receiver cutting off under full accleration
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Radio Equipment >> receiver cutting off under full accleration
Page: [1]
Login
receiver cutting off under full accleration - 2/22/2009 9:17 PM
zsar1
Score: 100
Last Login: 4/28/2009
Status: offline
hi anyone have problem when you put receiver on and accelarate and the reciver switches off.after disconecting battery and reconecting it, it comes on again but when you give it full throttle the receiver switches off again.anyone got any idea why this is happening . i am using spectrum receiver and mamba esc and mamba max motor
_____________________________
zsar1
Hide Signatures
       Post #: 1
RE: receiver cutting off under full accleration - 2/22/2009 9:37 PM
xt2nitro
Score: 100
Last Login: 7/12/2009
Status: offline
Do you mean the servo is cutting out? If it is the receiver please can you explain how you can tell it's the receiver.
< Message edited by xt2nitro -- 2/22/2009 10:09 PM >
Hide Signatures
(in reply to zsar1)
       Post #: 2
RE: receiver cutting off under full accleration - 2/22/2009 10:42 PM
systemlord
Score: 100
Last Login: 7/26/2009
Status: offline
Spektrum receivers are famous for not working correctly with some brands of ESC's. I'm not a Spektrum hater either, I'm about to buy a $700 plus dollar Spektrum product.
< Message edited by systemlord -- 2/22/2009 10:43 PM >
UE SuperMaxx 1/8th Monster Truck* Custom Duratrax Vendetta Mamba 25 Motor 5400kv Impulse 3S1P 11.1v 950mAH 25C
Hide Signatures
(in reply to xt2nitro)
       Post #: 3
RE: receiver cutting off under full accleration - 2/23/2009 12:18 AM
RCguru09
Score: 100
Last Login: 6/12/2009
Status: offline
Simple solution. Use a seperate battery for your reciever. If you are not, This the problem. The motor is sucking all the current and the reciever can't get any juice to power the servos. By pasing the reciever and using the motor battery to power the whole care is called B.E.C. battery -Eliminator- circuit Most newer reciever has this.
Hide Signatures
(in reply to zsar1)
       Post #: 4
RE: receiver cutting off under full accleration - 2/23/2009 2:15 AM
systemlord
Score: 100
Status: offline
quote:
ORIGINAL: RCguru09
Thats the what I would do, brushless systems are so power hungry that you should use a seperate battery for your receiver on any electric power model.
Hide Signatures
(in reply to RCguru09)
       Post #: 5
RE: receiver cutting off under full accleration - 2/23/2009 8:08 AM
sonicj
Score: 107
Last Login: 11/12/2009
Status: offline
one of these should solve your problem: http://www.spektrumrc.com/Products/Default.aspx?ProdID=SPM1600
i don't think spektrum should charge for these. this is a design flaw. i have plenty of rx's that work fine during voltage drops. if it only works with above average and better battery systems, then it should say so on the box! or at least sell them at cost!
Pro-Pulse B-100, Pro-Pulse T-100, HPI Micro RS4, Losi JRX-Pro SE, Losi Micro DT, Associated Monster GT 4.6, EXI 450
Hide Signatures
(in reply to systemlord)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
2.391RCU1
