RE: New Fusion and ProYak ARFs
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> OMP - Ohio Model Products Support Forum >> RE: New Fusion and ProYak ARFs
Page: <<   < prev  1 [2]
Login
RE: New Fusion and ProYak ARFs - 4/23/2009 3:09 AM
noahb
Score: 100
Last Login: 11/8/2009
Status: offline
Is the CG really 8-8.5 inches back from the leading edge of the wing at the root? Not disputing this, but man that is way way back there.
Can someone verify this?
Hide Signatures
(in reply to noahb)
       Post #: 26
RE: New Fusion and ProYak ARFs - 4/23/2009 3:12 AM
noahb
Score: 100
Status: offline
my calculations show it back around 5.5-6 inches back.
Hide Signatures
(in reply to noahb)
       Post #: 27
RE: New Fusion and ProYak ARFs - 4/23/2009 11:38 AM
closetguy
Score: 100
Last Login: 11/7/2009
Status: offline
my first two flew great at 8.5 CG,that is where i am putting the CG one this new third one that i bought at the Toledo show.NOT A BETTER FLING SLAB OUT THERE!
No. three and counting
Hide Signatures
(in reply to noahb)
       Post #: 28
RE: New Fusion and ProYak ARFs - 4/23/2009 2:53 PM
daveopam
Score: 109
Status: offline
I have a small piece of trim tape on mine showing the CG. It is about half way back from the LE. SHould be in the 8.5" range.
David
_____________________________
"Never use a big word when a little filthy one will do"
Johnny Carson
Hide Signatures
(in reply to closetguy)
       Post #: 29
RE: New Fusion and ProYak ARFs - 4/23/2009 11:22 PM
noahb
Score: 100
Status: offline
Thanks guys. Just wondering. As most know, typical cg's are located around 25-30%. However, this one is more like 43% if my calcs. are correct. Just making sure before I put a flight on her.
Hide Signatures
(in reply to daveopam)
       Post #: 30
RE: New Fusion and ProYak ARFs - 4/26/2009 12:48 PM
AFSalmon
Score: 100
Last Login: 11/6/2009
Status: offline
quote:
ORIGINAL: noahb
8.5" is absolutely correct. CG calculations are based on many factors most of which have to do with knowing where the center of lift is on the desgin, not just pure geometry. For this design, given the wing sweep and airfoil design, 8.5 is the sweet spot.
Mike (Salmon) Pilkenton, Chief Slab Designer
Ohio Model Planes
Hide Signatures
(in reply to noahb)
       Post #: 31
RE: New Fusion and ProYak ARFs - 5/15/2009 1:27 AM
beachbrada
Score: 160
Status: offline
Whats the difference between these two planes as far as 3D and overall performance? I plane on getting one of these and will be using a Saito 125 for whichever one I choose. Are the Yaks still coming out tail heavy and requiring alot of nose weight or has there been a fix to this? I currently have the OMP Edge 540 V3, this plane is a blast to fly, but I want something a little bigger and has a thinner wing for flying in moderate wind.
There''s no such thing as a cheap mistake in this hobby.
Hide Signatures
(in reply to AFSalmon)
       Post #: 32
RE: New Fusion and ProYak ARFs - 5/15/2009 2:02 AM
AFSalmon
Score: 100
Status: offline
quote:
ORIGINAL: beachbrada
You want the Fusion. Perfect for that engine and a great compliment to your profile lineup. The ProYak is another 40 size profile although a lot more aggressive and nimble than the V3 Edge. I think you were readig about the RazorYak ARF which is a 70-90 size model. Some folks though have put bigger engines such as the 1.25 4s engines.
Ohio Model Planes
Hide Signatures
(in reply to beachbrada)
       Post #: 33
RE: New Fusion and ProYak ARFs - 5/15/2009 12:39 PM
beachbrada
Score: 160
Status: offline
You are right, I was talking about the Razor Yak 56", so how does this plane compare to the Fusion?
