RE: best rock crawler set up?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> RE: best rock crawler set up?
Page: <<   < prev  1 2 3 [4]
Login
RE: best rock crawler set up? - 11/14/2003 1:18 AM
Isphius
Score: 100
Last Login: 2/15/2009
Status: offline
yeah but on rocks your ful throttle climbing without much air speed over the head. You might be able to find a good point between power/rich setting, but you can just get a giant cooling head. Im sure if your gears are low enough you wont have heat problems anyway.
Hide Signatures
(in reply to BigBlocked)
       Post #: 76
RE: best rock crawler set up? - 11/18/2003 2:05 AM
flip3d
Score: 100
Last Login: 1/8/2005
Status: offline
ive got a txt on order.
what do i do to make it crawl better
philip
_____________________________
They call me "Flip"
Hide Signatures
(in reply to Isphius)
       Post #: 77
RE: best rock crawler set up? - 1/13/2004 9:47 AM
Sic Soul
Score: 100
Last Login: 1/30/2004
Status: offline
this is my 30 mph rock crawler- i love to crawl but i don't want to wait all day to get to the rocks.
It is a truck I designed that utitilizes an emaxx transmission and other stock emaxx parts- but with a suspension similar to a four link suspension- which allows this truck to achieve 90 degrees of articulation and still bounce back for more.
4ws is available with the addition of a servo and Y harness. I haven't even locked the differentials and it still has plenty of climbing power. And it still handles high speed very well. the wooden pyramid in the second picture is 13 inches high. I have a video of my truck going through an obstacle course with similar pyramids that my friends' TXT rolled over while trying to go through the course. That was funny- the day an Emaxx out Crawled a TXT.
of course this is no ordinary Emaxx.
SicSoul Engineering
Paul
sicsouleng@hotmail.com
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to flip3d)
       Post #: 78
RE: best rock crawler set up? - 1/13/2004 11:28 AM
DCLXVI
Score: 100
Last Login: 4/28/2008
Status: offline
quote:
ORIGINAL: now_torquin
philip
Lock the diffs...
If you want to buy stuff for it, 2x Kyosho Magetic Mayhem motors, alu skid plates, new dampers (I'm using the DuraTrax Evader dampers, alu, threaded bodys, 15,5 USD a pair @ Tower)
You can go to www.rc4wd.com for the skidplates and www.rcrock.com for instructions on how to JBWeld-lock the diffs...
/DCLXVI
Hide Signatures
       Post #: 79
RE: best rock crawler set up? - 1/13/2004 11:28 PM
skyjacker_rc_club
Score: 100
Last Login: 5/22/2005
Status: offline
this would be a great descusen to bring up in the offical rock crawling page there is no need to open another thread.
[link]http://www.freewebs.com/skyjacker/[/link]
Hide Signatures
       Post #: 80
RE: best rock crawler set up? - 1/17/2004 1:15 AM
oatmealman
Score: 100
Last Login: 2/2/2005
Status: offline
if you guys want to make a good crawlin machine listen up.cut the chassis in half then buy a small hinge and place it about half and half on the chassis so the two half chassis move side to side.Warning the hinge must one of those one that swings both ways.this will allow half of the truck to be going another way then the other,without alot of suspension help,There for fixing every mans problem of suspensions. the 2 screws mudst be placed diagnol from each other allowing the chassis moving side to side.
Hide Signatures
(in reply to skyjacker_rc_club)
       Post #: 81
RE: best rock crawler set up? - 2/10/2004 11:00 AM
iBlake
Score: 100
Last Login: 12/1/2005
Status: offline
Hey, I was thinking about getting a clod buster and I am not sure which Esc I should get, but I don’t want to spend $120 on a rooster. What requirements does the Esc have to meet to run on the clod, I”ve heard things about parallel, and duel motor compatibility, but I don't know how to make since of it all. Can someone try to explain it to me? I need the most cost effective Esc that can handle rock crawling. I would appreciate the help.
Hide Signatures
(in reply to oatmealman)
       Post #: 82
RE: best rock crawler set up? - 2/11/2004 5:34 AM
R/C Dragon
Score: 100
Last Login: 9/2/2007
Status: offline
Hey, wat kind of tires are better?? I want to get some IMEX duallies but would wider be better??
-The R/C Dragon
Hide Signatures
(in reply to iBlake)
       Post #: 83
RE: best rock crawler set up? - 2/11/2004 7:51 PM
DCLXVI
Score: 100
Status: offline
quote:
ORIGINAL: blako74
You will need an ESC that can handle at least a 14T motor...high frequency are a plus...
/DCLXVI
Hide Signatures
       Post #: 84
RE: best rock crawler set up? - 2/13/2004 10:49 PM
mrmaxxman
Score: 100
Last Login: 11/10/2011
Status: offline
why not go scale rock crawling heres mine. 465 on ebay ready to run last pic is stock leaf spring set up still has decent artic.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by mrmaxxman -- 2/13/2004 8:07:17 PM >
Hide Signatures
(in reply to DCLXVI)
       Post #: 85
RE: best rock crawler set up? - 2/14/2004 3:17 PM
q8murder
Score: 100
Last Login: 12/12/2010
Status: offline
what is a crawler?
Hide Signatures
       Post #: 86
RE: best rock crawler set up? - 2/17/2004 2:22 AM
auto2
Score: 100
Last Login: 7/11/2012
Status: offline
I admit I havn't read the whole thread but the problem with independent is also as the suspension compresses the center of the truck gets closer to the ground .loosing ground clearence.
A solid axle lift up the middle of the rear when it goes up over a rock. gaining ground clearence.
Hide Signatures
       Post #: 87
RE: best rock crawler set up? - 9/8/2012 2:11 PM
mynightster
Score: 100
Last Login: 11/1/2012
Status: offline
i just built  a ground pounder crawler usenig a locked stampede tranny  it crawls well but ikeep popping the rear driveshaft out of the yoke, how do i stop this proplem? and what would b a good crawler motor and gear set up to give me torque
Hide Signatures
       Post #: 88
RE: best rock crawler set up? - 10/27/2012 3:19 PM
Sigma.40
Score: 199
Last Login: 4/27/2013
Status: offline
I think this is the oldest thread I've ever seen resurrected! Almost 9 years.
HPI Baja 5SC, TLR 8ight 2.0, Traxxas Stampede 4x4 VXL and one very pissed off wife.
Hide Signatures
(in reply to mynightster)
       Post #: 89
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.000RCU1
