short range in stampede    Gallery
Logged in as Guest
    Search This Thread
Printable Version
SCT Combo - RTR
Seller:  Callifas38
Details:   $100.00   |  5/19/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> short range in stampede
Page: [1]
Login
short range in stampede - 2/10/2009 12:08 AM
slogan
Score: 100
Last Login: 10/20/2011
Status: offline
velineon setup in a traxxas stampede good speed,after 25' or 30' stalling, several new locations,same result, the set-up is the original lay out.
Hide Signatures
       Post #: 1
RE: short range in stampede - 2/10/2009 12:15 AM
newjak
Score: 100
Last Login: 11/9/2011
Status: offline
quote:
ORIGINAL: slogan
Make sure that there is no damage to the antenna on the truck. Also make sure that the AA batts in your TX are good. 25' is REALLY short. Are you using the antenna tube? TX antenna fully extended?
_____________________________
AMA Park Pilot Partner
Hide Signatures
(in reply to slogan)
       Post #: 2
RE: short range in stampede - 2/10/2009 12:20 AM
1maxdude
Score: 105
Last Login: 7/17/2010
Status: offline
I'd try a new RX if all else is good. Make sure your antenna doesn't come in contact with carbon fiber,graphite, aluminum, etc. What kind of batteries are you using, and do you have your lipo cutoff turned on? Maybe if your binding and geared too high, using poor batteries, it could cause the lipo cutoff to engage if its on, and you're using nimhs. Do you still have steering when it stops you?
Hide Signatures
(in reply to newjak)
       Post #: 3
RE: short range in stampede - 2/10/2009 4:07 AM
slogan
Score: 100
Status: offline
the rx is new,the batteries check out,good.the pics shows the layout,anything needs to be changed? and yes i have steering when the signal is lost or the range is shortened.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by slogan -- 2/10/2009 4:51 AM >
Hide Signatures
(in reply to 1maxdude)
       Post #: 4
RE: short range in stampede - 2/10/2009 6:28 AM
newjak
Score: 100
Status: offline
You didn't mention what battery you're running. If you are still able to steer than you are not out of radio range. Sounds more like the VXL LVC issue.
Hide Signatures
       Post #: 5
RE: short range in stampede - 2/10/2009 12:06 PM
1maxdude
Score: 105
Status: offline
Yeah, probably, get out your manual and figure out how to disable your low voltage cutoff. You say the batteries are good? If they are nickel metals and less than stellar, they could be getting sucked down while under acceleration to the point that would trigger the low voltage cutoff. Or, it could be a faulty speed controller. I seem to read alot about the vxl lvc not functioning properly, I don't own one personally.
Hide Signatures
       Post #: 6
RE: short range in stampede - 2/10/2009 4:28 PM
newjak
Score: 100
Status: offline
quote:
ORIGINAL: 1maxdude
I have a couple of VXL's and the LVC sucks real bad! I disabled mine and run my trucks without it and just monitor my runtime (3S) or use my 2S lipo alarm
Hide Signatures
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.328RCU1