Hide Signatures
       Post #: 34
RE: New Fusion and ProYak ARFs - 5/15/2009 12:57 PM
AFSalmon
Score: 100
Status: offline
The RY has been described as a "hang onto your a**" type of profile. It is at the top of the charts as far as aggressive agility. Given a real short nose and HUGE tail surfaces it will twist itself around very quickly. It is designed obviously for pure 3D flying. The Fusion is completely different and designed for both precision flying as well as 3D. If you want to mix up the two styles of flying for some freestyle routines then the Fusion is the king of profiles. You can perform any sequence in the book and still fly awesome 3D. Fusion does the best wall I've ever seen bar none. It can kick the tail under the nose so well it actually flys backwards for a second.
Ohio Model Planes
Hide Signatures
       Post #: 35
RE: New Fusion and ProYak ARFs - 5/15/2009 11:57 PM
beachbrada
Score: 160
Status: offline
I know that normally with any 3D plane or fun fly type plane you don't want to go fast for the sake of avoiding flutter. Is this still true for the Fusion or will this plane do fine with high speed fly-by's?
Hide Signatures
       Post #: 36
RE: New Fusion and ProYak ARFs - 5/16/2009 12:05 AM
AFSalmon
Score: 100
Status: offline
This is a fact with any profile or aircraft with flat surfaces which are inherently prone to flutter. Good servos and tight linkages are key. The Fusion is no different than any other profile in this regard. Use good servos and make sure slop in minimal to none and you will be fine.
Ohio Model Planes
Hide Signatures
       Post #: 37
RE: New Fusion and ProYak ARFs - 5/16/2009 12:21 AM
beachbrada
Score: 160
Status: offline
Ok thanks, does the Razor Yak incorporate the carbon fiber tube that runs through the fuselage like the other OMP planes? Also how much harder will it be to fly the Razor Yak coming from the OMP Edge? Im sort of leaning towards getting the Razor Yak since I want all out 3D performance.
Hide Signatures
       Post #: 38
RE: New Fusion and ProYak ARFs - 5/18/2009 2:11 PM
AFSalmon
Score: 100
Status: offline
The RY has a 1/2" fiberglass tube that runs through the fuselage.  Even though it is slightly heavier we use fiberglass tubes instead of carbon as the fg flexes more instead of fracturing like cf.  The RY is not a beginner profile.  They are designed to be very aggressive and can twist their tails off quicker than you can blink an eye.  The V3 Edge is designed to be more the beginner 3D profile and that's what it was designed to do.  It is still very capable and with a hot engine and good servos very responsive but not in the same class as the RY.  If you are experienced in 3D then step up to the Proyak (40 size) or RY (70-90 size).
Ohio Model Planes
Hide Signatures
       Post #: 39
RE: New Fusion and ProYak ARFs - 5/31/2009 3:18 AM
rjbranchii
Score: 100
Last Login: 10/26/2009
Status: offline
Mike
Could you post those pics on the throttle  wire routing fix?
bob
Hide Signatures
       Post #: 40
RE: New Fusion and ProYak ARFs - 6/1/2009 2:16 PM
AFSalmon
Score: 100
Status: offline
quote:
ORIGINAL: rjbranchii
Mike
bob
Hi Bob, check out this other thread on the 67" Fusion:  Pics are in there.
http://www.rcuniverse.com/forum/m_8760830/tm.htm
Ohio Model Planes
Hide Signatures
(in reply to rjbranchii)
       Post #: 41
RE: New Fusion and ProYak ARFs - 9/2/2009 10:27 PM
beachbrada
Score: 160
Status: offline
Did the throttle servo wiring channel every get incorporated into the Fusions? If I order one today, will I get one with or without the servo wiring channel cut?
Hide Signatures
       Post #: 42
RE: New Fusion and ProYak ARFs - 9/8/2009 4:07 PM
AFSalmon
Score: 100
Status: offline
Not until the next run of ARFs which probably won't be until next summer. It takes less than 5 minutes to cut a hole through the balsa bracing though. Piece of cake.
Ohio Model Planes
Hide Signatures
       Post #: 43
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.047RCU1
