RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Futaba 18MZ - RTF
Seller:  Newgadgets
Details:   $2,900.00   |  5/13/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 6/16/2009 7:49 AM
Meyer1811
Score: 100
Last Login: 3/16/2011
Status: offline
I would agree with your sources Mike.
In fact I have a hunch that the DX7 got its start in a JR lab since it resembles the JR radios so closely.
DSM2 support above 7 channels is provided by Spektrum 2.4GHz modules for JR and Futuba.
Also, lack of a model match is not a show stopper for me, it just mean it is easier to swap receivers across different planes an long as you are careful to select the correct airplane on the Aurora.
I think I will hold off buying or replacing any Spektrum gear.
John
Hide Signatures
(in reply to MikeMayberry)
       Post #: 76
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 6/18/2009 9:53 AM
MikeMayberry
Score: 104
Last Login: 5/10/2013
Status: offline
Aurora Video Walkthough here: http://www.rcuniverse.com/forum/m_8861187/anchors_8861187/mpage_1/key_/anchor/tm.htm#8861187
Mike
_____________________________
Hitec RCD Rep
http://www.hitecrcd.com
Hide Signatures
(in reply to Meyer1811)
       Post #: 77
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 6/18/2009 6:12 PM
nzak
Score: 100
Last Login: 2/4/2012
Status: offline
Thanks for the vids, Mike. Very informative. I am sold on it for sure now.
Hide Signatures
       Post #: 78
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 6/18/2009 7:50 PM
bigedmustafa
Score: 134
Last Login: 5/16/2013
Status: offline
Wow!  That's a pretty impressive demo.  The Aurora looks very user friendly for folks not used to programming a computer radio.
To a tree, balsa wood and MonoKote taste just like chicken!
Hide Signatures
(in reply to nzak)
       Post #: 79
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 6/24/2009 6:08 AM
MikeMayberry
Score: 104
Status: offline
http://www.rcuniverse.com/forum/m_8861187/tm.htm
New Heli Set up video posted.
Mike.
Hitec RCD Rep
Hide Signatures
(in reply to bigedmustafa)
       Post #: 80
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 6/24/2009 8:40 PM
HLANG
Score: 100
Last Login: 9/26/2011
Status: offline
Mike.
Is there a chance that Hitec release a new Aurora 12 ch. radio?
Aurora 9 is wonderfull BUT:
1. Could be a full 2.4GHz dedicated radio
2. 12 ch full proportional
3. Be compatible with MicroSD or similar storage cards to expand memory and change and share model profiles, altough we can connect it to PC
4. A color LCD screen (yes, it makes a big difference to our eyes)
5. If possible, a Bluetooth or IR port to connect it to a PC.
Aurora 9ch radio uses a cable attached to 2.4module to the transmitter.
I am concerned about damage to this cable while using this radio.
As a pro class radio, a 12ch system could be only 2.4Ghz dedicated.
Congratulation to Hitec people.
Aurora is a new concept, a new step forward in RC transmitters.
Best Regards
Henrique
Hide Signatures
       Post #: 81
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 6/25/2009 12:07 AM
tadawson
Score: 100
Last Login: 4/24/2013
Status: offline
Myself, I see the fact that they have *NOT* locked it in to 2.4, and still give the end user flexibility to be a huge strength! Don't change a thing, unless you want to add back in 50MHz support!
- Tim
Hide Signatures
(in reply to HLANG)
       Post #: 82
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 6/25/2009 2:09 AM
MikeMayberry
Score: 104
Status: offline
Anything is possible, but we're focused on the Aurora 9 at this time. Who knows what the future will bring?!?!?
Mike.
Hitec RCD Rep
Hide Signatures
(in reply to tadawson)
       Post #: 83
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 6/25/2009 4:25 AM
Meyer1811
Score: 100
Status: offline
Hey Mike,
As long as people are putting in wish-lists: I think OLEDs would be great for a R/C transmitter. I have fits with my LCD when I am wearing my polarizing sunglasses (which in Arizona it pretty much any time the sun is up).
For now I would be happy seeing the Aurora make its planned shipping dates and get the 6 ch receivers to market.
BTW: is any size & weight info available for the Aurora compatible receivers?
John
Hide Signatures
       Post #: 84
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 6/25/2009 6:42 AM
MikeMayberry
Score: 104
Status: offline
Receiver info on page 9. http://www.hitecrcd.com/2009_Full_Catalog.pdf
Mike.
Hitec RCD Rep
Hide Signatures
       Post #: 85
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 6/26/2009 4:43 AM
Gungadin
Score: 115
Last Login: 3/20/2013
Status: offline
I think Hitec did their home work on the BODA (boosted omni-directional antenna) deal. I always believed a system that had to have 3 & 4 recievers and sattelites had an inherent design flaw. Me thinks Hitec did it right if they can get away with only one antenna on the reciever. It would be nice though to have a reciever with connections for higher current batteries something like JR has done, since the standard connector is only rated for 3 amps and sometimes you have to use two or more into the reciever so as to not overload a single connector. It's long over due.
Hide Signatures
       Post #: 86
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 6/27/2009 5:04 AM
MikeMayberry
Score: 104
Status: offline
One more fact that might be of interest as of late... the Optima line of receivers will handle up to a 2S unlegulated lipo to power the servos and all the way up to 6S in the SPC port to power the RX separately.
