RE: Saito FG-20 or 21    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: Saito FG-20 or 21
Page: <<   < prev  54 55 56 57 58 59 60 61 [62] 63   next >   >>
Login
RE: Saito FG-20 or 21 - 11/21/2012 5:29 AM
w8ye
Score: 318
Last Login: 5/20/2013
Status: offline
The FG-21 has bronze valve seats and a different connecting rod as well as RCEXL ignition.
The carb was changed before the FG-21 came out.
_____________________________
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to alan0899)
       Post #: 1526
RE: Saito FG-20 or 21 - 11/21/2012 1:37 PM
Garthwood
Score: 100
Last Login: 5/12/2013
Status: offline
quote:
ORIGINAL: alan0899
G'day Garthwood,
I think maybe HH has it wrong, If both carbys are the same on the FG20 & FG21, why does Saito supply a new carby for the older FG20.
The carbys are different, & Saito changed a few things inside as well.
I love my FG21.
Cheers
G'day to you too mate ! I'm going to call HH in the next few days and get to the bottom of this. I bought the FG20 in 2011 at the Toledo show, but not sure if the carb is the newer version.
My question is; Is it possible to install in the FG20 the carb and the newer Electronic ignition of the FG21 ?
HH never answered all my questions so i need to give them a buzz.
Cheers
WACO Brotherhood # 87
Carl Goldberg Ultimate 10-300 Brotherhood # 61
Hide Signatures
       Post #: 1527
RE: Saito FG-20 or 21 - 11/21/2012 8:39 PM
alan0899
Score: 100
Status: offline
G'day Mate,
YES, the FG21 carby is a direct replacement for the carby on the FG20.
Saito found a few problems with the throttle rotor hole size in the FG20 carby, so they supplied new carby's to fix the tuning problems.
They also made a few changes inside the engine & released it as the FG21, & put a new RCEXL Ignition module, with a much smaller sensor.
The new ignition is not required to get the engine running sweetly, it's just that the new sensor is much smaller.
Cheers
Good Flyin Mate. Keep Thyne Airspeed up, lest the ground arise & smite thee,
Allan.
Hide Signatures
(in reply to Garthwood)
       Post #: 1528
RE: Saito FG-20 or 21 - 11/21/2012 10:02 PM
w8ye
Score: 318
Status: offline
quote:
ORIGINAL: Garthwood
quote:
ORIGINAL: alan0899
G'day Garthwood,
I love my FG21.
Cheers
Cheers
Your carb should already be the new one
Original AMA #31261
Hide Signatures
       Post #: 1529
RE: Saito FG-20 or 21 - 11/21/2012 10:38 PM
Garthwood
Score: 100
Status: offline
Thank you Allan and W8YE.
Charles.
Hide Signatures
       Post #: 1530
RE: Saito FG-20 or 21 - 11/29/2012 1:21 PM
Timbers
Score: 105
Last Login: 5/15/2013
Status: offline
Does anyone on this post have any significant time on the FG-21, in the air?
I've been running the FG-20 since it came out in 2009. My big problems were the ignition system and burning out exhaust valve seats. Thanks to Horizon for always coming through and fixing the problems for me (even though it costs me $12 to ship it back each time)
Anyways I have a new FG-21 to try now, haven't mounted it yet. I'm wondering if I should just bail at this point, or if I should give it a shot. I could sell the engine and buy a DLE-20 and probably just fly all Summer long without issues.
Should I give the FG-21 a shot, hoping that the new pressed in valve seats, redesigned conrod, ignition system and carb will make this a solid engine?
Hide Signatures
       Post #: 1531
RE: Saito FG-20 or 21 - 11/29/2012 7:08 PM
w8ye
Score: 318
Status: offline
You need to give it a workout so you can tell us how it compares with the FG-20? There's no better qualified person to do this.
Original AMA #31261
Hide Signatures
(in reply to Timbers)
       Post #: 1532
RE: Saito FG-20 or 21 - 12/9/2012 3:21 PM
profmb
Score: 105
Last Login: 5/13/2013
Status: offline
Hi all,
I have been reading this thread and it mirrors my experiences with both the FG20/21 where I have been unable to get either to run really well, and just get frustrated with the unpredictability of it/ them. My FG20 had 2 new carbs and 3 ignition units, all replaced under warranty. My experience with the FG21 has been largely the same - it will run fine on the test bench but up in the air (no cowl) it is really rough and usually ends of quitting. No matter what I seem to do with either the LS of the HS it makes no difference. Indeed on the ground, therre are times when no amount of adjustment of the carb changes the revs one iota. I had thought that it was dirt in the carb perhaps - but no this is clean. After countless efforts and so may dead sticks I gave up and bought a Mintor 22cc - so easy in comparison!
