RE: Official HPI Baja 5 Thread (5T, 5B, 5B SS)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Giant Scale Cars >> RE: Official HPI Baja 5 Thread (5T, 5B, 5B SS)
Page: <<   < prev  1 2 [3] 4   next >   >>
Login
RE: Official HPI Baja 5 Thread (5T, 5B, 5B SS) - 2/5/2009 5:46 PM
monsterbrad
Score: 100
Last Login: 4/4/2013
Status: offline
This is all well and good but there is the noise factor also.
So the DDM side pipe is a good all around pipe but how is it with a silencer on it?
if you can even get one on it
Hide Signatures
(in reply to bryan70546)
       Post #: 51
RE: Official HPI Baja 5 Thread (5T, 5B, 5B SS) - 2/5/2009 5:55 PM
bajamaniac69
Score: 100
Last Login: 3/26/2013
Status: offline
monsterbrad....
check out youtube type in side dominator.....its pretty quiet..................
j
Hide Signatures
(in reply to monsterbrad)
       Post #: 52
RE: Official HPI Baja 5 Thread (5T, 5B, 5B SS) - 2/5/2009 8:57 PM
Foxy
Score: 2012
Last Login: 5/19/2013
Status: offline
quote:
ORIGINAL: monsterbrad
It has a built in silencer and is not available without.
It's not quiet, but it's not monstrously loud either. It's only disadvantage is weight.
< Message edited by Foxy -- 2/5/2009 8:59 PM >
_____________________________
IT`S A FAAAAAAAAKKKKKKKEEEEEEEEE!
Hide Signatures
       Post #: 53
RE: Official HPI Baja 5 Thread (5T, 5B, 5B SS) - 2/5/2009 10:16 PM
monsterbrad
Score: 100
Status: offline
How much louder is it then the stock can???
Hide Signatures
(in reply to Foxy)
       Post #: 54
RE: Official HPI Baja 5 Thread (5T, 5B, 5B SS) - 2/5/2009 10:50 PM
Dan H
Score: 100
Last Login: 5/7/2013
Status: offline
http://www.hpiracing.com/kitinfo/10629/
Check out the new Baja v2.0 RTR
Hide Signatures
       Post #: 55
RE: Official HPI Baja 5 Thread (5T, 5B, 5B SS) - 2/6/2009 5:36 AM
46u
Score: 136
Last Login: 7/13/2012
Status: offline
Both the side and rear Dominator are heavy as the are made of steel. I read and article a while back that said steel is the best materiel to make a 2 stroke pipe out of the only problem is weight. Unfortunately the article is no longer available.
Rebel Racing
Sponsored by Killer RC maker of great kill switches and more!
Hide Signatures
(in reply to Dan H)
       Post #: 56
RE: Official HPI Baja 5 Thread (5T, 5B, 5B SS) - 2/6/2009 5:51 AM
46u
Score: 136
Status: offline
I have a question about the Mielke Side Pipe. I have read there are some problems with the coupling between the header and the pipe. Is this true and if so what is the recommend fix?
Rebel Racing
Hide Signatures
(in reply to 46u)
       Post #: 57
RE: Official HPI Baja 5 Thread (5T, 5B, 5B SS) - 2/6/2009 6:55 PM
Foxy
Score: 2012
Status: offline
Yes, the recommendation is to use a decent automotive pipe as a coupler and fat automotive jubilee clips. It's just a piece of thin plastic the stock one, and melts after a few hard runs. Simple fix. I got some decent piping the right diameter from a local shop and did all my pipes with it.
Hide Signatures
(in reply to 46u)
       Post #: 58
RE: Official HPI Baja 5 Thread (5T, 5B, 5B SS) - 2/6/2009 6:57 PM
Foxy
Score: 2012
Status: offline
It's about the same as the stock can, maybe a touch louder, but it's significantly quieter than the HPI 'tuned' pipe and the X-cans. The mielke is the only truly quiet pipe unless you heavily silence the others, which means you'll lose some power. Mielke doesn't even have an integrated silencer, must work by magic. lol.
