Balancing heavys    Gallery
Logged in as Guest
    Search This Thread
Printable Version
98 inch Caribou - ARF
Seller:  AUSTARSMODEL
Details:   $820.00   |  4/15/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Questions and Answers >> Balancing heavys
Page: [1]
Login
Balancing heavys - 2/7/2009 5:05 AM
YOADRIAN
Score: 100
Last Login: 5/18/2013
Status: offline
My planes are starting to get big and the cg machine no longer is any good because of the size. using fingers is ok but i would rather be right on with the big ones. Any ideas would be great or has someone come up with a better system.
Hide Signatures
       Post #: 1
RE: Balancing heavys - 2/7/2009 5:25 AM
exeter_acres
Score: 116
Last Login: 9/24/2012
Status: offline
Have the plane all assembled RTF minus fuel. Find a place where you can put the nose of the plane up against a wall. Take a level and prop up the tail wheel till the fuse is sitting level. Your gonna have to take the hatch off in most cases to set the level on.
Once the plane is sitting level, mark on the ground the two points where the main wheels are with masking tape and draw a line right where the wheels contact the tape. Then make a mark where the center of the tail wheel sits in the same manner. Its gonna be on whatever you propped the tail up with. (I use magazines)
Its also a good time to measure from the wall, how far back the recommended CG is. Save that number for later.
What you are looking for at this point is the distance to each wheel from the tip of the spinner. (which should be touching the wall at this point)
I use a long straightedge to get the distances
Lets say you come up with theses numbers:
LH main - 22 inches
RH main - 22 inches
Tail wheel - 70 inches
Now get a scale and place it under each wheel individually. You will have to re-adjust the other wheels to keep the plane sitting level. Add more magazines.
(If you have three scales you can get the weights at the same time but make sure the plane is level)
Remember to put the hatch on after you level the plane before you weigh each wheel. You gonna wind up with three weights. One for each wheel.
Lets say you come up with these numbers
LH main - 9lbs
RH main - 9lbs
tail wheel - 5lbs
Now its just a simple math problem to find where the CG sits right now on the plane.
Weight x ARM (distance) = Moment
22x9=198
22x9=198
70x5=350
Now add the total of all the moments and the total of all the weights.
Weights 9+9+5 = 23lbs
moments 198+198+350 = 746
Then divide the total moments by the total weights.
746 divided by 23 = 32.43
That number 32.43 is "in inches" how far back from the tip of the spinner to where the plane balances right now.
Compare that to the distance that you measured earlier to the recommended CG location.
If you are off one way or another adjust items then recalculate the weights. The distances (or ARM's) aren't going to change so you already have those numbers.
It may sound confusing and a lot of work but it really only takes about ten minutes to do it.
This is generally how full scale planes are balanced. You cant go lift one of them by your fingers or stick it on a CG machine.
Try it......
Originally written by Wayne Geffon
_____________________________
Extreme Flight RC tech support
IMAC SE Regional Director|IMAC Sequence Committee|IMAC Judging Instructor|Team Futaba
Hide Signatures
(in reply to YOADRIAN)
       Post #: 2
RE: Balancing heavys - 2/7/2009 6:50 AM
YOADRIAN
Score: 100
Status: offline
Not bad at all exeter so i just do what i learned in ap school. Funny I am rebuilding two 1947 cessna 140s i own and it did not even cross my mine to do it the same way lol. Now to look for some small scales. Thanks for the help guy.
Hide Signatures
(in reply to exeter_acres)
       Post #: 3
RE: Balancing heavys - 2/7/2009 8:19 AM
Crash Campbell
Score: 100
Last Login: 9/28/2012
Status: offline
Hi,
There are many ways to skin a cat or find the CofG. This device makes it easy.
http://home.mindspring.com/~the-plumber/Vanessa%20CG%20Machine.htm
Cheers,
Colin
Where there is a Will there are Relatives.Ultra Sport Brotherhood No:11 Ultimate 10-300 Brotherhood No:13
Hide Signatures
       Post #: 4
RE: Balancing heavys - 2/7/2009 8:59 AM
mimhoff
Score: 100
Last Login: 1/8/2012
Status: offline
Yoadrian Not sure what CG machine you are currently using (Great Planes maybe?) Sig is coming out with a Sig ProBalancer that appears to be quite a bit more robust than the GP CG machine. I have not seen one yet but I have one ordered fromTower for 39.99 scheduled to arrive early this month.
Mark
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 5
RE: Balancing heavys - 2/7/2009 2:20 PM
sowega flyer
Score: 105
Last Login: 3/30/2012
Status: offline
I use 2 wooden ladderback chairs from the kitchen. Nothing fancy, but uncomplicated and free. My wife supllies an extra pair of hands if needed.
"They won't grow if you plant 'em that deep..."