New Data Transfer video!
Mike.
Hitec RCD Rep
Hide Signatures
(in reply to Gungadin)
       Post #: 87
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 6/27/2009 5:27 AM
Gungadin
Score: 115
Status: offline
Mike What kind of connector on the Optima RX'rs ? I thought they took the standard type connector, which as I noted earlier is only rated for 3 amps.
Hide Signatures
       Post #: 88
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 6/27/2009 6:33 AM
nzak
Score: 100
Status: offline
How many 3-position switches?
Hide Signatures
       Post #: 89
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 6/27/2009 8:20 AM
MikeMayberry
Score: 104
Status: offline
The bus can handle well over 10A and the 9CH RX has two power ports for the servos. Typically you are fine with up to 6 7955's or similar with a single battery. Powering the RX separately through the SPC (Suplimental Power Connection) allows for even more headroom.
Switches/ Adjusters:
(2) 3 pos
(5) 2 pos
(1) momentary.
(2) Sliders
(3) Digi Adjusters.
Fully assignalble to anything.
Mike.
< Message edited by MikeMayberry -- 6/27/2009 8:25 AM >
Hitec RCD Rep
Hide Signatures
(in reply to nzak)
       Post #: 90
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 6/30/2009 4:37 AM
Gungadin
Score: 115
Status: offline
quote:
ORIGINAL: MikeMayberry
(2) 3 pos
(5) 2 pos
(1) momentary.
(2) Sliders
(3) Digi Adjusters.
Mike.
OK, so what kind of connectors that plug into the Rx can handle 10 amps ?
< Message edited by Gungadin -- 6/30/2009 4:50 AM >
Hide Signatures
       Post #: 91
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 7/1/2009 5:26 PM
ksh243
Score: 100
Last Login: 12/29/2009
Status: offline
Ok, so here it is July 1. Is there a better idea on when my aurora 9 will be arriving at my local hobby shop? I have a plane waiting for it. I pre-ordered the 9 channel rec with servos version. Also, plans on the release date for the telemetry sensors and mod? Will all the sensors (rpm, temp, fuel, gps) be released at once? Or will it be a part here and there? thanks
Hide Signatures
       Post #: 92
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 7/1/2009 10:55 PM
WILDBILL M
Score: 100
Last Login: 9/5/2012
Status: offline
KSH243 - - Mikes Post No. 57 dated 6/30/09 mentions that he will be in Korea this week - but doesn't say exactly for how long. It may still be sometime till we get our new equipment. Bill M.
Hide Signatures
(in reply to ksh243)
       Post #: 93
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 7/2/2009 12:52 AM
WILDBILL M
Score: 100
Status: offline
Tower Hobbies just up-dated the expected availability dates on their Web Site Check em out - - Mid to Late July now HMMM
Hide Signatures
(in reply to WILDBILL M)
       Post #: 94
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 7/2/2009 2:46 AM
ksh243
Score: 100
Status: offline
quote:
ORIGINAL: WILDBILL M
Saw that. Its what prompted my question really. Wondering how many times it will change. . Old radios are about to go to another home and I may be without very soon.
Hide Signatures
       Post #: 95
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 7/2/2009 3:11 AM
nzak
Score: 100
Status: offline
I know the feeling, I have been without for over a month now
Hide Signatures
       Post #: 96
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 7/21/2009 8:34 PM
Minnreefer
Score: 195
Last Login: 5/19/2013
Status: offline
I have a couple of questions. Any update on when it will hit the stores? Do you have any stats on latency? The new Airtronics looks pretty fast, how does the Hitec compare?
Tiger 2 brotherhood #14
The Common flyer, best of the lousiest, and lousiest of the best.
Hide Signatures
(in reply to nzak)
       Post #: 97
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 7/21/2009 8:57 PM
MikeMayberry
Score: 104
Status: offline
The Aurora is still slated for late August delivery. As I have mentioned in the past... the 7CH version will be the first available; the 6CH,9CH and 72Mhz versions will be at least 30 days behind. It's not a good idea to rely on Tower for delivery dates.
Sorry, I don't have the specific latency #'s, but everyone that has flown with it says if feels quick and connected. This will not be an issue... I really think people put too much in the #'s!
The telemetry items are due before the end of the year.
Mike.
Hitec RCD Rep
Hide Signatures
(in reply to Minnreefer)
       Post #: 98
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 7/21/2009 9:01 PM
Minnreefer
Score: 195
Status: offline
Cool
Hide Signatures
       Post #: 99
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 7/24/2009 10:16 AM
Alex7403
Score: 126
Last Login: 3/27/2012
Status: offline
Mike, where the Aurora 9 is made country of origin?
what kind of charging jack it has is it like futaba?
i'm considering the Aurora 9, i really dont like how the 6EX feels nor the price of the 10CAG Rx's.
Alex
< Message edited by Alex7403 -- 7/24/2009 10:29 AM >
Ultra Sport Brotherhood #3.
Ya know, a cat is longer from head to tail than from tail to head.
Hide Signatures
       Post #: 100
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.781RCU1