Hide Signatures
       Post #: 59
RE: Official HPI Baja 5 Thread (5T, 5B, 5B SS) - 2/6/2009 11:33 PM
xxSLiMxx
Score: 105
Last Login: 9/9/2010
Status: offline
Here is a few pictures of my baby!
Hide Signatures
(in reply to Foxy)
       Post #: 60
RE: Official HPI Baja 5 Thread (5T, 5B, 5B SS) - 2/7/2009 12:10 AM
46u
Score: 136
Status: offline
It will be a while before I have mine running as I am doing many up grades before I ever start it. Besides the below list I all so got a piston stop and flywheel, clutch puller. More coming soon.
HPI Baja 5B SS Kit
Team Associated
DS1015 servo
Turtle Racing
Complete Clutch System (Orange)
Turtle Racing
HD Tranny Plate (Orange)
Threshold
Shock Umbrella Seals with installation tool
Turtle Racing
Heavy Duty Front Chassis Brace
HPI
Front tire molded foams
washers for e clip conversion
Fast Eddie
Wheel Shim Kit
Scorpion Chassis Brace Satin
Pro-Match 6v 4200mAh Hump Receiver Battery
FF Front/Side Windows Smoked
Rebel Racing
Hide Signatures
(in reply to xxSLiMxx)
       Post #: 61
RE: Official HPI Baja 5 Thread (5T, 5B, 5B SS) - 3/15/2009 12:36 AM
landeck
Score: 137
Status: offline
By chance, do you know if the HPI piston stopper is compatible with glow plug engines, i.e. has the same threads as a standard glow plug?
Bruce
Bruce L. AMA# 54227
Ultra Sport Brotherhood #15
Hide Signatures
(in reply to 46u)
       Post #: 62
RE: Official HPI Baja 5 Thread (5T, 5B, 5B SS) - 3/15/2009 1:10 AM
46u
Score: 136
Status: offline
quote:
ORIGINAL: landeck
Bruce
No way the spark plug is much bigger then any glow plug engine I have. They do make one for glow plug engines.
I am ALL MOST done with phase 1 after having my 5B SS for 2 months. Putting the finishing touches on it and if only the weather would get better I will be running it for the first time. Just installed the RX and PB Kill Switch!
< Message edited by 46u -- 3/15/2009 1:13 AM >
Rebel Racing
Hide Signatures
(in reply to landeck)
       Post #: 63
RE: Official HPI Baja 5 Thread (5T, 5B, 5B SS) - 3/15/2009 1:18 AM
landeck
Score: 137
Status: offline
Thanks for the quick reply.
Bruce
Bruce L. AMA# 54227
Hide Signatures
(in reply to 46u)
       Post #: 64
RE: Official HPI Baja 5 Thread (5T, 5B, 5B SS) - 3/15/2009 1:58 AM
46u
Score: 136
Status: offline
landeck See you are all so in Georgia, I live in Macon. Do you go to any of the RC race tracks in Georgia
Rebel Racing
Hide Signatures
       Post #: 65
RE: Official HPI Baja 5 Thread (5T, 5B, 5B SS) - 3/15/2009 5:13 PM
landeck
Score: 137
Status: offline
46u, I have been flying RC aircraft for 36 years and do not run land vehicles. I got here due to a search for a good piston stopper for glow engines. Sandy Springs is between Atlanta and Roswell.
Bruce
Bruce L. AMA# 54227
Hide Signatures
(in reply to 46u)
       Post #: 66
RE: Official HPI Baja 5 Thread (5T, 5B, 5B SS) - 3/16/2009 6:07 AM
46u
Score: 136
Status: offline
Do you know Pecan Patch (Marko) near Griffin? He does aircraft as well as land vehicles. He has a small landing strip in his back yard for ultra lights and small plains as well as a off road track.
