RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System
Page: <<   < prev  174 175 [176] 177 178 179 180 181 182 183   next >   >>
Login
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 7/25/2012 4:34 AM
wkevinm
Score: 100
Last Login: 6/17/2013
Status: offline
I use channel 7 in a number of airplane models to actuate an airplane release mechanism (common for all planes). A couple weeks ago I was out and found that the mechanism was reversed, such that when I use switch (H), which is spring loaded to actuate the mechanism it was reversed from before and released as soon as I powered it up, as oppsed to when I activated the switch. I since have checked out 4 other models programs and the same thing. I have had to go into the transmitter and change all settings from reverse to normal.
Something changed, and I am not real sure what it was, the only thing that makes sense is that tjhis may coincide with the update of a number of recievers, TX and module to the latest firmware from the earliest firmware?
When I set switch H to the relaxed position and then move to the on position (against the spring) the servo moves in a clockwise rotation, looking down on the servo. Can anyone tell me if this is normal?
I am not aware of any other changes to any other channels I am using (basic 4 channels), but have not checked beyond that.
In my mind I need to know what happened since this mechanism releases the airplane from the ground at a full throttle setting, and although I have a failsafe buit in not knowing this could have caused some trouble.
Thanks in advance for any insight to the issue.
Hide Signatures
(in reply to Michel)
       Post #: 4376
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 7/25/2012 11:54 AM
JIMF14D
Score: 104
Last Login: 6/16/2013
Status: offline
Do you have a failsafe set so that the switch goes to release with TX off and RX on? Do you always turn the
TX on first?
If it is changed, reprogram it the the way you want it and see if it works correctly. There have not been any recent changes that I know of.
Jim D
Hide Signatures
(in reply to wkevinm)
       Post #: 4377
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 7/25/2012 2:53 PM
wkevinm
Score: 100
Status: offline
The mechanism I speak of can be found by following this link, this may describe it better than my earlier description. I would not suggest this system to everyone, you have to be aware of the reason for certain steps and understand the consequences, my use sequence prevented a bad situation with the change in channel direction. This mechanism has worked very well for some time now.
http://www.rcuniverse.com/forum/m_9840395/anchors_9840395/mpage_1/key_/anchor/tm.htm#9840395
My main point was my surprise that a channel operation had changed or reversed. When I powered up the mechanisms receiver from behind the plane it released the plane, and I had to quickly take off from that position.
As mentioned before there were no changes to the main 4 channels, and this one caught me by surprise, I had not ground checked it as I do with the main channels. I have gone and reprogrammed the TX and all is well once again. This is a heads up to me that after any firmware update either by myself or factory the settings may change, and need to be confirmed.
wkevinm
Hide Signatures
(in reply to JIMF14D)
       Post #: 4378
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 7/25/2012 3:58 PM
Whistling Death
Score: 150
Status: offline
So is Hitec ever going to break the 9 channel threshold?
_____________________________
Blake
CORSAIR Brotherhood Lucky #13
Hide Signatures
       Post #: 4379
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 7/25/2012 9:31 PM
A.T.
Score: 186
Last Login: 6/18/2013
Status: offline
quote:
ORIGINAL: wkevinm
rotation, looking down on the servo. Can anyone tell me if this is normal? I am not aware of any other changes to any other channels
There are repeated instructions within the manual and elsewhere that following any firmware change
to verify all mixes and switches before next usuage, especially during each range check.
A9 manual was written at the time of V1.03. Because firmware may have changed since the time
their new equipment was manufactured shipped and sold, it is a pity retailers do not think to advise
new owners of all Hitec 2.4GHz systems to peruse:
Hitec RCD USA - Support page and read at least the page headed:
2.4GHz Firmware & Software Updates
together with the RC Universe Support Forum Sticky, updated on an almost daily basis being
built up from the worldwide knowledge base, and also highlights all known new manual pages,
changes and alerts:
Hitec USA Support Forum Sticky:
Aurora 9, AFHSS Spectra Modules, Optima Transceivers, Minima Receivers
& Telemetry
- FAQ & Undocumented Features
- Mixes, Setups,Tips. {Individual Links often updated}          e.g.