Hide Signatures
(in reply to mimhoff)
       Post #: 6
RE: Balancing heavys - 2/7/2009 8:42 PM
OldScaleGuy
Score: 120
Last Login: 5/19/2013
Status: offline
quote:
ORIGINAL: exeter_acres
LH main - 22 inches
RH main - 22 inches
LH main - 9lbs
RH main - 9lbs
tail wheel - 5lbs
22x9=198
22x9=198
70x5=350
Try it......
This sounds like a great method and no lifting the plane with cords or balancing it between two items which is much safer! Thanks for posting this, it was a lot of typing for you. I have copied it and saved it on my hard drive to balance the 50%'er that is finally getting close to finished.
Steve - Spitfire Brotherhood #144
Full size airplanes are real, our models are too.
Hide Signatures
       Post #: 7
RE: Balancing heavys - 2/15/2009 8:35 AM
Sawmill
Score: 100
Last Login: 2/15/2009
Status: offline
I have both of these balancers offered here... http://www.ezbalancer.com/ They cover all my balancing needs now and in the future. It's a tool. You get what you pay for...and in my opinion, a great investment.
Hide Signatures
(in reply to OldScaleGuy)
       Post #: 8
RE: Balancing heavys - 2/15/2009 3:44 PM
dhal22
Score: 138
Status: offline
quote:
ORIGINAL: Sawmill
the large one is pricey indeed but very cheap compared to some of the maiden crashes we see occasionally.
David
Hide Signatures
(in reply to Sawmill)
       Post #: 9
RE: Balancing heavys - 2/15/2009 4:53 PM
exeter_acres
Score: 116
Status: offline
quote:
ORIGINAL: OldScaleGuy
Method works great... as mentioned above...same as full scale...
I cannot take credit though.. was just a copy and paste for me!
Wayne Geffon (IMAC North Central regional director) posted it a while back....
Hide Signatures
       Post #: 10
RE: Balancing heavys - 2/22/2009 9:36 PM
KW_Counter
Score: 141
Status: offline
Does this technique work with tricycle gears?
KW_Counter
Hide Signatures
       Post #: 11
RE: Balancing heavys - 2/23/2009 12:57 AM
Roary m
Score: 107
Last Login: 5/17/2013
Status: offline
I have used the Jim archer(Vanessa) device for years; it works very well and is very easy to set up. You just need enough room to move around the plane.
Hide Signatures
(in reply to KW_Counter)
       Post #: 12
RE: Balancing heavys - 2/23/2009 5:32 AM
KW_Counter
Score: 141
Status: offline
Roary,
My question is wether the technique from Exeter Acres and Wayne Geffon works on planes with tricycle landing gears.
KW_Counter
Hide Signatures
(in reply to Roary m)
       Post #: 13
RE: Balancing heavys - 2/11/2012 8:16 AM
sebo
Score: 111
Status: online
Just reading through old threads and I found this on balancing........
Here's my technique.......similar to one of the above methods...
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 14
RE: Balancing heavys - 2/11/2012 9:51 AM
bogbeagle
Score: 148
Status: online
Kitchen scales and simple sums is how I do it.
With a bit of care, you can get a very accurate result.
Hide Signatures
(in reply to sebo)
       Post #: 15
RE: Balancing heavys - 2/11/2012 12:23 PM
sebo
Score: 111
Status: online
There sure are a lot of ways to do it, and they all achieve the same result!
Hide Signatures
(in reply to bogbeagle)
       Post #: 16
RE: Balancing heavys - 2/11/2012 1:03 PM
Luchnia
Score: 193
Status: offline
quote:
ORIGINAL: sebo
There sure are a lot of ways to do the same thing. I made my own Vanessa rig and also regular balancers. Very easy and don't have 30 bucks total in all of them! I have been building things all my life and no way I would invest 229 in a balance rig that I can build for pocket change. I have also seen some nice ones for large gassers using PVC pipe and metal with pipe foam and rubber.
One of the best balancers is a couple of people using their hands and sound judgement. I know some old codgers that balance with hands for the last 30+ years and you could not get a machine to do better. Their planes are pristinely balanced and fly smooth as glass! Which brings up another point. Checking with some of the older guys in the area that have flown for years and years and see what they do. One may find some more unique ideas and money saving tips.
To each his own and that is another great thing about the hobby. There are so many different ways to accomplish the same thing and this gives us great concepts. I am glad there are creative minds out there!
Hide Signatures
(in reply to sebo)
       Post #: 17
RE: Balancing heavys - 2/11/2012 3:40 PM
Lone Star Charles
Score: 105
Status: offline
In response to KW_Counter:  Yes, exeter's method will work on tricycle gear as well as tail-dragger.  Just be sure that you measure with the airplane leveled.
Hide Signatures
       Post #: 18
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.578RCU1