More recently one of my FG30's stopped working - I found that the ignition unit had failed ..I then experimented with a RCEXL unit and could not get this to work at all. OK so the RCEXL is a hall sensor whereas the Saito unit worked as an induction unit with auto advance. But no matter where I put the sensor I did not get the engine to fire properly - the best being a gentle phutt phutt. After two hours of little result for my efforts I gave up. In that time I had tested the spark plug out of the engine so I could see the spark etc etc. But what really finished me off was trying to get the spark plug back out of the cap - bad enough when the plug is in the cylinder, because with the Saito cooling finsso close to the cap it is soo hard to twist and turn. Perhaps my technique is all wrong???
Anyway I have now got it running sweetly using Runtronic unit - so easy to get the cap on and off for a start! The nice thing about the Runtronic is that it is much cheaper and smaller than the Saito and has automatic advance. So far so good.
One day I may have another go at the FG21, but for the moment it is back in its box...
Hide Signatures
(in reply to w8ye)
       Post #: 1533
RE: Saito FG-20 or 21 - 12/9/2012 5:04 PM
Saillfish
Score: 100
Last Login: 5/3/2013
Status: offline
I started this post and come back to it from time to time just to laugh and wonder why you guys are even messing with this engine. I have installed two dle 20cc engines in my aircrafts and the oddest thing has happen. They work. You just start them and fly. They dont need any tuning once set and the never die in the air or anywhere else. Can you all believe this. : )
Hide Signatures
(in reply to profmb)
       Post #: 1534
RE: Saito FG-20 or 21 - 12/9/2012 7:15 PM
Garthwood
Score: 100
Status: offline
quote:
ORIGINAL: Saillfish
I come to this thread because it is about the SAITO FG20 and not the DLE20.
Hide Signatures
(in reply to Saillfish)
       Post #: 1535
RE: Saito FG-20 or 21 - 12/9/2012 7:36 PM
Saillfish
Score: 100
Status: offline
quote:
ORIGINAL: Garthwood
quote:
ORIGINAL: Saillfish
Yeah I know. I offered more valuable advise on the saito FG 20 and 21. Did you not get it
Hide Signatures
       Post #: 1536
RE: Saito FG-20 or 21 - 12/9/2012 11:42 PM
Garthwood
Score: 100
Status: offline
quote:
ORIGINAL: Saillfish
quote:
ORIGINAL: Garthwood
quote:
ORIGINAL: Saillfish
Not sure. Do you remember the page ?
Hide Signatures
       Post #: 1537
RE: Saito FG-20 or 21 - 12/10/2012 12:10 AM
bulldog319
Score: 100
Last Login: 2/23/2013
Status: offline
The valuable information he posted was that there are far better alternatives than this engine.
Pretty relevant in this thread as people that are interested in the engine are likely to come here looking for information.
I am always amazed at the vehement defenders of this thing.
There are a lot of people just like me that have a $500 door stop sitting around in their shop.
I only stay subscribed to this thread to see who comes up with the next fix for it and if it's worth throwing another penny at this thing.
The engine is worthless to me other than as a reminder to always do my research before I buy.
Hide Signatures
       Post #: 1538
RE: Saito FG-20 or 21 - 12/10/2012 12:33 AM
CH Ignitions
Score: 420
Last Login: 5/6/2013
Status: offline
Hi Guys,
Nice to se some names I...grew up with Saillfish, Timbers and W8YE, that I remember from back in 2009 on the FG20 thread.
My FG20 runed fine even thow was the first version, before the doted carb. But talking about how it can be improved we talk back then a lot of things,
replace the carb with WT-456-1, or Zama C1Q-P8 .I tried both and they are both direct replacements betwen them, the accelerator pump on them makes
a nice feature.
I used this carbs on FA120 , Fa120S,FA125, FA150, FA180, FG 20, and FG30.
If any of you tied of this engine FG21, and is willing to send it in to me to have a look at it and see what can be done...I will be willing to give it a try.
I think my stuff for FG20 will also work on the FG21 ...but I have to try it and good part about it is that it can be reverted back to original by replacing the intake mnfl.with a new one from HH or other place and
no one will know the difference.
Here is a FG30 from Norway.
