RE: NEUTRINO - NEW F3A PROJECT FROM GREECE    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> RC Pattern Flying >> RE: NEUTRINO - NEW F3A PROJECT FROM GREECE
Page: <<   < prev  1 2 3 4 5 6 7 [8] 9   next >   >>
Login
RE: NEUTRINO - NEW F3A PROJECT FROM GREECE - 4/28/2009 10:32 PM
doxilia
Score: 136
Last Login: 6/19/2013
Status: offline
That looks bl**dy fantastic Elias!! 3350 g! Go 123's
When did you find the time to make the landing gear and pants or did you have those around? Hey, it looks like you have a CF spar running down the length of the wings. Perhaps I missed it but how were the wings layered up? Is the CF a solid cured piece or is it CF mat? Lately, I've started to add CF "spars" to foam cores in the build of pattern classics (photo attached) and very pleased with the results!
Elias, I'm glad you've paved the way for 11s2p (4600 mAh) on A123's. Perhaps it's been done before in 2m pattern but I've yet to find any info on line for such an arrangement and have been tempted to do the same for 10s lipo configurations as well as 9s2p for 8s lipo configurations, particularly where swapping packs is undesirable. I imagine you intend to use that single arrangement without swapping and recharge the two separate 11s packs on board (in 15 min no less!) - the only question is, what charger is able to charge 11s 123's? Perhaps your setup consists of 4 packs arranged as (6s5s)2p requiring 4 chargers? Would really like to see and hear more about how you went about this.
Perhaps you switch to lipo's for competition (sound like you're a tad over 5 kg AUW with 123's)?
David.
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by doxilia -- 4/28/2009 10:35 PM >
Hide Signatures
(in reply to highfly3D)
       Post #: 176
RE: NEUTRINO - NEW F3A PROJECT FROM GREECE - 4/28/2009 11:04 PM
Elias Sopeoglou
Score: 100
Last Login: 6/17/2013
Status: offline
Friday evening I was even happier as I managed to do the first flight just before it became dark.The original impression is that the plane flys straight with only the slightest coupling of rud-ail mix that could also be managed by the rudder shape.Other than that no other mix is needed ! Snaps are crisp and precise and swept wing looks really nice and stalls clear and straight.There is some work on the differectial to be done since it´s quite different to what I have flown so far.There is absolutely no pitch coupling at knife edge something that made me smile on my way back since I did all the work with the movable stab sys
During the weekend I flew the plane with lipos thanks to my dear friend Alex (buka). With a final weight of 4500 ,the feeling of such a light plane made me even happier :-))
The only thing remaining now is good paint job and the plane is set ! Shortly will start on Nr2........
Elias
Click for fullsize
< Message edited by ELIAS SOPEOGLOU -- 5/6/2009 8:04 PM >
Hide Signatures
(in reply to Elias Sopeoglou)
       Post #: 177
RE: NEUTRINO - NEW F3A PROJECT FROM GREECE - 4/29/2009 12:52 AM
flyintexan
Score: 100
Last Login: 6/18/2013
Status: offline
Congratulations! Well done.
-mark
_____________________________
NSRCA 3656
www.NSRCA.us
Hide Signatures
       Post #: 178
RE: NEUTRINO - NEW F3A PROJECT FROM GREECE - 4/29/2009 3:11 AM
Jeff Boyd 2
Score: 100
Last Login: 9/13/2012
Status: offline
Fantastic Elias . .
Good guess for the stab position
Great overall package. Looks good with NO paint
Well done. Thanks for sharing your building with us.
Cheers, JB
South Australian Pattern Association web = http://sapa-f3a.blogspot.com/
Hide Signatures
       Post #: 179
RE: NEUTRINO - NEW F3A PROJECT FROM GREECE - 4/29/2009 9:35 AM
highfly3D
Score: 100
Last Login: 6/14/2013
Status: offline
The plane looks awesome , do you plan to paint it or cover it with iron on
quote:
ORIGINAL: ELIAS SOPEOGLOU
Friday evening I was even happier as I managed to do the first flight just before it became dark.The original impression is that the plane flys straight with only the slightest coupling of rud-ail mix that could also be managed by the rudder shape.Other than that no other mix is needed ! Snaps are crisp and precise and swept wing looks really nice and stalls clear and sraight.There is some work on the differectial to be done since it´s quite different to what I have flown so far.There is absolutely no pitch coupling at knife edge something that made me smile on my way back since I did all the work with the movable stab sys
Elias
< Message edited by highfly3D -- 4/29/2009 9:37 AM >
I will say it only once Yak 54 the best aerobatic plane ever made.