. Hitec HPP-22 2.4GHz Programmer - Manual, FAQ - How to Install & Use (with screenshots).
"2. Check all Model Functions. Aurora 9 programming is so flexible that no firmware designer could ever envisage
and take into account all the possible user settings and ensure that absolutely none will be effected during an upgrade
and still get the updates out in a timely cost effective manner. (especially free upgrades..)
Monitor screen assists check of each model.
Another reason recheck all functions each model is essential after an upgrade"
. AFHSS - ID_Setup (also known as Binding or Linking) & Range Test Procedure
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
R/C hobby consultant for various companies
Hide Signatures
       Post #: 4380
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 7/25/2012 9:47 PM
JIMF14D
Score: 104
Status: offline
What am I missing?
You have a safety system or safety system start up approach where you start the plane in the "launcher" and things are live and then you turn on the radio control system to operate it? And you find out the system is not working correctly or is unsafe by watching the plane leave the the launcher to your great suprise?
Sounds backwards to me!
Jim D
Hide Signatures
       Post #: 4381
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 7/25/2012 9:51 PM
wkevinm
Score: 100
Status: offline
and how would you do it?
Hide Signatures
       Post #: 4382
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 7/25/2012 10:07 PM
rs402931
Score: 100
Status: offline
I guess I would check the operation of that "unit" before i even do the preflight check on my plane.  things can and do go WRONG !
Bob S
Hide Signatures
       Post #: 4383
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 7/25/2012 10:20 PM
JIMF14D
Score: 104
Status: offline
Speaking in general terms and not relative to your specific design which I know nothing about I would handle it like any glow plane which I was going to prep to fly. I check the plane voltage and all controls from the TX, then I start the plane and recheck the controls while it is on the safety bench. Then I pick it up and fly it.
I would not start the engine or put the plane on the launcher until: I would fire up the tx and rx and then put the launcher in the loaded position with no plane on it. I would then release the launcher with the TX. If every thing looked ok then I would leave the TX and RX on, reset the launcher to the armed postion. Start the plane,  set it on the launcher and confirm that the launcher was holding it before I let go of it. Then I check my plane controls again, check the flying area for clear space,, yell "taking off" and release the launcher using the TX switch.
Good luck
Jim D
Hide Signatures
(in reply to rs402931)
       Post #: 4384
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 7/25/2012 10:57 PM
wkevinm
Score: 100
Status: offline
thanks
Hide Signatures
       Post #: 4385
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 7/26/2012 3:46 AM
udet1918
Score: 100
Status: offline
Okay guys here's a poser. I installed a 7 channel receiver in my Nieuport 17, went to do a range test on low power got to about 30' and nothing. The manual says 30 meters or 100'. Now I removed a hatch and dangled the antenna out of the model and tried again. This time whenever the antenna was in sight the range test was fine but when walking around the model whenever the antenna was hidden by the model I couldn't go past 30'. The model itself is traditional construction, Ply, Balsa etc. and covered with silver solartex. When the receiver and antenna are in postion and the hatch closed the receiver is surrounded by silver solartex. All components have been upgraded to latest version all batteries fully charged. Thoughts???
Ron
Hide Signatures
       Post #: 4386
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 7/26/2012 4:35 AM
A.T.
Score: 186
Status: offline
quote:
ORIGINAL: udet1918  Okay guys here's a poser. I installed a 7 channel receiver in my Nieuport 17, went to do a range test on low power got to about 30' and nothing. The manual says 30 meters or 100'. Now I removed a hatch and dangled the antenna out of the model and tried again. This time whenever the antenna was in sight the range test was fine but when walking around the model whenever the antenna was hidden by the model I couldn't go past 30'. The model itself is traditional construction, Ply, Balsa etc. and covered with silver solartex. When the receiver and antenna are in postion and the hatch closed the receiver is surrounded by silver solartex. All components have been upgraded to latest version all batteries fully charged. Thoughts???Ron
Silver Solartex conatins massed metal particles and is an effective shield with both 35<72MHz.and
with 2.4GHz. The antenna tip must exit the fuselage, refer the guidance under "Helicopter notes" and
"Sailplanes & Carbon Fibre Fuselages"
below
. Optima Transceiver (RX) - Installation RX & BODA Antenna FAQ,
Alan T.