Adrian
www.ch-ignitions.com
Hide Signatures
(in reply to bulldog319)
       Post #: 1539
RE: Saito FG-20 or 21 - 12/10/2012 1:49 AM
MercerAUST
Score: 120
Last Login: 2/14/2013
Status: offline
I've been running the FG-14 (100hrs) and FG-20 (50hrs) with no problems. I had some initial problems sourcing a part for the FG-14 after a crash and with fueling for the FG-20 when I first set it up. I've also got the RCGF 2-stroke 20cc and 26cc, but don't like the noise or poor economy much. I'll continue to upgrade to 4-stroke petrol whenever I can afford a new motor. If you are not into 2 strokes, you don't have much choice in the petrol range.
Different strokes for different folks, I guess.  I've tuned a few of these Saitos now for people who gave up on them. It takes patience, that's for sure.
Hide Signatures
(in reply to CH Ignitions)
       Post #: 1540
RE: Saito FG-20 or 21 - 1/16/2013 8:26 AM
AeroFinn
Score: 100
Status: online
quote:
ORIGINAL: CH Ignitions
Hi Guys,
a nice feature.
Adrian
Hi Adrian
Thanks for the video.
I'v seen two of your videos on FG-20 running with C&H ignition and Zama C1Q-P8 carb (or walbro WT-456-1) The engine idle seems to idle & accelerate perfect but the top rpm seems to be somewhat lower than with the stock carb (8100-8300 vs. 8500-8800)
Have you tried, by ever chance to blend the bore of the Zama Carb to the intake manifold diameter? Could the difference in Zama carb venturi bore and in the intake manifold be the cause foe reduced max rpm vs. stock carb?
Btw I'v read lots of very positive customer testimonials of your service. Congrats!
I'm also thinking of converting my FA-125a to CDI and then run it on glow or gas (don't know yet)
Hide Signatures
       Post #: 1541
RE: Saito FG-20 or 21 - 1/16/2013 7:16 PM
Arruda
Score: 105
Status: offline
Hi guys, I’ll report my story with the FG-21.
After my previous (and positive) experience with the FG-14A, I decided to buy this engine to put on a ZLIN 50 (Seagull Models). The engine is an excellent mach for this plane.
I didn’t follow the manual’s recommendation to run it on the bench for, at least, 40 minutes.It went straight to the plane and I run it for just 20 minutes at 3000 rpm on the ground (I injected some oil in the crankcase first).
After this time I leaned a little the LS needle and went flying. The HS needle was set a quarter turn on the rich side and I flew the plane in this condition for more or less one hour.
After this first hour I leaned a little more the LS needle and set the HS needle to maximum power.
After two hours of flying I decided it was time to set the LS needle correct. I leaned it until the engine quits when I move the throttle fast from idle to maximum opening (this happens on the ground, not in the air). I think I now have the engine set.
It still misses a beat when going without load at less than 4000 rpm (going down, for instance), but I’m afraid to lean further the LS needle. I think one just have to accept this characteristic of the engine.
For the first three flights I used MOTUL 800 motorcycle oil (a French brand), then I moved to Morgan Fuel Cool Blue because I read in one of these forums that this oil is the same as the recommended Evolution oil.
I noticed one curious thing:  when using the Motul, the plane was full of dark spots of oil. When I moved to Cool Blue, the oil spots were clear. I don’t know yet if this is a good thing or a bad one. It could be that this oil is more resistant to burning – a good thing. Or it could be that it is not cleaning the engine as it should – a bad thing. Only time will tell.
Hide Signatures
(in reply to AeroFinn)
       Post #: 1542
RE: Saito FG-20 or 21 - 1/16/2013 7:49 PM  1 votes
profmb
Score: 105
Status: offline
I have given a summary of my experiences earlier in this thread. However, the best that I can say of these engines that they are erratic in their performance. One day everything works fine and then with nothing different in the set up they refuse to run. As to choices - well here in the UK we have a great bunch of guys at Weston UK - they design, build and tune engines. Recently they converted a Magnum 1.80 to petrol for me using a Runtronic induction ignition and a regulator pumped from the tuned exhaust to pressurise the fuel tank via a shroeder valve. Works a treat. So there are choices albeit not off the shelf so to speak.
I have two FG30's - one of which runs sooo sweetly and the other had been a pig. Recently we decided that the carb was simply not doing its job - so I have used one of Westons' glow R/C carbs. When the ignition unit packed up I also hooked up a Runtronic ignition. So my experience is that ignition units and carb from Saito are just too unreliable. Incidentally I also have an FG57 and again that runs faultlessly - but again I have read threads where others have such a lot of hassle with them one wonders if they are made by the same company!