Hide Signatures
       Post #: 180
RE: NEUTRINO - NEW F3A PROJECT FROM GREECE - 4/29/2009 1:47 PM
Magne
Score: 100
Status: offline
Elias.
Nice job, well done.
I flew about 100 flights last summer with 11s2p A123, worked quite well with a Hacker C50 12XL motor.
I made two packs, and recharged @20A in 12 minutes from mains supply, or @16A in 15-16 minutes using a small generator.
The charging was done directly on a Hysys 5020E power supply. (Max. 50V/20A)
This power supply works just like a normal CC/CV charger, no need for a separate charger. (NOT recommended for Lipos, but ok for A123)
I found that the 11s2p packs contained JUST enough energy for a P09 flight, with not much reserve.
(on A123 you don't need to limit your consumption to 80% of the pack capacity, but when it is empty, it really stops dead.)
What is the final weight of your wing panels?
Regards,
Magne
Hide Signatures
       Post #: 181
RE: NEUTRINO - NEW F3A PROJECT FROM GREECE - 4/29/2009 9:01 PM
Elias Sopeoglou
Score: 100
Status: offline
Hallo
Thanks for the comments !
The legs are ZN long legs ,the pants I made with my own mould out of carbon.
The wing spars are carbon prefabricated tubes 4mm outer.
About 123s I thing they are super cells but just not for competition ,who would like to fly a plane in a competition more than 500gr heavyer.
Magne your method is definately the way to go ,a guy over here charges them directly from a set of led batterys.
I just test flown them for trimming ,will definately go for the lipos and I´m about to decide what I´m getting.
Wing panels are not as light as I wanted them to be ,weight is 340gr less servo and paint .I guess 470gr all up weight with sevo(8401) and paint .Will be making a mould for the wings in the future ..
cheers
Elias
Hide Signatures
(in reply to Magne)
       Post #: 182
RE: NEUTRINO - NEW F3A PROJECT FROM GREECE - 4/29/2009 9:21 PM
tuny
Score: 100
Status: offline
Congratulation Elias! exelent work!!! really amazing
Regards
TUNY
Hide Signatures
       Post #: 183
RE: NEUTRINO - NEW F3A PROJECT FROM GREECE - 5/27/2009 3:04 AM
Elias Sopeoglou
Score: 100
Status: offline
Hallo !
Finaly I managed to paint my plane ,it was quite adventurous since it was the first time for me to use water based acrylic car paint ,quite furstrating at times when paper tape soaked in moisture got saged (you can imagine at wich part of the plane !) anyways the result came quite ok ,maybe a bit heavyer now (havent weighted yet)  but I really dont mind...
so here it is ..
reguards
Elias
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by ELIAS SOPEOGLOU -- 5/27/2009 7:55 PM >
Hide Signatures
(in reply to tuny)
       Post #: 184
RE: NEUTRINO - NEW F3A PROJECT FROM GREECE - 5/27/2009 3:07 AM
Elias Sopeoglou
Score: 100
Status: offline
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 185
RE: NEUTRINO - NEW F3A PROJECT FROM GREECE - 5/27/2009 3:09 AM
Elias Sopeoglou
Score: 100
Status: offline
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 186
RE: NEUTRINO - NEW F3A PROJECT FROM GREECE - 5/27/2009 3:31 AM
doxilia
Score: 136
Status: offline
Elias,
absolutely fantastic! Bar none, this is the best scratch project I've ever seen. From inception to completion a real tour de force.
Bravo!
Now, you'll just have to find a way to allow the rest of us to enjoy the fruits of your considerable labour... any plans to kit the model?
David.
Hide Signatures
       Post #: 187
RE: NEUTRINO - NEW F3A PROJECT FROM GREECE - 5/27/2009 5:26 AM
dhal22
Score: 138
Status: offline
any wood kit designers have any comments?  not trying to be a smart a^%,  just asking.
David
Hide Signatures
(in reply to doxilia)
       Post #: 188
RE: NEUTRINO - NEW F3A PROJECT FROM GREECE - 5/27/2009 5:27 AM
flyintexan
Score: 100
Status: offline
Great job from start to finish.  Congrats and thanks for sharing with us all.
-mark
NSRCA 3656
www.NSRCA.us
Hide Signatures
       Post #: 189
RE: NEUTRINO - NEW F3A PROJECT FROM GREECE - 5/27/2009 6:13 AM
shannah
Score: 105
Status: offline
Looks Great.  Where's the T-Can?