Hide Signatures
(in reply to udet1918)
       Post #: 4387
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 7/26/2012 9:49 AM
udet1918
Score: 100
Status: offline
Thanks AT. Problem is the model has flown on 72 mhz for it's entire life, well over 10 years, with no radio problems and this includes having the whole of the antenna enclosed in the model. As I stated above the 7 channel receiver was tested with the antenna dangling from the model and whenever it was shielded by the airframe walking around radio contact was lost. So even if the antenna is exposed as you suggested there will come a time during flight that it will become shielded by the airframe resulting in signal loss. Are we saying here that a model cannot be painted silver if we are to use the Aurora 2.4 radio?
Hide Signatures
(in reply to A.T.)
       Post #: 4388
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 7/26/2012 10:56 PM
A.T.
Score: 186
Status: offline
quote:
ORIGINAL: udet1918   Thanks AT. Problem is the model has flown on 72 mhz for it's entire life, well over 10 years, with no radio problems and this includes having the whole of the antenna enclosed in the model. As I stated above the 7 channel receiver was tested with the antenna dangling from the model and whenever it was shielded by the airframe walking around radio contact was lost. So even if the antenna is exposed as you suggested there will come a time during flight that it will become shielded by the airframe resulting in signal loss. Are we saying here that a model cannot be painted silver if we are to use the Aurora 2.4 radio?
If PPM was used, then would expect similar result with 2.4GHz.. PCM does mask problems seen by PPM but could later bite without warning as seen with flying wires and petrol powered models.
How was the 2.4ghz antenna tip placed within the model? if close and parallel to any metal, CG or switch harness etc, it will be effected. and if antenna tip under model then ground effect will likely come into play during range tests,refer sub section
"Receiver Operating Range, Range Test & Range Problem Solving" on my webpage. In brief, any Range test should be performed with antenna clear of the ground to at least waist height as in ID Setip & Range test procedures (previous post). Please exit the tip of the antenna from top of model and try the range again - works well with CF models.
2.4GHz FAQ
"Q. How do I position my BODA antenna (s)?
 A. In most cases this placement is not critical. A good rule is to keep the antenna away from metal objects and the power wires as much as possible.  If using the Optima 9 the optimum placement is 90 degree from each other also following the guidelines previously mentioned."
Previous threads which discuss rf and metal coated models:
2.4GHz Rx and metallic covering, a problem?
Glitch-free receiver instalation in aluminum covered fuselage
In need, suggest email direct, with photo of installation:
Hitec Warranty & Service
Note: Hitec USA only services North/South America and Canada. (- Closed Weekends)
• If you are from a country that is outside North and South America, please contact the
Hitec distributor in your country for service.
Alan T.
Hide Signatures
       Post #: 4389
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 7/28/2012 1:36 AM
udet1918
Score: 100
Status: offline
quote:
ORIGINAL: A.T.
''Receiver Operating Range, Range Test & Range Problem Solving'' on my webpage. In brief, any Range test should be performed with antenna clear of the ground to at least waist height as in ID Setip & Range test procedures (previous post). Please exit the tip of the antenna from top of model and try the range again - works well with CF models.
2.4GHz FAQ
''Q. How do I position my BODA antenna (s)?
 A. In most cases this placement is not critical. A good rule is to keep the antenna away from metal objects and the power wires as much as possible.  If using the Optima 9 the optimum placement is 90 degree from each other also following the guidelines previously mentioned.''
Alan T.
Okay the problem has been discovered. The Receiver was bad. Changed it out for another and all problems vanished. Low power range check resulted in more than 2x the recommended distance with no signal loss from any angle with the antenna fully enclosed in the model and surrounded by the silver solartex. What bothers me is the receiver was NIB. Never used in a model just upgraded to newest firmware.
Ron
Hide Signatures
(in reply to A.T.)
