Tower Hobbies
Logged in as Guest
  Printable Version
XYZ-50cc Gas Engine
Seller:  XYZUSA
Details:   $249.00   |  7/3/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >>
Page: [1]
Login
- 6/4/2003 10:45:13 PM
mpj220
Status: offline
No longer support RCU
< Message edited by mpj220 -- Aug 4 2003 11:44PM >
       Post #: 1
- 6/6/2003 11:52:20 PM
Richard L.
Status: offline
It could be just that batch of fuel. What's the batch number? The same thing happened to my YS .63 when I switched to a new gallon of Powermaster YS 20/20. The engine ran fine on the previous gallon. However, it started detonating when I began using the new gallon. The knocking noise was so bad that I had to run the engine richer than usual.
(in reply to mpj220)
       Post #: 2
- 6/6/2003 11:59:22 PM
JWN
Status: offline
Richard,
Care to share the batch # with us? I have an unopened can of 20/20 sitting at home and I'd like to have an idea of whether or not to expect problems with it.
John
       Post #: 3
- 6/7/2003 6:37:26 AM
Richard L.
Status: offline
The batch # is 3256. I also have another unopened can of 3256, so we'll see what happens.
       Post #: 4
- 6/7/2003 7:40:37 PM
JWN
Status: offline
My can is #3326 so I shouldn't have any problems.
John
       Post #: 5
- 6/9/2003 7:40:06 PM
mpj220
Status: offline
< Message edited by mpj220 -- Aug 4 2003 11:51PM >
       Post #: 6
- 6/9/2003 7:46:12 PM
JWN
Status: offline
There are a lot of people running 30% nitro in their YS 4-strokes without any problems. I suspect your LHS may store their fuel on a concrete floor. That, and give the fact that your fuel has an older batch number indicates that water may have found it's way into the can which can cause all kinds of problems even if the fuel does not appear milky. Been there, done that.
John
       Post #: 7
- 6/9/2003 10:33:16 PM
mpj220
Status: offline
       Post #: 8
- 6/11/2003 11:22:38 PM
POWERMASTER
Status: offline
mpj220
Mark have had no complaints on the batch 2549 25/20 fuel which is a pattern fuel. The batch is over two years old and during this time have had no reports of any problems when using this fuel.
It sounds like the engines are pre-det. causing them to run hot. This fuel is an all synthetic oil mix the same as the 20/20 fuel, just more nitro.
Will pull retain and check to see if there is/was a problem in the mix.
Wendell
_____________________________
Wendell Hammond
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.438RCU1
