RE: Comp ARF BAE Hawk build thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Comp ARF BAE Hawk build thread
Page: <<   < prev  32 33 [34] 35 36 37 38 39 40 41   next >   >>
Login
RE: Comp ARF BAE Hawk build thread - 10/12/2012 6:58 PM
tucson
Score: 100
Last Login: 5/19/2013
Status: offline
Rich,
Looks like I will be mounting my new smoke pump in the Tutor until I come up with a way to get a smoke tank into the Hawk with out redoing the airlines and wires.
Well anyway the Tutor really needs smoke more then the Hawk
Stan
Hide Signatures
(in reply to RCISFUN)
       Post #: 826
RE: Comp ARF BAE Hawk build thread - 10/12/2012 8:11 PM
Dave Wilshere
Score: 108
Last Login: 5/18/2013
Status: offline
Stan
You could put two 24 oz Dubro's one either side of the wires?
Dave
_____________________________
Motors & Rotors. JetCat, Powerbox, Intairco, Behotec, Graupner. CARF-models Rep. JR Propo for ever!, Jet 1A, MAP, Evojet, BV
Hide Signatures
(in reply to tucson)
       Post #: 827
RE: Comp ARF BAE Hawk build thread - 10/12/2012 8:20 PM
tucson
Score: 100
Status: offline
quote:
ORIGINAL: Dave Wilshere
Stan
Dave
Dave,
Thought of that. They will cover the air inlet some.
Did you ever put smoke in your Hawk?
Stan
Hide Signatures
(in reply to Dave Wilshere)
       Post #: 828
RE: Comp ARF BAE Hawk build thread - 10/12/2012 8:24 PM
happy flying
Score: 100
Last Login: 5/14/2013
Status: offline
Stan
I have used the wing tank from a flash with the wire and air lines coming out just either side of centre, i will try and take some pics for you tomorrow.
Steve
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 829
RE: Comp ARF BAE Hawk build thread - 10/12/2012 8:30 PM
tucson
Score: 100
Status: offline
quote:
ORIGINAL: happy flying
Stan
Steve
Thanks Steve,
Look forward to seeing what you did.
Stan
Hide Signatures
(in reply to happy flying)
       Post #: 830
RE: Comp ARF BAE Hawk build thread - 10/13/2012 12:13 PM
happy flying
Score: 100
Status: offline
Hi Stan
Here are some pictures for you (sorry about the quality), i have put the tank in upside down to give more room through the front but it works fine.
HTH
Steve
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 831
RE: Comp ARF BAE Hawk build thread - 10/13/2012 3:26 PM
Dave Wilshere
Score: 108
Status: offline
quote:
ORIGINAL: tucson
Stan
Dave
Dave,
Stan
Stan
No, hate the mess...:-)
Dave
Hide Signatures
       Post #: 832
RE: Comp ARF BAE Hawk build thread - 10/13/2012 3:50 PM
tucson
Score: 100
Status: offline
Steve,
Very helpful pictures I see what you did.
This will be an option for me when I do install my smoke tank.
I do like to watch airplanes when they use their smoke systems, but my main reason for going to smoke is to use in an emergency situation.
While flying my Flash I have lost sight of it as I enter a turn with the proper colored sky.
My thought is it would be great to flip a switch and be able to spot it if you could not find it right away.
So my thinking now is a smaller tank 24-32 oz's (two 16 oz tanks). That should give me two minutes of smoke if I only used it on certain maneuvers or emergency situation.
Thanks for your pictures,
Stan
Hide Signatures
       Post #: 833
RE: Comp ARF BAE Hawk build thread - 10/15/2012 6:52 AM
Dave Wilshere
Score: 108
Status: offline
Had the Hawk that started this thread out again yesterday at a local club's fly in. Great model, still one of my favourite models. P-120SX power is plenty...
Dw
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 834
RE: Comp ARF BAE Hawk build thread - 10/15/2012 12:28 PM
RCISFUN
Score: 105
Status: offline
Dave in looking at you last photo.... some lights would be an awesome addition
Rich
Jet Central Rabbit, Cheetah, Super Eagle & Rhino owner
Hide Signatures
       Post #: 835
RE: Comp ARF BAE Hawk build thread - 10/16/2012 7:47 AM
Dave Wilshere
Score: 108
Status: offline
Because the outline is scale and it flys so well I always intended building a second Hawk with Lights and the scale gear, but time never allows this. I don't even have the scale cockpit fitted yet!
Maybe one day...
The sun just went behind a cloud for a minute when Claire took that shot
Dave
Hide Signatures
       Post #: 836
RE: Comp ARF BAE Hawk build thread - 10/16/2012 8:12 AM
fireblade5437
Score: 105
Status: offline
Dave
MAKE time well worth it with the cockpit in. One thing is not good where the two intake vents are on the top if you cut out the wooden former is directly underneath so you would have to cut into the wood hence it would need bracing lower down.
