Can the PT Gyros Be Steered With Rudder Only ??
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> AutoGyros >> Can the PT Gyros Be Steered With Rudder Only ??
Page: [1]
Login
Can the PT Gyros Be Steered With Rudder Only ?? - 1/6/2009 3:25 AM
ottogiro58
Score: 100
Last Login: 1/17/2009
Status: offline
Hi Gang, Are there any PT Gyro scientist/pilots (all PT models) who would like to try a simple experiment ?? Adjust your radio gear so the rudder and elevator (rotor pitch) are on the same stick, and see if it can be flown as a 3-channel trainer airplane would be handled..... Some up-elevator might be needed while turning.....You could still leave the roll control on the left stick with the throttle, in case you need to bail out and recover using roll........ Who knows, a 3-channel autogyro might make the ideal training aircraft !!! C'mon guys, this is an easy experiment and could lead to simplification of this design. Less cost, less weight, less construction. Thanx !!! Charlie Anderson
< Message edited by ottogiro58 -- 1/6/2009 4:11 AM >
Hide Signatures
       Post #: 1
RE: Can the PT Gyros Be Steered With Rudder Only ?? - 1/6/2009 10:55 AM
rcflyerfl
Score: 100
Last Login: 11/6/2009
Status: offline
Charlie,
My Whistlers are Rudder and Elevator only. And engine of coarse.From 25 size to 120 size.
Jim
Hide Signatures
(in reply to ottogiro58)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.172RCU1