       Post #: 4390
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 8/7/2012 10:59 PM
PT19
Score: 100
Status: offline
I have tryed to follow this post for a while now I need some simple help. Flaperons 5/8" down with 1/8" up elevator mixed. Need to keep it easy. I love my 9 but sometimes I let it get to me. Thanks.
Hide Signatures
       Post #: 4391
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 8/7/2012 11:41 PM
MikeMayberry
Score: 104
Last Login: 6/13/2013
Status: offline
Use the "Landing" mix.
Mike.
Hitec RCD Rep
http://www.hitecrcd.com
Hide Signatures
(in reply to PT19)
       Post #: 4392
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 8/8/2012 2:41 AM
PT19
Score: 100
Status: offline
Mike you say landing I don't find anything about landing mix. Do you mean launch in the glid ?
Hide Signatures
(in reply to MikeMayberry)
       Post #: 4393
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 8/8/2012 5:14 AM
A.T.
Score: 186
Status: offline
quote:
ORIGINAL: PT19    Mike you say landing I don't find anything about landing mix. Do you mean launch in the glid ?
. Aurora 9 - Flap to Elevator - Mix Set up.
. Aurora 9 - Flap (Landing) Mix see also sailplane below
and more under Hitec USA Support Forum Sticky:
& Telemetry
Alan T.
Hide Signatures
(in reply to PT19)
       Post #: 4394
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 8/8/2012 5:17 AM
boothg-3
Score: 100
Last Login: 6/6/2013
Status: offline
I too had an aux. channel used with a switch reversed after updating the transmitter , module and reciever
just figure it was reset to default setting after updating, the gimbals were not affected
Hide Signatures
(in reply to PT19)
       Post #: 4395
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 8/9/2012 12:23 AM
Michel
Score: 123
Status: offline
Hi
I hope everyone is have a wonderful summer ,............. mine is better than I can ever expect
I beleive that this question has already been asked , but I cann,t seem to find it .
I friend of mine has an Aurora 9 , which he has resently purchased . When he turns on the transmitter , there,s nothing on the screen . Is there a remidy for this , like redown-loading the transmitter .
Any help would be appreciated .
Michel
Hide Signatures
(in reply to boothg-3)
       Post #: 4396
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 8/9/2012 12:26 AM
PT19
Score: 100
Status: offline
Thanks Mike I an slow but I knew the 9 would make it simple.
Hide Signatures
       Post #: 4397
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 8/9/2012 12:58 AM
Michel
Score: 123
Status: offline
Hi
I believe that this question has already been asked , but I cann,t seem to find it .
I friend of mine has an Aurora 9 , which he has recently purchased . When he turns on the transmitter , there,s nothing on the screen . Is there a remedy for this , like re down-loading the transmitter .
Michel
Hide Signatures
(in reply to PT19)
       Post #: 4398
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 8/9/2012 1:20 AM
A.T.
Score: 186
Status: offline
quote:
ORIGINAL: michel gravelle
Hi  I hope everyone is have a wonderful summer ,............. mine is better than I can ever expect
I friend of mine has an Aurora 9 , which he has recently purchased . When he turns on the transmitter , there,s nothing on the screen . Is there a remedy for this , like re down-loading the transmitter .Any help would be appreciated . Michel
Has been reported a few times, generally relating to:
Aurora 9 - Off/On Switch problem? A9 Auto Saves (flash) each session's programming & trim changes on shutdown.
Allow time to complete task before switching on again.
May also occur for no apparent reason, perhaps bad battery connection, but above still works.
Alan T.
Hide Signatures
       Post #: 4399
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 8/10/2012 3:15 AM
RandyP
Score: 100
Last Login: 10/6/2012
Status: offline
Hi All,
I have just updated my A9 & Module to the latest & greatest updates. I have just linked the Optima 9 per the instructions. Now when I turn on the Trans & Rcvr. The module keeps beeping> This is what it says on the instructions, but how do I stop the beeping??
Randy
Hide Signatures
(in reply to A.T.)
       Post #: 4400
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.766RCU1