Alan
Hide Signatures
       Post #: 837
RE: Comp ARF BAE Hawk build thread - 10/16/2012 2:52 PM
Dave Wilshere
Score: 108
Status: offline
Just had this through of sunday's flying with plenty of Hawk shots
https://www.dropbox.com/sh/ryhxvvjdo157hkm/KY3Lj4cA6L
Dw
Hide Signatures
(in reply to fireblade5437)
       Post #: 838
RE: Comp ARF BAE Hawk build thread - 10/30/2012 5:48 PM
husafreak
Score: 100
Last Login: 5/17/2013
Status: offline
Could someone comment on the flying qualities of the Hawk VS the Ultra Flash? I am primarily interested in the Ultra flash as my first turbine but the Hawk is the about same cost and size I thought I would check it out as an alternative. I am an aerobatic (not scale) flyer. But I do like scale airplanes, I just dislike the handling limitations most of them have. I am looking for the handling qualities of a pattern ship (kind of like my Electra) in my first turbine and i want to run a smoke system. The Union Jack color scheme is awesome! Thanks
Hide Signatures
       Post #: 839
RE: Comp ARF BAE Hawk build thread - 10/30/2012 6:38 PM
Dave Wilshere
Score: 108
Status: offline
Not a million miles apart. Look at these flown on the same 260' site
http://www.motorsandrotors.co/index.php?main_page=index&cPath=1_62
The slow speed is close, UF is quite a bit faster (say like here both with P-120SX)
break-away on Hawk is more sudden than the UF, but very slow even then.
Dw
Hide Signatures
(in reply to husafreak)
       Post #: 840
RE: Comp ARF BAE Hawk build thread - 10/30/2012 8:20 PM
husafreak
Score: 100
Status: offline
Thanks Dave. Yes the Hawk is much prettier in flight but the UF is much faster and in the video the flying is much more high energy, looks like you (or whoever was flying) was having more fun with the UF! The rolling and knife edge and stability of both look great but the UF was pulling a lot more g's and only it was doing snap rolls. Thank you.
Hide Signatures
       Post #: 841
RE: Comp ARF BAE Hawk build thread - 10/30/2012 8:53 PM
Kenrico
Score: 100
Status: offline
I was in the same boat as you a few days back! but decided on the hawk in the Union Jack Scheme. I'm hopping to hear from Andy today with a tracking number.
Dave,
What is the recommended torque for the Stab? I have some hitecs 7985s I was thinking on using for the wing and two 7955TG for the Stab?
the 7985s are 172 oz-in at 6V and the 7955 are 333 oz-in at 6V each.
Hide Signatures
       Post #: 842
RE: Comp ARF BAE Hawk build thread - 10/30/2012 9:25 PM
fireblade5437
Score: 105
Status: offline
I used 8911 x 2 for tailplane, 8911 rudder (had spare one) 8411 x 4 for ailerons and flaps, BLS351 front wheel, HS 5125MG slim metal gear for small front door and cockpit power box and A123....
Alan
Hide Signatures
(in reply to Kenrico)
       Post #: 843
RE: Comp ARF BAE Hawk build thread - 10/30/2012 9:40 PM
dubd
Score: 135
Status: offline
quote:
ORIGINAL: husafreak
The CARF Hawk can be fast and flown with a lot of energy too. I often flew my CARF Hawk like I flew my UF.
Hide Signatures
       Post #: 844
RE: Comp ARF BAE Hawk build thread - 10/30/2012 10:35 PM
luv2flyrc
Score: 102
Status: offline
quote:
ORIGINAL: dubd
quote:
ORIGINAL: husafreak
I have both Flash and Hawk, if I could only have one, it would be Hawk hands down. Yes, Flash is way faster witrh same engine but, after a few high speed runs, who cares. Hawk has WAY more presence.  I find the Hawk a bit more challenging to land on a short field than Flash if that's a concern but, then again, I have more time on the Flash. The Hawk will fly a lot slower than you think and people often try to land it too fast.
Not sure what Dub's got in his but, I'm guessing that's more than a P-120
Mike
Hide Signatures
(in reply to dubd)
       Post #: 845
RE: Comp ARF BAE Hawk build thread - 10/30/2012 10:53 PM
dubd
Score: 135
Status: offline
Like Mike, if I could only have one it would be the Hawk. You can fly the Hawk as a sport jet or scale jet. It does look a bit odd flying around like a sport plane. BTW - I had a Kingtech 170 in mine.
With that said, here's me doing more "non-scale" flying with my old Hawk.
< Message edited by dubd -- 10/31/2012 12:33 AM >
Hide Signatures
(in reply to luv2flyrc)
       Post #: 846
RE: Comp ARF BAE Hawk build thread - 10/31/2012 12:37 AM
afterburner
Score: 110
Status: offline
I'm trying to finish up my cockpit and was wondering if the white loop that crosses over the canopy between the pilots was an item that was included in the kit? I see some people didn't have it in the pictures that they posted. Just wondering what to use. Thick pinstriping tape or some flexible styrene? Thanks.
Marty
< Message edited by afterburner -- 10/31/2012 2:08 AM >
Hide Signatures
(in reply to dubd)
       Post #: 847
RE: Comp ARF BAE Hawk build thread - 10/31/2012 12:43 AM
dubd
Score: 135
Status: offline
Marty, I used thick vinyl tape.
Hide Signatures
(in reply to afterburner)
       Post #: 848
RE: Comp ARF BAE Hawk build thread - 10/31/2012 2:59 AM
afterburner
Score: 110
Status: offline
Thanks Dantley.
Marty
Hide Signatures
(in reply to dubd)
       Post #: 849
RE: Comp ARF BAE Hawk build thread - 10/31/2012 5:27 AM
husafreak
Score: 100
Status: offline
Well, you guys are certainly not making this any easier for me! But thanks for the videos, the Hawk was moving out and in style. Very capable in KE and looking great with the smoke on. I would probably get a P140 if I buy a new engine so it is quite powerful. That is one sweet jet.
Hide Signatures
       Post #: 850
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.673RCU1