< Message edited by 46u -- 3/16/2009 6:08 AM >
Rebel Racing
Hide Signatures
       Post #: 67
RE: Official HPI Baja 5 Thread (5T, 5B, 5B SS) - 3/16/2009 8:39 AM
blackdogafd
Score: 100
Last Login: 3/21/2013
Status: offline
hey guys just wanted to come on and i am now a proud owner of a new hpi baja 5b SS!!!!! i love this thing! i love being able to put it together from stratch makes really appreciate it better...but anyway, this is my first 1/5 scale car ive always the nitros and love um and still have them....but ive been wanted a 5b ever since i they came out....but the only big beef i have is i wish the front steering turnbuckles were a little tougher! ive busted 2 so far and ive only ran 3 full tanks thru it...i did see however that largescalerc.com has the stainless steel turnbuckles and i was thinking about ordering them....just wanted to what you guys think
andy
here's a few pics of my SS
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by blackdogafd -- 3/16/2009 8:50 AM >
Team Evolution R/C Racing
~REDCAT RACING DEALER~
Hide Signatures
       Post #: 68
RE: Official HPI Baja 5 Thread (5T, 5B, 5B SS) - 3/17/2009 5:25 AM
wave waker
Score: 100
Last Login: 4/13/2013
Status: offline
Here's my New Look Fender 5t, it is a rubber window trim, insert it and glue..got pics of before and after.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
losi,warhead,dirtbike,,HTB360-2 ,HS Dumas,Nitro hammer, H&M Tunnnel,hydrofoamie,nomadio sensor,cat31,OB SW36
Hide Signatures
(in reply to blackdogafd)
       Post #: 69
RE: Official HPI Baja 5 Thread (5T, 5B, 5B SS) - 3/17/2009 5:32 PM
monsterbrad
Score: 100
Status: offline
Nice fender modd
After a few tanks through this thing I am still amazed how well this thing runs.
I can believe how good it is with the stock pipe on it.
It lacks a bit down low but has great mid range for a stock can.
Either way this thing is awesome and I wish I could set up the SS for sand cause I live right near Lake Erie and have Miles and Miles of beach!
Hide Signatures
(in reply to wave waker)
       Post #: 70
RE: Official HPI Baja 5 Thread (5T, 5B, 5B SS) - 1/1/2013 5:56 PM
coalminer
Score: 100
Last Login: 5/17/2013
Status: offline
Hi every one
I have been a member of this forum for a few years now and mainly posted on the Tamiya Nitrage thread.
I also own a HPI Baja 5b ss that I built from kit form 26cc. However not much of the original kit now survives on the car due to the vast amount of upgrades available. I have had the car for two years. Here are the latest pics of it in the Monster energy theme
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 71
RE: Official HPI Baja 5 Thread (5T, 5B, 5B SS) - 1/1/2013 7:41 PM
wan6176
Score: 105
Last Login: 3/17/2013
Status: offline
most of the buggy post are very clean and shiny
Everyday is learning day,no one can say he has learn enough.
Hide Signatures
(in reply to coalminer)
       Post #: 72
RE: Official HPI Baja 5 Thread (5T, 5B, 5B SS) - 1/2/2013 1:07 PM
coalminer
Score: 100
Status: offline
quote:
ORIGINAL: wan6176
It does get dirty at times ...honest. I strip and clean her up after a run.
Hide Signatures
(in reply to wan6176)
       Post #: 73
RE: Official HPI Baja 5 Thread (5T, 5B, 5B SS) - 2/11/2013 11:47 PM
nastyboys727
Score: 105
Last Login: 5/18/2013
Status: offline
wow only 3 pages this one went out fast
tru to this not new to this
Hide Signatures
       Post #: 74
RE: Official HPI Baja 5 Thread (5T, 5B, 5B SS) - 4/16/2013 1:52 AM
coalminer
Score: 100
Status: offline
quote:
ORIGINAL: nastyboys727
Yes I'm surprised too that this thread cut short early. The HPI Baja is still a very popular petrol powered 1/5 scale basher.
I have just dyed some wheels to match my RPM arms and fitted some new Hostile MX Nightmare tyres
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to nastyboys727)
       Post #: 75
Jump to:
Google
SITE MAP!   : :   FORUM RULES
4.422RCU1
