Foxy
Score: 2012 Joined: 3/23/2005 Last Login: 5/25/2013 From: Kingston UK, but living in Athens, GREECE Status: offline
quote:
ORIGINAL: Lunchboxer I don't know if I'd quite agree Foxy.. because if someon is, as you said, frightened due to understeering (I assume that just means you are going into a turn and you can't turn the car as it is plowing, so you might hit something), that simply means he/she is going too fast (for the car / chassis / suspension / tires).. you back off the throttle and the line tightens.. it is not the fastest way around the turn / the track, but you don't swap end.. and spinning out means you have pretty much lost control and you most likely only can put both feet in (clutch / brake) and lock it up and hope you don't hit anything.. An inherently oversteering car is less confidence inspiring, because it takes quite a bit of commitment (to plant the rear, you need to be on the throttle, BUT, you might run out of room when tracking out (after the apex), if your line is not perfect). I am certainly not saying that it is ''bad'' (it is faster around the turn / track), but just saying that for most people, it is more dangerous as having the tail stepping out / spin usually scare most drivers. You are talking about driver levels -> a pro driver probably don't get frightened for either anyway as they understand how chassis react to their inputs. If the car understeers, they will know how to deal with it. If the car oversteers, they also know how to deal with it. And most likely, they will adjust the setup to suit their driving style once they found out the current setup of the car. quote:
ORIGINAL: Foxy I think we need to qualify driver levels. If my wife for example, had a high power rear wheel drive, she'd probably crash it if she tried to drive it fast. So in that sense, yes, understeer is 'safer'. However, for those who can drive well, understeer is very frightening, for the simple reason that there isn't much you can do about it. All you can do is stab the brake and hope the forward weight shift makes the front tires grip again. At least with oversteer, there are several subtle ways to respond to it. I've never ended up facing the wrong way in the S. It's nearly killed me a few times, but I never lost control of a spin. I can only speak for myself. understeer is the devil's work, oversteer is fun. So anyway, the deed is done, I drove the Type R to work this morning after taking delivery last night. I'm very impressed by the power, especially in second. In fact, it's quicker than the S in second (but not even remotely as quick in 1st and 3rd). The power is more usable, it takes normal gas (not the 100 octane the s2k demanded), it has usable rear seats and a big trunk. Torque steer is pretty bad though lol. I really love the car, It may not be as quick or as fun as the S, but it's more usable in more situations. I'll miss the soft top in the summer, but hey, you can't have it all. I'll post some pics possibly later after a wash n wax and a bit of T-cut on the headlights and for a scuff on the hood. A friend commented it looks like new.
_____________________________
So, you got a smartphone. You now have virtually unlimited access to the collective acquired knowledge of the entire human race in the palm of your hand, and you use it to... play Angry Birds while sitting on the toilet. Way to go!
Hide Signatures
