RE: Comp ARF BAE Hawk build thread    Gallery
Logged in as Guest
Users viewing this topic: butler-campers, fireblade5437, hbutler, kev-o
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Comp ARF BAE Hawk build thread
Page: <<   < prev  31 32 [33] 34 35 36 37 38 39 40   next >   >>
Login
RE: Comp ARF BAE Hawk build thread - 8/10/2012 1:38 PM
fireblade5437
Score: 105
Last Login: 5/25/2013
Status: online
Stan
Too be honest it is coming up to 2yrs since I built this Jet, so trying to remember!
Ok re-read what you wrote... the carbon deflector is under the lip of the bell mouth if you look at last pic you can make out the M2 cap head bolts I used to hold the two parts together also pic#5.
I think the only bits I trimmed off the deflector was on the top of each side where they come close to the two ali right angle brackets.
Alan
< Message edited by fireblade5437 -- 8/10/2012 2:55 PM >
Hide Signatures
(in reply to tucson)
       Post #: 801
RE: Comp ARF BAE Hawk build thread - 8/18/2012 2:38 PM
fireblade5437
Score: 105
Status: online
Finally managed to get the red paint matched on the Hawk
Two reasons I am repainting, one the carf stuff is not fuel proof you only have to buff with dry cloth and red comes off and secondly the main reason the paint scheme not been done right in the first place! plus I get rid of the mold line... ok 3 reasons.
The red has prooved to be not easy as anyone who paints will tell you. The CARF Display is a VERY bright red and typically bright reds are very translucent which means the base coat does matter. Well I usually use a Ti Green 2k primer which is very good but even in the pic this was tinted by 10% white 2k! you can tell the difference especially when you take it out of the sunlight. The right hand side has white primer which makes a huge difference. The guys at paints4u.com have spent some time on this finally having to manually mix taking out lots of orange and using a lot of very bright red tint! The small peice on the right is original red (cut out when fitting air scoops)
Second pic is top of nose which has just been redone, but it had light green Ti primer and you can tell the difference so this bit being rubbed down and done with white 2k primer before the red, then it will be exact match!
Also first time I have had 2k through my SATA mini jet 4 that I recently brought ... well impressed how it lays the paint on, pleased I brought it!
Alan
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to fireblade5437)
       Post #: 802
RE: Comp ARF BAE Hawk build thread - 8/18/2012 4:18 PM
dubd
Score: 135
Status: online
That looks great! Getting rid of the mold lines make a big difference.
Hide Signatures
       Post #: 803
RE: Comp ARF BAE Hawk build thread - 9/9/2012 6:25 PM
RCISFUN
Score: 105
Status: offline
Can anyone trace an out line of the wing fence and post it so I can make a set for mine
_____________________________
Rich
Jet Central Rabbit, Cheetah, Super Eagle & Rhino owner
Hide Signatures
(in reply to dubd)
       Post #: 804
RE: Comp ARF BAE Hawk build thread - 9/9/2012 7:05 PM
Dave Wilshere
Score: 108
Last Login: 5/24/2013
Status: offline
If you get no takers I can draw around one and fax it? Don't have a scanner!
Dave
Motors & Rotors. JetCat, Powerbox, Intairco, Behotec, Graupner. CARF-models Rep. JR Propo for ever!, Jet 1A, MAP, Evojet, BV
Hide Signatures
(in reply to RCISFUN)
       Post #: 805
RE: Comp ARF BAE Hawk build thread - 9/9/2012 10:10 PM
afterburner
Score: 110
Status: online
Hey Rich,
I tried scanning it and then printing it. It printed a tad smaller. I will email you the file anyway as it gives you the correct shape and you can enlarge it or let me know a better way.
Marty
Hide Signatures
       Post #: 806
RE: Comp ARF BAE Hawk build thread - 9/10/2012 2:49 AM
RCISFUN
Score: 105
Status: offline
Marty
I received your e-mail, thank you
Maybe you can provide the length measurement as marked on the photo that you sent to me?
Click for fullsize
Rich
Hide Signatures
(in reply to afterburner)
       Post #: 807
RE: Comp ARF BAE Hawk build thread - 9/10/2012 2:50 AM
RCISFUN
Score: 105
Status: offline
Thanks Dave, I think Marty's file may work...
Rich
Hide Signatures
(in reply to Dave Wilshere)
       Post #: 808
RE: Comp ARF BAE Hawk build thread - 9/10/2012 3:07 AM
afterburner
Score: 110
Status: online
Rich,
If you draw two vertical lines at each end of the fence, the OAL is 127mm or 5". Hope this helps.
Marty
Hide Signatures
       Post #: 809
RE: Comp ARF BAE Hawk build thread - 9/10/2012 3:09 AM
RCISFUN
Score: 105
Status: offline
Thanks Marty, that what I did in the photo that I posted, the lines came out very light, but they are there
Thanks for the info!
Rich
Hide Signatures
       Post #: 810
RE: Comp ARF BAE Hawk build thread - 9/10/2012 3:19 AM
afterburner
Score: 110
Status: online
quote:
ORIGINAL: RCISFUN
Ha, I didn't click on the pick or look too close. I see them now.
