Futaba Servo Battery Compatibility Data
Krysta/Bax,
I was recently asked by a fellow flying buddy for some assistance in selecting new servos for his next plane. We discussed a broad number of potential candidates and he seems to have settled on the Futaba brand. When he did his research on each candidate he discovered information that seemed to question the use of either Nimh or Lipo batteries with the servos. Sure enough when I looked into the information provided on the Futaba website and the Tower website I found the following:
Quoted from both the Futaba and Tower websites
S3305
This is the Futaba S3305 High Torque, Metal Gear Servo. per Futaba this servo is approved for use with NiCd batteries ONLY!
This servo can produce high-current draw from your batteries.If using NiMH or LiPo batteries, make sure they are capable of delivering sufficient amps
S3010
This servo can produce high-current draw from your batteries. If using NiMH or LiPo batteries, make sure they are capable of delivering approximately 2A for each servo
S3004
This servo can produce high-current draw from your batteries. If using NiMH or LiPo batteries, make sure they are capable of delivering sufficient amps.
S3001
There are a number of areas where I have issues with these statements but, my primary concern is why Futaba is calling into question the use of Nimh or Lipo batteries and in one case requiring the use of Nicd only. Some of the new Nimh batteries with low internal impedance are exceptional airborne packs and easily exceed many parameters available in Nicd batteries. Other than Lipo high voltage concerns I am not aware of other parameters that could be detremental to Futaba servos. If high voltage is a concern then I think it would be better to say that.
In any case I am posing this issue so that I can learn from it - your insights and knowlege are appreciated.
Howard
S3305
S3010
S3004
S3001
Howard
RE: Futaba Servo Battery Compatibility Data
The statements are there because many people have NiMH or LiPO battery packs that simply cannot deliver the current necessary to drive a number of the large servos. Therefore the caution. Would you have us not caution you about the fact that high-current draw can cause damage to NiMH or LiPO battery packs that are not able to handle the loads? NiCd battery packs are well-proven through decades of use to be able to provide high levels of current, provided they are of sufficient capacity to give you the duration you need, and that you use wiring of sufficient gauge to prevent voltage drop.
ORIGINAL: Bax
I certainly applaud the motivation and intent however, the impact (I think) may be different than you intended. Just a thought. If you told me your attorney wrote the caution then I would really understand. Thanks for getting back to me so quickly, your presence and contributions make a very positive difference and lots of us appreciate it.
Howard
