Reload this Page >
JR XP-7202 mode1 to mode 2 conversion
Old 01-28-2009, 05:39 PM
RCEEBUILDER
Default JR XP-7202 mode1 to mode 2 conversion
I have purchased a JR XP7202 Mode 1. I thought I can change the mode . Oh nooo this version can not be convertible . Firm upgrade is needed to convert this. No problem let's open the box.. there are 6 philips screws to be loosen.
ID:	1121963   Click image for larger version
Old 01-28-2009, 05:52 PM
RCEEBUILDER
Default RE: JR XP-7202 mode1 to mode 2 conversion
it looks so nice..New pictures coming soon .
Old 01-29-2009, 06:19 AM
422nd_novak1
Hello! iam curious if you did it well! could you changed it to mode 2? Some say that it need a firmware update to do it...I have the same radio and im up to change it too.
Regards
Novak
Old 01-29-2009, 05:55 PM
RCEEBUILDER
Conversion still in progress. After removal of sender pcb power pcb has been removed too. Then left and right stick holders have been removed . Now it is time to interchange throttle and elevator trim and pot . Before the installation we have to change the cables too.
ID:	1122607   Click image for larger version
ID:	1122608   Click image for larger version
ID:	1122609   Click image for larger version
Old 01-29-2009, 06:53 PM
RCEEBUILDER
Now it is time to assemble all the things again .
ID:	1122656   Click image for larger version
ID:	1122657   Click image for larger version
ID:	1122658   Click image for larger version
Old 02-01-2009, 04:43 AM
RCEEBUILDER
and finally
ID:	1124671   Click image for larger version
ID:	1124672   Click image for larger version
ID:	1124673   Click image for larger version
ID:	1124674   Click image for larger version
Old 02-21-2009, 06:49 PM
karambochomdls
Hi, i did it but the trims still working like before, ive changed the cables like You said but still the same. Radio Thr trim is now display elev trim and radio elev trim is display thr trim. How can i resolve this? how can i make it work changing all of the cables? Thanks
Old 02-28-2009, 06:12 PM
RCEEBUILDER
ORIGINAL: karambochomdls
Logically it is imposibble that the trims are working as before if you have really interchange the cables. Trims on the display will remain same as before. Never mind it.
Old 03-01-2009, 01:22 AM
tigrejohn
My Feedback: (7)
Have a silly question. Wouldn't it have been easier just to switch the rudder and aileron servo connections at the receiver?
Old 03-01-2009, 07:17 PM
RCEEBUILDER
Simply can not be done . Since this is sophisticated transmitter mix functions will not work. Moreover throttle and elevator trims work different .Throttle trim is only actived when the stick below the middle point .
Old 03-10-2009, 10:52 PM
caffinatedbear
PM Sent to RC builder to thank and to ask for clarification on wire cut change and resoldering.
Let me thank you publicly as well!
Caffinatedbear
Sleepy bears are grumpy!
Old 03-11-2009, 03:34 AM
RCEEBUILDER
Dear Caffinatedbear
As you can see below 4 cables should be cut and resoldered for each channel . In other words 4 cables for elevator , 4 cables for throttle.
Old 03-22-2009, 01:28 AM
caffinatedbear
Can you explain a bit more about the trim working after this conversion. You say that trims on the display will remain as before. so I just set up the trims properly looking at the mechanics of the heli and never mind the display? . Thanks
Old 03-26-2009, 02:33 AM
RCEEBUILDER
After conversion trims work properly. With the conversion , only the polarity of the trims and sticks have been changed. No problem at all If you do not take care the trims on the display.
Old 03-26-2009, 11:38 AM
karambochomdls
It Works OK! Thanks
Old 05-05-2009, 11:05 AM
dematel
I have a question for you. Those 4 wires do I have to solder throttle wires to the place where elevator wires where? Thanks Marcel
I did conversion from mode 2 to mode 1 :-)
Old 05-05-2009, 11:15 AM
dematel
I think I understand it know. I see the arrows now. Thanks