My FG21 is currently sitting in a draw - and I am thinking that I may well do to it what I did with my FG30....I will post some pics of the FG30 set up later...
Cheers
Hide Signatures
(in reply to Arruda)
       Post #: 1543
RE: Saito FG-20 or 21 - 2/25/2013 12:52 AM
P51 Lover
Score: 100
Last Login: 4/18/2013
Status: offline
Where is the dot on the carb and what does it look like. A picture would help. I have a Fg20 that I bought in aug/2009 and have had problems getting it to run. It has been to HH three times and still does not run right! Does anyone know what they did different when it FG21 replaced the FG20? Bill
Hide Signatures
(in reply to gibatta)
       Post #: 1544
RE: Saito FG-20 or 21 - 2/25/2013 2:42 AM
w8ye
Score: 318
Status: offline
The FG-21's have a RCEXL type ignition and bronze valve seats. That is the only difference in them.
Original AMA #31261
Hide Signatures
(in reply to P51 Lover)
       Post #: 1545
RE: Saito FG-20 or 21 - 2/27/2013 1:39 PM
P51 Lover
Score: 100
Status: offline
I ran my FG-20 on the bench yesterday to see if I could make any determination as to why the engine runs poorly and often quits, especially when I advance the throttle from low to high. The first test, I had the fuel tank mounted with the engine and when the engine was running rough,I noticed there were air bubbles in the line. When the air bubbles got to the carb, bam, she either died or cut out bad. No, this was brand new fuel line, so there are not holes in the fuel lines.
I removed the fuel tank and held in my hand while the engine was running. This stopped the bubbles and the engine ran okay, not great, but okay. Evidently the excessive vibration produced by the Saito FG-20 and shaking the tank causes air bubbles to be form in the fuel line. I noticed this same situation when the engine was mounted on the Hangar 9 Funtana 125.
In talking with Horizon Hobby, they suggested trying a different clunk and sent me two to try. I used one of them for this test and it did not seem to help.
The engine appears to run better in the open than it does in the airframe. WHen installed in the Funtana 125, there is not much clearance between the hole in the back of the carb and the firewall, which may be contributing to the problem of poor running and dying when in the air. I have enlarged the area behind the carb and drill completely through the firewall in an attempt to help. I have added substantial foam around the fuel tank in the airframe as well. I plan to test run the engine without the cowl first and them with the cowl on the ground soon.
If it helps, I will report back.
Hide Signatures
(in reply to w8ye)
       Post #: 1546
RE: Saito FG-20 or 21 - 2/27/2013 6:11 PM
w8ye
Score: 318
Status: offline
I like the felt clunks
Original AMA #31261
Hide Signatures
       Post #: 1547
RE: Saito FG-20 or 21 - 3/10/2013 7:56 PM
Timbers
Score: 105
Status: offline
Selling my CH Ignition system that I was using on the FG-20. It cured the problems I had with the stock Saito ignition system. I'm sure Saito worked out the bugs with the new FG-21, but if one of you still has a finicky you can try my ignition system. Works great!
http://www.rcuniverse.com/market/item.cfm?itemID=905203
Here is the listing for it. Thanks.
Hide Signatures
(in reply to togatoga)
       Post #: 1548
RE: Saito FG-20 or 21 - 4/11/2013 5:46 PM
jamesroutledge
Score: 100
Last Login: 5/18/2013
Status: offline
I want to chime in here with a good word for Bill.
A while ago I got a crash damaged FG20 for a good price. The needle valve was smashed off the carb.
I wondered if the FA125 needle valve assembly would work as a replacement, because you cannot buy this assembly separately for the FG carb.
So I PM'ed Bill about this. He replied that it could not be done as the NV's are different, and then sent me a whole carb , FREE.
I did not even buy the engine from Horizon and that's the sort of service I get.
I am truly impressed.
Thanks Bill
SAMAA 5409
Club Saito Member #766
Hide Signatures
       Post #: 1549
RE: Saito FG-20 or 21 - 5/5/2013 6:10 PM
labebe
Score: 100
Last Login: 5/9/2013
Status: offline
Hi to all of you, I am planning to install my new saito fg-20 on a Great Planes WACO ARF, the manual recommends a OS 120 4 stroke engine. My question is, Does any body knows how many HP it can developement?? Does the Saito FG 20 has less power tan the same 4 stroke glow engine displacement???
I am concern about it, I don´t want to be underpower on my WACO,
Hide Signatures
       Post #: 1550
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: Saito FG-20 or 21
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.672RCU1