Team BJCraft
Hide Signatures
(in reply to flyintexan)
       Post #: 190
rcpattern
Score: 100
Status: offline
Great job..i love the scheme...
Congrats.
Arch
Team Futaba, Castle Creations, Tech Aero Designs, Hacker Motors, F3A Unlimited, Team BJ Craft,
Hide Signatures
       Post #: 191
RE: NEUTRINO - NEW F3A PROJECT FROM GREECE - 5/27/2009 10:38 AM
Jeff Boyd 2
Score: 100
Status: offline
WOW . . VERY nice ! !
Cheers, JB
Hide Signatures
       Post #: 192
RE: NEUTRINO - NEW F3A PROJECT FROM GREECE - 5/27/2009 11:36 AM
jclaude
Score: 100
Status: offline
Hi Elias,
This is a very nice paint scheme.
I hope that the flying qualities are up to your expectations.
We now await your report of flight tests.
Anyway, thank you for sharing this experience with us.
Best Regards,
JClaude
Hide Signatures
(in reply to Jeff Boyd 2)
       Post #: 193
RE: NEUTRINO - NEW F3A PROJECT FROM GREECE - 5/27/2009 5:26 PM
tuny
Score: 100
Status: offline
FANTASTIC!!! BEAUTIFULL JOB!!!
Congratulations!
TUNY
Hide Signatures
(in reply to jclaude)
       Post #: 194
RE: NEUTRINO - NEW F3A PROJECT FROM GREECE - 5/27/2009 6:01 PM
guille2006
Score: 109
Status: offline
Hey Elias: your work is hard to improve!!!!! SUCH A PLANE IN LESS THAN 5 MONTHS!!!! EXCELENT!!!!
Exocet Engineering & Design.
Hide Signatures
(in reply to tuny)
       Post #: 195
RE: NEUTRINO - NEW F3A PROJECT FROM GREECE - 5/27/2009 7:53 PM
Elias Sopeoglou
Score: 100
Status: offline
Thank you all for the nice comments !
Sorry but there are no plans for kiting the plane ,I would never find the time ,someone else would have to do it and it would need a very reliable and good manufacturer for me to trust my moulds !
The T-can ,i had some rolling issues ,kind of barrel like ,they completely dissapeared when i removed the can ,i bet it has to do with incidence ,I think I´ll play with that after the WC .now the rolls are axial and precise ,I really love how this plane handles ,knife has no coupling at all and snaps are crisp and clean (I like the violent ones not the lazy ones).There is a slight pitch to the canopy on uplines and downlines ,there is absolutely no yaw in uplines regardless of speed ,right thrust is right on and it is only about  1deg ! Plane can fly pretty fast if needed in high wind conditions and I´m about to recieve my competition jeti90(currently using the simple) for setting my brake on downlines.
will be posting shots of inside setup soon..
Thanks egain for all the nice comments !
reguards
Elias
Hide Signatures
(in reply to guille2006)
       Post #: 196
RE: NEUTRINO - NEW F3A PROJECT FROM GREECE - 5/27/2009 11:48 PM
highfly3D
Score: 100
Status: offline
Hi Elias,This is one of the coolest F3A build i have seen, please do post some videos of the plane i am sure many of them would love to see it..Regards,Highfly
Hide Signatures
       Post #: 197
RE: NEUTRINO - NEW F3A PROJECT FROM GREECE - 5/28/2009 1:13 AM
Elias Sopeoglou
Score: 100
Status: offline
Will do that first chance..
Elias
Hide Signatures
       Post #: 198
RE: NEUTRINO - NEW F3A PROJECT FROM GREECE - 5/28/2009 9:35 AM
MAVROS
Score: 100
Last Login: 4/18/2013
Status: offline
Yassou Elias,
PARRA POLY OREO FILLEH.
Wish all the best for the World Championships
regards
MAVROS
AUSTRALIA
Hide Signatures
       Post #: 199
RE: NEUTRINO - NEW F3A PROJECT FROM GREECE - 5/28/2009 5:03 PM
MHester
Score: 100
Last Login: 6/28/2011
Status: offline
quote:
ORIGINAL: dhal22
Like?
I'm with everybody else, I think it's some awesome work. It's different. What I DO really like is the nomex construction. There are only a handful of people that can do nomex and do it right. When it's done properly it's as good as it gets for composite fuses. The stiffness approaches wood planes. The key is the weight. Looks like Elias nailed it.
I love the color scheme too!
-Mike
Thanks to my sponsors over the years!
Hide Signatures
(in reply to dhal22)
       Post #: 200
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.422RCU1
