Help in setting up my Cularis
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Gliders, Sailplanes and Slope Soaring >> Help in setting up my Cularis Page: [1]
Login
Help in setting up my Cularis - 2/23/2009 7:00 PM
fireforthall
Score: 100
Last Login: 6/21/2009
Status: offline
I could use some help in settin up my radio to my Cularis! I have a Hitec Eclipse 7 and am having problems setting up all the inputs. I have never used this indepth of a program in a radio so if one could help please PM me to see if we can talk.
Andy
Hide Signatures
       Post #: 1
RE: Help in setting up my Cularis - 2/24/2009 3:13 AM
UltraBob
Score: 100
Last Login: 11/8/2009
Status: offline
Andy,
Ran across this. Don't know if you had seen it. Might help.
Bob
http://www.mombu.com/aviation/radio-controlled-aviation/t-hitec-eclipse-7-question-1373407.html
Hide Signatures
(in reply to fireforthall)
       Post #: 2
RE: Help in setting up my Cularis - 2/24/2009 10:43 PM
aeajr
Score: 100
Status: offline
So tell me what problem you are having. There is no need to over complicate this. Have you used the manual?
Does you Cularis have a motor?
Did you select a glider profile and 4 servo wing (4WNG) type? Page 10-11
What channels did you use for your servos? Page 30 gives you the channel assignments you should use for a glider using the glider profile and 4 wing servo type.
Do you have your basics done? End point adjusted, servos centered? All moving in the correct direction? - See page 28 for the index that is relevant to gliders
See page 29 for the glider switch assignments
See page 30 for some useful tips
dual rates or dual expo - your choice page 18 or 20
Aileron differential - page 25
aileron to rudder mix - page 24
Flap to elevator mix - Page 33
If you have a motor you will have on/off control from the front left switch (see diagram on page 29)
You don't need every mix in the book. I would suggest that you try to enable only these to start.
< Message edited by aeajr -- 2/24/2009 11:14 PM >
_____________________________
President, Long Island Silent Flyers www.lisf.org
President, Eastern Soaring League www.flyesl.com
Present on the flying field whenever possible.
Hide Signatures
(in reply to UltraBob)
       Post #: 3
RE: Help in setting up my Cularis - 2/25/2009 12:10 AM
fireforthall
Score: 100
Status: offline
aeajr,
I was able to get most of this done today, but now I am having a problem with my L flap in that when I input L aileron it goes up but the flap will not. On the R side the flap will go up when you give R input.
I used 4 wing
1 R aileron, 5 L, 2 ele, 4 rudder, 6&7 flap
I have used the manual, some thing just did not seem to be working at first. Other than the deal with my flap, every thing is working good for now. I just need to figure this one out. I did set up crow and flap aileron mixing so that may be the problem.
Thank you
Hide Signatures
       Post #: 4
RE: Help in setting up my Cularis - 2/25/2009 1:37 AM
aeajr
Score: 100
Status: offline
Turn off Crow and flap aileron mixing. You don't need them now.
Get the plane flying with the mixes I gave you and forget the rest. When you have the plane flying wonderfully, when you are comfortable using what I gave you, THEN you can start adding mixes one at a time.
< Message edited by aeajr -- 2/25/2009 1:41 AM >
Hide Signatures
       Post #: 5
RE: Help in setting up my Cularis - 3/5/2009 3:15 AM
astroboycp
Score: 100
Last Login: 10/27/2009
Status: offline
How do you guys place your receivers as it seems quite tight in my easyglider and I am worried about internal interference?
Tam KingTiger|TigerI|Sturmtiger|Sherman|Jadgpanther|Leopard|Pershing|WSNT34|Stuart|Scania|KingHauler|Volvo|Mercedes|Tundra
Hide Signatures
(in reply to aeajr)
       Post #: 6
RE: Help in setting up my Cularis - 3/5/2009 3:16 AM
astroboycp
Score: 100
Status: offline
When are you maidening your cularis, maybe can shoot some videos and upload for us to see.
Hide Signatures
(in reply to astroboycp)
       Post #: 7
RE: Help in setting up my Cularis - 3/5/2009 6:36 PM
fireforthall
Score: 100
Status: offline
I have hand launched it on flat ground to get is set up but am waiting for my high start to arrive. If the 50mph wind would stop I would go hand launch again. I will see what I can do for a video once I sling it.
Hide Signatures
       Post #: 8
RE: Help in setting up my Cularis - 6/29/2009 3:27 AM
Serafintirado
Score: 100
Last Login: 10/12/2009
Status: offline
Crash my Cularis a few time. Ripped nose off, broke all wing servo, lost rudder in flight. Dog lunch, But she a hard bird to kill. Watch my video on DOG CHASE CULARIS and CRASH CULARIS . What is under the hood, 900K motor, 40amp ESC, All medal gear servos ( replacement of the one I broke HS55 AND HS81), 10BEC, one Gyro for the roll, just to smooth thing out. All from Hobby City for under 100 USA dollars not including cularis, Battery 2100, 20C from hobby city 18$, OH and lots of white Duct tape. Those strip on the wing and tail are not paint, they are color duct tape.
http://www.youtube.com/watch?v=YRoD40fs1zw Warning this Video is not for the weak in heart.
http://www.youtube.com/watch?v=GYI-uZoLMNc After repair, I show how to replace wing servo and what not to do for wing connectors.
Hide Signatures
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.578RCU1
