Wiring diagram for HL RX18 Board    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Tanks >> Wiring diagram for HL RX18 Board
Page: [1]
Tower Hobbies Today's Special Offer! Brands Products
Login
Wiring diagram for HL RX18 Board - 1/8/2009 4:47 PM
Alan123
Score: 111
Last Login: 2/5/2011
Status: offline
Has anyone done a diagram or photo guide of how one connects the new HL RX18 board into a HL tank that did not have one before.
I am trying to do one at the moment and am having trouble working it all out and really need a guide for dummies because I am no good at this sort of thing at all and am likely to damage something.
It is the turret connections that are hard to work out, especially when one has a recoil unit installed.
I need to know which wire goes where.
Alan.
_____________________________
http://myworld.ebay.de/tankpainter2010/
http://www.youtube.com/alanundlilja
Hide Signatures
       Post #: 1
RE: Wiring diagram for HL RX18 Board - 1/8/2009 5:17 PM
YHR
Score: 190
Last Login: 2/4/2012
Status: offline
Here you go
RX 18
Dan
Battle Armor RC
Hide Signatures
(in reply to Alan123)
       Post #: 2
j z
Score: 100
Last Login: 2/3/2012
Status: offline
Hi Alan. Atkliev had a similar post and bubbajoexx posted a pretty detailed photo diagram of what all the outputs are for. Look for upgrading to rx-18. Regards, JZ
Hide Signatures
       Post #: 3
RE: Wiring diagram for HL RX18 Board - 1/8/2009 7:06 PM
Alan123
Score: 111
Status: offline
This is exactly what I needed. It even has notes for connecting the Tamiya things.
Alan.
Hide Signatures
(in reply to j z)
       Post #: 4
RE: Wiring diagram for HL RX18 Board - 1/8/2009 8:30 PM
Alan123
Score: 111
Status: offline
Well the diagram could not have been that good as I have connected the turret turn and elevation units, powered on for a test and the RX18 smoked and is now no good. Thats $30 straight down the toilet. F'ken great!
Hide Signatures
       Post #: 5
RE: Wiring diagram for HL RX18 Board - 1/8/2009 9:22 PM
darkith
Score: 101
Last Login: 12/11/2011
Status: offline
Hrm,
Most of the diagram is correct, as it looks like it was mostly cribbed from the one I drew up, and I'm pretty sure of the information I traced out myself.
The turret and elevation wasn't on my diagram, and I see what looks like two errors, one in the speaker volume port, and another for the turret info. Should be one wire for elevation, one wire for fire (airsoft or recoil), and a common B+ wire for elevation and fire.
Based on other diagrams, I think it might be:
C: Elevate (switched negative)
D: Fire (switched negative)
E: Elevate & Fire (B+)
Though, I wouldn't have thought that that error would cause the board to smoke. Another possibility is the the key is backwards (e.g. A & H are backwards, B & G are backwards), which could have toasted the 5v regulator on the board from excessive current draw.
D.
RCU Required Disclosure: Manufacturer of DBC battle circuit for Heng Long tanks.
Hide Signatures
       Post #: 6
RE: Wiring diagram for HL RX18 Board - 1/8/2009 9:55 PM
Alan123
Score: 111
Status: offline
God is with me! After cup of tea and a rest I went back to my setup and the board must have somehow recovered as it now works again, but with that much smoke it can never be 100% of what it was.
Whats more I worked out where the error is. On turret elevation you have to use pin 3 and 5 (just like with an Elmod conversion which is what made me think of it), thats Blue D and E on the diagram not C and D as shown. I think you cover that in your last reply.
Pls do not be disheartened, the diagram is great and thanks a lot for producing it.
Any idea where to put the 2 wires that come off the Asiatam Recoil unit?
Cheers
Alan.
Hide Signatures
(in reply to darkith)
       Post #: 7
RE: Wiring diagram for HL RX18 Board - 1/8/2009 11:20 PM
j z
Score: 100
Status: offline
Glad to hear your board is O.K. I was feeling sick to my stomach, I know all to well what it's like to finally have a new board arrive , only to have it detonate . Good luck . Regards, JZ
Hide Signatures
       Post #: 8
RE: Wiring diagram for HL RX18 Board - 1/9/2009 7:58 AM
swathdiver
Score: 101
Last Login: 11/4/2011
Status: offline
quote:
ORIGINAL: j z
That's why you always buy 2! I was beginning to think with these great 14 and 18 boards it was ok to change my signature, looks like I'm going to change it back!
If we ever forget that we are One Nation Under God, then we will be a nation gone under. - Ronald Reagan
Hide Signatures
(in reply to j z)
       Post #: 9
RE: Wiring diagram for HL RX18 Board - 1/10/2009 12:41 AM
j z
Score: 100
Status: offline
I used to order many at a time. Then as I learned a little more, I must have gotten over confident with myself. These newer boards are almost fool proof, but until they make them idiot proof,I have to be on my guard. No James, I don't have spare boards. Regards, JZ
Hide Signatures
(in reply to swathdiver)
       Post #: 10
RE: Wiring diagram for HL RX18 Board - 1/10/2009 2:47 AM
bubbajoexx
Score: 110
Status: offline
UPDATED DIAGRAM
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to j z)
       Post #: 11
RE: Wiring diagram for HL RX18 Board - 1/10/2009 4:30 AM
YHR
Score: 190
Status: offline
quote:
ORIGINAL: j z
Funny
I always have spare boards. Not because they Heng Long board are bad, more just because I am so stupid
Dan
Battle Armor RC
Hide Signatures
(in reply to j z)
       Post #: 12
RE: Wiring diagram for HL RX18 Board - 1/10/2009 4:18 PM
philipat
Score: 104
Status: offline
I'm comparing the colored letter diagram and the one on Darkith's webpage and I have a couple of questions about the RX-18 board:
1) Where does the smoker switch go? Is it still integrated into the board like on the 13 and 14 boards? Or is that the green A/B? The Red A/B looks like the leads to the smoker itself. I don't think it's the main on/off switch because that goes on the positive lead between the battery and the board (sits between the light blue A/B).
2) If you order the RX-18 separately, does it come with the volume knob terminated in the correct plug? How about the smoker switch and power switch? I guess the latter two could be done with the jumpers that RC Command sells.
It''s been said that politics is the second-oldest profession...it bears a great similarity to the first. -Ronald Reagan
Hide Signatures
(in reply to bubbajoexx)
       Post #: 13
RE: Wiring diagram for HL RX18 Board - 1/10/2009 5:46 PM
bubbajoexx
Score: 110
Status: offline
lime green a and b are the smoke switch the power switch is the one used on the original tank location
Hide Signatures
(in reply to philipat)
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
RC Universe is a service of Internet Brands, Inc. Copyright © 2001-2012.
3.984RCU1
