sagacity
CA, USA Status: offline
Oh. by the way, Craig and all, I do have extensive photography of the build, which I'd happily zip up and PM to any one. Did I say this kit was a blast to build? Looks like they're going to discontinue it, so I'd scoop one up from Tower if you're interested. It might be one to buy and shelve until you're a good enough builder that no impending disaster will flap you. Some of the sheeting and most of the control surface work is really demanding, requiring as much 'think' time as 'do' time. On the other hand, the central airframe is done with some simple concepts that are very familiar, if not done to excess. Also scary are the buried linkages in the empennage, so build with confidence. Also, get a cowl from Stan's Fiber tech in Riversice, Ca. The ABS one isn't even good for an epoxy tray.;-) I will be flying this plane with the US41 as modified (see photo in giant engine forum), and will be reporting back. I may jump to the G62 later, especially since it bolts up without airframe mods, but Craig and I are in for the haul for the eartly flights. Craig says it'll fly scale, but well with the 41, and his name's on the plans. Hey Craig, did I mention I've never flown a warbird before? Rest assured, I'll be on a buddy cord! I'm rambling. At this rate I'll be at the field by noon! Unemployment... greg
