Wood for a small electric airboat?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> RC Airboats >> Wood for a small electric airboat?
Page: [1]
Login
Wood for a small electric airboat? - 1/23/2009 8:59 PM
500 lb. koolaid man
Score: 105
Last Login: 5/24/2012
Status: offline
I'm thinking about building a brushless airboat about the size of a Dumas Lil Swamp Buggy. I'm planning on scaling down the Gator 24" plans. Would regular Tower Hobbies plywood (not birch like Midwest brand but much cheaper) work alright? And what's needed, just 1/16" (with the exception of a 1/8" motor mount), maybe 1/16" and 1/8" (1/8" is 5 ply and 1/16" is 1 ply on tower in case that matters)?
Thanks.
< Message edited by 500 lb. koolaid man -- 1/23/2009 9:00 PM >
_____________________________
"A penny saved is a penny earned" -Benjamin Franklin
Hide Signatures
       Post #: 1
RE: Wood for a small electric airboat? - 1/23/2009 11:54 PM
Rowboat
Score: 100
Last Login: 12/11/2012
Status: offline
I don't know about towers ply .The ply from the hobbies shop should be ok to use, it would be a good quality wood. Have you considered using balsa wood? It is much lighter than ply. I have built lots of balsa boats with nitro engines and one electric boat. I am not sure how cheap where you are. But why not give it a go.
Boating is not a matter of life or deth, It is more important than that !!
Hide Signatures
(in reply to 500 lb. koolaid man)
       Post #: 2
RE: Wood for a small electric airboat? - 1/26/2009 4:35 PM
mr. ilikehelp
Score: 100
Last Login: 3/21/2010
Status: offline
better than balsa use depron. its cheaper stronger and lighter than balsa
Hide Signatures
(in reply to Rowboat)
       Post #: 3
RE: Wood for a small electric airboat? - 1/28/2009 4:43 AM
SlashBasher
Score: 110
Last Login: 5/21/2013
Status: offline
I used pink insulation foam and sanded it to shape. This is my first airboat but I plan on moving up. this is the cheapest easiest way IMO. Its fast to!
Click to see fullsize image.
Click for fullsize
4s Slash- mamba max- turnigy 36-57 2600kv- flm adpters and 1/8 buggy badlands- tons of rpm and aluminum upgrades
Hide Signatures
(in reply to mr. ilikehelp)
       Post #: 4
RE: Wood for a small electric airboat? - 1/28/2009 6:48 AM
500 lb. koolaid man
Score: 105
Status: offline
You have the exact motor / esc that I'm going to use, Hobbycity
Thanks for posting that picture. She looks nice What prop size are you using?
I'll consider pink foam. Either that or balsa, not sure which yet. Balsa just seems much more "solid" to me.
I wonder what thickness I will need if I choose balsa, 1/16 for skin, 1/8 for motor stand, and which for the rest?
Thanks.
Hide Signatures
(in reply to SlashBasher)
       Post #: 5
RE: Wood for a small electric airboat? - 1/28/2009 9:26 AM
Rowboat
Score: 100
Status: offline
I would 1/8 for the skin, the next size up for the engine stand, or use 1/8 ply. Remember that the hull should be sealed with an epoxy coat. The balsa can dint easily it also can be repaired cheap and easily. Use 1/8 for the framing as well. The boat should be sealed inside and out. This will stop any twisting in the hull due to moisture.
If you had the money you could apply one layer of 3oz fiber cloth to the outside of the hull this makes for a very strong hull and it is still a light weight boat.
If you use pink foam it is easer to shape and you can glass over the foam as well. I just prefer working with balsa. I can build in the lounge room while watching TV, I can't sand foam.(The wife would kill me)
Hide Signatures
       Post #: 6
RE: Wood for a small electric airboat? - 1/28/2009 4:49 PM
SlashBasher
Score: 110
Status: offline
quote:
ORIGINAL: 500 lb. koolaid man
Thanks.
Thanks! Im using an 8x3.8 prop on a 2s lipo. I havent tried it on water yet but its really fun on ice!
Hide Signatures
       Post #: 7
RE: Wood for a small electric airboat? - 1/29/2009 6:19 AM
500 lb. koolaid man
Score: 105
Status: offline
Thanks guys. I have all the info I need. Time is now my only enemy College and my signature
Thanks again.
< Message edited by 500 lb. koolaid man -- 1/29/2009 6:20 AM >
Hide Signatures
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.297RCU1
