice? Thanks!
My cars: [Rc18T- Brushless]
FOR SALE:
Hide Signatures
(in reply to Car-Tune)
       Post #: 1535
RE: OFFICIAL HPI Sprint 2 Thread (Sport and Flux) - 10/17/2012 3:36 AM
WindyCitySquirrel
Score: 100
Last Login: 5/9/2013
Status: offline
Measured center to center either inside or outside of the cups.
TOE LINKS: 1.40"
FRONT CAMBER LINKS: 1.585"
REAR CAMBER LINKS: 1.5"
SERVO LINK: 1.82"
ACKERMAN LINK: 1.915"
quote:
ORIGINAL: ChrisJuliano
Hide Signatures
(in reply to ChrisJuliano)
       Post #: 1536
RE: OFFICIAL HPI Sprint 2 Thread (Sport and Flux) - 10/17/2012 3:47 AM
DarksideVR
Score: 105
Status: offline
I just wanted to say I have ran a couple lipo packs through my car and have had a blast with it. I got another set of drift tires on BBS wheels as well as some road tires on some wheels that look like Rotas. I have a handful of parts on order. Here is the list of parts on the way; 2 of the aluminum center pulleys, a tensioner for the rear belt, bearings for both tensioners, Tough racing drive belts front and rear, HD carbon fiber front and rear shock towers and the HPI graphite upper chassis deck. Thanks for the help on getting this car setup.
HPI E FIRESTORM
HPI SPRINT 2 DRIFT
Hide Signatures
(in reply to WindyCitySquirrel)
       Post #: 1537
RE: OFFICIAL HPI Sprint 2 Thread (Sport and Flux) - 10/17/2012 10:51 AM
ChrisJuliano
Score: 100
Status: offline
Wow thanks so much!!!! Your the best!
FOR SALE:
Hide Signatures
       Post #: 1538
RE: OFFICIAL HPI Sprint 2 Thread (Sport and Flux) - 10/21/2012 2:38 AM
DarksideVR
Score: 105
Status: offline
I have 3 or more hours of drifting in and am loving it. Thanks to some tips from this site I have added a tensioner for the rear belt and put on some aluminum pulleys. I have some more goodies on the way. Here is a pic of the new pulleys and tensioner installed.
HPI E FIRESTORM
HPI SPRINT 2 DRIFT
Hide Signatures
       Post #: 1539
RE: OFFICIAL HPI Sprint 2 Thread (Sport and Flux) - 10/23/2012 10:54 AM
ChrisJuliano
Score: 100
Status: offline
My car tends to gain alot of speed during drifting, after driving a few of my other friends cars it makes mine super undriveable on short courses.
What could I do to make it slower? I am thinking a smaller gear on the motor would help since it would be more torque on my stock motor making it spin faster quicker keeping speed down hopefully? Or maybe it would do opposite and make it faster like it woudl if I had grip tires?
EDIT: I have the plastic hpi tires.
FOR SALE:
Hide Signatures
       Post #: 1540
RE: OFFICIAL HPI Sprint 2 Thread (Sport and Flux) - 10/23/2012 1:05 PM
rockydc
Score: 100
Status: offline
You have the flux or sport?
Hide Signatures
       Post #: 1541
RE: OFFICIAL HPI Sprint 2 Thread (Sport and Flux) - 10/24/2012 4:27 PM
ChrisJuliano
Score: 100
Status: offline
Sport, non brushless one.
I have a one way up front, not sure if its stock pinon on the motor since I bought it used.
FOR SALE:
Hide Signatures
(in reply to rockydc)
       Post #: 1542
RE: OFFICIAL HPI Sprint 2 Thread (Sport and Flux) - 11/9/2012 4:21 AM
WindyCitySquirrel
Score: 100
Status: offline
(Question retracted due to lack of interest)
< Message edited by WindyCitySquirrel -- 11/17/2012 7:05 PM >
Hide Signatures
       Post #: 1543
RE: OFFICIAL HPI Sprint 2 Thread (Sport and Flux) - 12/7/2012 10:11 AM
fk452
Score: 100
Last Login: 3/4/2013
Status: offline
Just got the HPI Falken Sprint 2 sport porsche. Any ideas on what to upgrade??
Hide Signatures
       Post #: 1544
RE: OFFICIAL HPI Sprint 2 Thread (Sport and Flux) - 12/7/2012 10:13 AM
fk452
Score: 100
Status: offline
Just got the HPI Falken Sprint 2 sport porsche. Any ideas on what to upgrade?? i have already swapped out the brushed motor to brushless/
Hide Signatures
       Post #: 1545
RE: OFFICIAL HPI Sprint 2 Thread (Sport and Flux) - 12/7/2012 1:55 PM
Car-Tune
Score: 110
Last Login: 5/24/2013
Status: offline
Carbon fiber chassis, upper deck, and shock towers. Upgrade the bearings too.
Hide Signatures
(in reply to fk452)
       Post #: 1546
RE: OFFICIAL HPI Sprint 2 Thread (Sport and Flux) - 12/9/2012 1:39 AM
dade247
Score: 100
Last Login: 1/10/2013
Status: offline
I just purchased the Sprint to Sport Mustang GTR-X , Anyone else has this?
Hide Signatures
       Post #: 1547
RE: OFFICIAL HPI Sprint 2 Thread (Sport and Flux) - 12/10/2012 5:21 PM
motorhead91
Score: 100
Last Login: 5/23/2013
Status: offline
quote:
ORIGINAL: dade247
I just saw this and it looks freakin' awesome. I may have to part with one of my trucks to pick this up. I'd rather buy a roller and paint the body and get the wheels myself but of course to get those you have to buy the whole RTR
rc''s: ae sc10 4x4, miss vegas, rio ep
real cars: a couple of f-bodies
Hide Signatures
(in reply to dade247)
       Post #: 1548
RE: OFFICIAL HPI Sprint 2 Thread (Sport and Flux) - 12/11/2012 11:41 PM
Coolio831
Score: 100
Last Login: 2/8/2013
Status: offline
 I also recently picked up the Falken tire Porsche. I've been looking for the past 2 days for exact oem replacements but can't find them online anywhere.  I'm running a SV2/7700kv combo on 6 cells geared 31/90. The tires are starting to get beat up. I plan on ordering a new radio/tires and a body tomorrow.
Edit: Forgot to mention I'm looking for the rear and front original falken tires 31mm/34mm with 9mm front offset and 12-14mm rear offset rims.
< Message edited by Coolio831 -- 12/12/2012 4:19 PM >
Hide Signatures
(in reply to motorhead91)
       Post #: 1549
RE: OFFICIAL HPI Sprint 2 Thread (Sport and Flux) - 12/12/2012 5:09 AM
Car-Tune
Score: 110
Status: offline
Pics!
Hide Signatures
(in reply to Coolio831)
       Post #: 1550
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.656RCU1
