RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System    Gallery
Logged in as Guest
Users viewing this topic: rhd-RCU, udet1918, Propworn
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 5/17/2009 11:43 PM
vasek
Score: 147
Last Login: 5/23/2013
Status: offline
thats the external antena link to the module like spektrum modules
_____________________________
Remember: Speed is life!
Hide Signatures
(in reply to Alex7403)
       Post #: 26
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 5/18/2009 2:08 AM
MikeMayberry
Score: 104
Last Login: 5/21/2013
Status: offline
Yes, just push and hold the icon as shown in the picture.
Alex7403- Hitec 2.4Ghz receivers will start at $49.99 for the 6Ch, then $69.99 for the 7Ch and only $99.99 for the top of the line 9Ch.
Since the Aurora is module based to allow the use of 72Mhz as well the 2.4Ghz antenna is run externally.
Mike.
Click to see fullsize image.
Click for fullsize
Hitec RCD Rep
http://www.hitecrcd.com
Hide Signatures
(in reply to Jim Holloman)
       Post #: 27
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 5/18/2009 8:22 PM
Eplane65
Score: 105
Last Login: 2/17/2013
Status: offline
I only wish that this new Hitec radio came out a year ago, because I've already bought JR stuff with many Spektrum receivers.  I used to have an Optic 6 and it was so user friendly when programming.  The JR 9303 is impossible to figure out and I thought I was a little computer savvy.  At least Hitec povides the features that I have suggested to them: 9 channels, 30 model memory.  This is a good deal.
Hide Signatures
       Post #: 28
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 5/18/2009 10:10 PM
fizzwater2
Score: 124
Status: offline
Mike - does it have cross trim capability?
No matter where you go, there you are!
Hide Signatures
(in reply to Eplane65)
       Post #: 29
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 5/19/2009 3:19 AM
aa2dd
Score: 106
Last Login: 5/24/2013
Status: offline
  Mike ... is the Aurora 9 going to be available in 72 MHz?
Bruce
aa2dd
Hide Signatures
(in reply to MikeMayberry)
       Post #: 30
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 5/19/2009 2:22 PM
Pippin
Score: 103
Status: offline
...the price for the Tx is 409,- in Germany. But you can not buy it yet.
Here is a video link to the but unfortunately in some German dialect:
http://www.airmix.de/modules/forms_press/files/a28d4e292501c26.wmv
Hide Signatures
       Post #: 31
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 5/19/2009 2:25 PM
Pippin
Score: 103
Status: offline
Wow, the Tx has got a fuel gauge!
Hide Signatures
(in reply to Pippin)
       Post #: 32
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 5/20/2009 8:55 PM
MikeMayberry
Score: 104
Status: offline
fizzwater- Cross trims... I can't find an option for that?
aa2dd- Yes, there will be a 72mhz version but the most popular version that the shops will stock will be the 2.4gz w/7ch RX. You can always add the Spectra Pro Synthesized module to it to operate your 72mhz stuff.
Mike.
Hitec RCD Rep
Hide Signatures
       Post #: 33
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 5/20/2009 10:12 PM
fizzwater2
Score: 124
Status: offline
Darn, that was the feature I liked best on my old pro-line radio.  Especially with the elevator trim located in the upper left of the case, where your left thumb had no trouble finding it.  It was great being able to reach the trim levers without having to let go of the right stick (mode 2).  Nothing has been quite as convenient since.
Hide Signatures
       Post #: 34
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 5/21/2009 1:22 AM
beenie
Score: 105
Last Login: 3/19/2012
Status: offline
Will the TX accept regular 72mhz single frequency modules or is it just the Spectra?
Ben
Hide Signatures
(in reply to fizzwater2)
       Post #: 35
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 5/21/2009 1:26 AM
djlyon
Score: 100
Last Login: 10/3/2012
Status: offline
Fizz ,That's just cuz you race pylon.  Boy I sure would like that feature for trimming a 428.
< Message edited by djlyon -- 5/21/2009 2:53 AM >
I never met an engine I didn''t like.
Of the things I''ve lost I miss my mind the most.
Hide Signatures
       Post #: 36
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 5/21/2009 7:31 AM
MikeMayberry
Score: 104
Status: offline
The Spectra Pro is the only compatible 72Mhz module; It will synthesize any channel and is selectable through the software. Existing modules are not compatible.
Mike.
Hitec RCD Rep
Hide Signatures
(in reply to djlyon)
       Post #: 37
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 5/21/2009 9:57 AM
tadawson
Score: 100
Last Login: 4/24/2013
Status: offline
Well, that's a bummer . . . . I was under the impression that both Hitec and Futaba RF modules would fit, and thus correct the omission of 50MHz support on the Aurora.  Since this now means that the Aurora would appear to have no support path for 50MHz, I just found reason to take it off my candidate list . . . . . drat!  Looked good otherwise . . . .
- Tim
Hide Signatures
       Post #: 38
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 5/21/2009 10:14 AM
MikeMayberry
Score: 104
Status: offline
What's the advantage of 50mhz... you have a bunch of RX's?
Mike.
Hitec RCD Rep
Hide Signatures
(in reply to tadawson)
       Post #: 39
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 5/21/2009 6:40 PM
zx32tt
Score: 110
Status: offline
Can I use the fm module from my Futaba 9C in the Aurora 9 and use all my 72mhz fm receivers, or do I have to use a specific Hitec fm module?
zx32tt
Hide Signatures
       Post #: 40
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 5/21/2009 6:44 PM
BuschBarber
Score: 104
Status: offline
You can only use the Hitec Spectra Pro Synthesizer RF Module. This allows you to Dial In any 72Mhz channel. It will work with what ever 72Mhz Rx's are compatible with the Hitec Tx.