Marty
Hide Signatures
       Post #: 811
RE: Comp ARF BAE Hawk build thread - 9/11/2012 8:05 AM
Dave Wilshere
Score: 108
Status: offline
The factory shape always needs a slightly increased front radius for the wing LE
Dave
Hide Signatures
       Post #: 812
RE: Comp ARF BAE Hawk build thread - 9/11/2012 11:46 AM
RCISFUN
Score: 105
Status: offline
Dave
Do you mean the inside radius that fits to the wing?
Rich
Hide Signatures
       Post #: 813
RE: Comp ARF BAE Hawk build thread - 9/23/2012 5:18 PM
fireblade5437
Score: 105
Status: online
Have been busy getting the rest of the fuz ready for painting, the front half is done now, so starting the back. Got rid of most of the blue and even though you can still see the design I have removed quite a lot of paint before I give it a light coat of 2K white primer.
Hopefully the back comes out as good as the front. One thing I did when building the CARF Hawk was to bolt on both jet intakes as I knew at some point I would repaint it, this makes it very easy to spray the intakes.
Alan
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 814
RE: Comp ARF BAE Hawk build thread - 9/23/2012 9:18 PM
Dave Wilshere
Score: 108
Status: offline
quote:
ORIGINAL: RCISFUN
Dave
Missed this! Yes!
Dave
Hide Signatures
       Post #: 815
RE: Comp ARF BAE Hawk build thread - 9/23/2012 9:37 PM
fireblade5437
Score: 105
Status: online
Dave
I wondered when you would get around to answering him
Alan
Hide Signatures
       Post #: 816
RE: Comp ARF BAE Hawk build thread - 9/25/2012 7:13 PM
fireblade5437
Score: 105
Status: online
Managed to get the back end done in 2k primer today before the rain came!
Alan
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 817
RE: Comp ARF BAE Hawk build thread - 9/25/2012 7:36 PM
RCISFUN
Score: 105
Status: offline
Looking good!
I have been working on my install, maybe next week I'll have time to post some photos
Rich
Hide Signatures
       Post #: 818
RE: Comp ARF BAE Hawk build thread - 9/25/2012 7:49 PM
fireblade5437
Score: 105
Status: online
Rich
Show us ya pics!
Always interesting to see other installs of 'your' plane
Couple of pics from my install
Alan
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 819
RE: Comp ARF BAE Hawk build thread - 10/11/2012 11:03 PM
afterburner
Score: 110
Status: online
I'm assuming the plane is balanced with gear down but better to ask? Thanks. Also has anyone who has put the air scoops on, not cut holes in the fuse and have problems? I have some things mounted to the fuse right under where they would mount and I didn't really expect I was going to get the scoops as my kit was older and didn't include them but Andy Kane put the order through for them and they showed up about six weeks later. Thanks.
Marty
Hide Signatures
       Post #: 820
RE: Comp ARF BAE Hawk build thread - 10/11/2012 11:40 PM
RCISFUN
Score: 105
Status: offline
quote:
ORIGINAL: fireblade5437
Rich
Show us ya pics!
Alan
Haven't been able to spend much time on it, hopefully I'll get back on it soon, basically our flying season is over So I will have plenty of time over the winter
Rich
Hide Signatures
       Post #: 821
RE: Comp ARF BAE Hawk build thread - 10/12/2012 8:22 AM
Dave Wilshere
Score: 108
Status: offline
quote:
ORIGINAL: afterburner
Marty
Marty
Yes, gear down-but my manual figures are "safe" so you can go back a little. Also ensure the Ailerons are level at the tip (ignor the flaps)
I fitted mine 3 years after it was built and in the "childish" rush to fit them did not make holes. They have been fine so far. Can you not even drill a 1/8" hole towards the back? Anything to reduce the pressure a little.
Dave
Hide Signatures
       Post #: 822
RE: Comp ARF BAE Hawk build thread - 10/12/2012 11:34 AM
afterburner
Score: 110
Status: online
Thanks Dave.
I remember your tip in the thread about the ailerons being offset with the flaps when all are neutral but thanks for the reminder. I was thinking the same thing about getting any kind if hole under the scoop. I might be able to. I might just do it the right way and pull the tank to get in there and do a bit of relocating. Thanks again.
Marty
Hide Signatures
       Post #: 823
RE: Comp ARF BAE Hawk build thread - 10/12/2012 5:30 PM
tucson
Score: 100
Status: online
After some medical problems I am finally on the road to finishing up my hawk.
All that is left is to Set up the controls, Balance and put the finishing decals on.
I was going to put smoke in but did not think ahead and brought the wing cable out the top of the wing instead of through the front. Has anyone put their smoke tank in another area other then on top of the wing where the wires come out?
I really do not want to move the wires if I do not have to.
Here are some pictures of my install.
Stan
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 824
RE: Comp ARF BAE Hawk build thread - 10/12/2012 6:24 PM
RCISFUN
Score: 105
Status: offline
I was going to say why not put the smoke tank on top of your main tank , but I see your air tanks are there, I mounted two big recycled Power max cans under my tray for plenty of air storage for those massive scale gear.
Rich
Hide Signatures
       Post #: 825
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.484RCU1
