What am I doing wrong?? (Adding fibreglass)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Beginners >> What am I doing wrong?? (Adding fibreglass)
Page: [1]
Login
What am I doing wrong?? (Adding fibreglass) - 2/26/2009 10:04 PM
gisi
Score: 100
Last Login: 5/18/2012
Status: offline
Hi folks.
I'm wondering what I'm doing wrong here.
I use the Z-Poxy PT-40 system, and 142g fibre class cloth.
I've cut a strip 4cm wide, and put it on the midsection of the wing. Before that, I removed the covering.
I used an epoxy brush to apply the epoxy onto the cloth. I noticed that the epoxy soaked the cloth, but it was not sticking to the balsa surface.
What am I doing wrong here?
Should I soak the cloth before putting it on the surface? Should I apply epoxy to the surface before laying the cloth?
_____________________________
gisi
Hide Signatures
       Post #: 1
RE: What am I doing wrong?? (Adding fibreglass) - 2/26/2009 10:07 PM
brett65
Score: 185
Last Login: 4/10/2012
Status: offline
Experiment on some scrap balsa.
No arsenal or no weapon in the arsenals of the world is so formidable as the will and moral courage of free men and women.
Hide Signatures
(in reply to gisi)
       Post #: 2
RE: What am I doing wrong?? (Adding fibreglass) - 2/26/2009 10:55 PM
coydog
Score: 100
Last Login: 5/8/2013
Status: offline
Hi gisi with your epoxy brush sread athin layer of epoxy on the bare wood then lay your glass down on the epoxy you just put on then brush on another layer of epoxy on the cloth make you put enough on to soak the cloth if its a little thicker then you want it to be take a old credit card and scrape alittle off just make sure the cloth is soaked with epoxy if you want it to real smoth take your heat gun and warm the epoxy up just be aware this speeds up the curing prosess let cure good then lightly sand as needed good luck
Hide Signatures
(in reply to brett65)
       Post #: 3
RE: What am I doing wrong?? (Adding fibreglass) - 2/26/2009 11:46 PM
jaka
Score: 158
Last Login: 5/21/2013
Status: offline
Hi!
142g glass cloth is very heavy for a .40 airplane. Two layers of 50g glass fiber is enough, and it's much better to put on several thinner layers of cloth , in a diamond shaped pattern than just one straight tape type layer.
Have you sanded the surface prior to applying the epoxy/glass fiber?
Jan Karlsson - Supplier MVVS Products
Hide Signatures
(in reply to gisi)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.688RCU1