Rich
byronf16@gmail.com
Hide Signatures
(in reply to zx32tt)
       Post #: 41
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 5/22/2009 8:38 AM
IJAA
Score: 100
Last Login: 10/12/2009
Status: offline
I really like this radio and I also really want triple rates. It seems many people want triple rates. So why would you guys choose to leave out triple rates on the Ailerons, elevator, and rudder?
Hide Signatures
(in reply to BuschBarber)
       Post #: 42
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 5/22/2009 9:20 AM
tadawson
Score: 100
Status: offline
quote:
ORIGINAL: MikeMayberry
Mike.
Requires a license to be there, so no boneheads. No interference - not a shared band, exclusive allocate to HAM radio so no chance of park flyer shootdowns. None of the 2.4G bogosity being in a very crowded band with insane numbers of part-15 (as well as unlicensed) stuff that is of very low quality and questionable spectral purity, not to mention the far more quirky propagation with regard to nulls and shadowing on 2.4G. And on 50, with my HAM license, I can legally work on anything I own - none of the outdated frequency change rules that plague 72.
Frankly, I regard 50MHz as more reliable and suitable for my needs than anything 2.4G . . . . and yes, I have a number of receivers as well, but that isn't the primary reason.
I just have no desire to be a 2.4G lemming at this time - it offers me nothing better than what I have now on 50 . . . .
- Tim
< Message edited by tadawson -- 5/22/2009 9:23 AM >
Hide Signatures
       Post #: 43
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 5/22/2009 9:39 AM
MikeMayberry
Score: 104
Status: offline
IJAA- There are two three position switches that can be assigned to rates, but moreover there are eitht flight conditions that can have a specific rate assigned to each for up to 24 total on two surfaces and 16 on the other. Is that enough?
quote:
ORIGINAL: tadawson
- Tim
tadawson- Holly cow... Geek factor levels off the chart!  I am not worthy!!! Just giving you a hard time... no offence. Seriously though, you could probably adapt a Futaba 50mhz module, you just have to match up the pin outs. By the way, our 2.4 system does not suffer from the woes you describe so eloquently.
Mike
< Message edited by MikeMayberry -- 5/22/2009 9:40 AM >
Hitec RCD Rep
Hide Signatures
       Post #: 44
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 5/22/2009 9:54 AM
djlyon
Score: 100
Status: offline
Sorry Mike but unless your 2.4 system defies the laws of physics it does suffer from the woes tadawson so eloquently describes especially here in the Los Angeles  basin.
Denis
Hide Signatures
       Post #: 45
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 5/22/2009 3:46 PM
jonkoppisch
Score: 106
Status: online
Looks like a nice radio.  I fly futaba but 1 thing that I really like about the jr radio is the analog throttle trim.  I'm surprised that more manufacturers haven't done this on their new radios as it seems to be a very popular, easy option..
"Washington in their infinite wisdom has lost their marbles"
Pappy Boyington
Hide Signatures
       Post #: 46
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 5/22/2009 5:44 PM
IJAA
Score: 100
Status: offline
quote:
ORIGINAL: tadawson
- Tim
Mike
Mike,
Flight conditions help but they aren't triple rates which I do like. It does appear that for the money you guys have managed to realy do well though. That's why I am so interested. Would you elaborate on how the flight conditions work. First, how do you switch between them in flight? Second, are the settings tied into switch settings or are they independently programmed? Thanks,
John
Hide Signatures
       Post #: 47
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 5/22/2009 6:25 PM
tadawson
Score: 100
Status: offline
Soirry Mike, but as djiyon pointed out, you can't *NOT* be affected.
2.4G propagation characteristics are things you can't control - they come with the band.
The high volume of questionable part-15 devices as well as other unlicensed devices sharing the band with you you can't control - the FCC has made 2.4G a pure free for all.
I am sure that Hitec has done a good job implementing their system - I just take exception to the use of 2.4 *period* due to all the issues with the band . . . . and the constant influx of more and more stuff crowding it and raising the noise floor even more every day!
Regardign using a Futaba module, would the Aurora software run OK without seeing a "smart" module from a software point of view?
- Tim
< Message edited by tadawson -- 5/22/2009 6:30 PM >
Hide Signatures
       Post #: 48
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 5/22/2009 6:49 PM
A Betancourt
Score: 100
Last Login: 5/16/2013
Status: offline
It sure looks like a great radio, I have a question, How about the gimbals quality, are the gimbals ball bearing supported?  if so, How many ball bearings?
Thanks.
Alfredo
Hide Signatures
       Post #: 49
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System - 5/22/2009 8:21 PM
Minnreefer
Score: 195
Status: offline
That looks like a great radio, and I like that some of the recievers are affordable ( I am still on a very tight budget).  A question which you can ignore if it is too off topic, I have heard that one nice thing about 2.4 is the ability to send and receive information, such as flight info, tact etc.  is that going to be an option on this model or some models in the future?
Jon
Tiger 2 brotherhood #14
The Common flyer, best of the lousiest, and lousiest of the best.
Hide Signatures
(in reply to A Betancourt)
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.344RCU1
