Grelker -> RE: AW Ultimate 20-300 (8/14/2009 7:00 PM)
I finished mine about 2 months ago and have just finished 2 gals of breakin fuel. I'm now on 80:1 amsoil. All the reports about a great flyer are true! I had to add a little right thrust to mine with a mezjlic 22x8 prop to correct serious left pull on uplines. When I added a grade 8 washer, about 1/16 inch thick, then i needed additional downthrust as well, added one washer. This has corrected the upline. Still using the pitts muffler although i had some issues with keeping the stabilizing bracket attached to the muffler (check out this link: Troy Built. I started out with a 4-40 bolt and that would last less than 1 flight, even with loctite red. I ended up with 2, 6-32 bolts, and that seems to work well. The cowl seems to lack much clearance on the top between it and the engine mounting bolt ears. I added a little foam tape to cushion it, anyone else have this problem? bdegan - thanks for the wakeup call... btw, my AUW is 18#-6oz. I have all the vertical i need, it'll go up until i can't see it anymore
