Straight solid shaft vs Flexishafts
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Boats >> Speed - RC Nitro Boats >> Straight solid shaft vs Flexishafts
Page: [1]
Login
Straight solid shaft vs Flexishafts - 6/11/2003 6:53:07 AM
Rendegade
Status: offline
Just wondering what the problems with both are.
I have a 7.5cc cat with a flex shaft and I wouldn't mind extracting all the power I can...
_____________________________
It's easy to fly, just throw yourself at the ground and miss!
       Post #: 1
Straight solid shaft vs Flexishafts - 6/11/2003 7:56:53 AM
AltimaT
Status: offline
The problem with a straight shaft is the U-Joints required to get the driveline parallel to the water at the prop. I true and polish my flex cable ODs to try to reduce friction some, and try to use the largest possible radius bends in the stuffing box. I would like to try piano wire like the electric guys are now using. The smaller the diameter, the less friction. Something around 3mm might work on a .45???
(in reply to Rendegade)
       Post #: 2
shafts - 6/13/2003 6:33:21 AM
hifonixs
Status: offline
i can get stainless flex shafts hich are the best of both worlds. you wont lose any power. [email]hifonixs@hotmail.com[/email]
       Post #: 3
Straight solid shaft vs Flexishafts - 6/14/2003 5:02:47 AM
izitbrokeyet
Status: offline
1.
the problem with straight shaft is you do not achieve constant rotational velocity on the prop because you have to use two universals to get to the prop. This "banging" is hard on the motor, equipment and causes energy loss.
2.
the problem with straight shaft is they suck in terms of positioning the strut where it is most needed.
3.
Flex has neither of these problems as long as you keep it lubed
       Post #: 4
RE: Straight solid shaft vs Flexishafts - 7/18/2006 5:37:18 AM
TwistedLiquid
Status: offline
FLEX shaft all the way...in R/C boats you need change for conditions...moving the prop angle is impossible on straight drive to the prop. Flex allows you to be messy on the alignment part too, but I recomend you not be...it stills has to go around. No real loss in power to prop if you get a good flex shaft.....properly match to a good shaft tube...no flop inside a tube that is to big...loss of power then...
Happy Racing....ZooM
OH YA!!! drive shaft U-Joints are for cars not boats.... Dont put car parts in your R/C...powerboat
< Message edited by TwistedLiquid -- 7/18/2006 5:38:47 AM >
James
TWISTED LIQUID RACING
       Post #: 5
RE: Straight solid shaft vs Flexishafts - 7/18/2006 2:22:58 PM
John Palica
Status: offline
Speaking from YEARS of experience with both shaft styles the flex shaft has my vote. Before flex shafts, all of our boats were hard shafts with 'U' joints to get the prop shaft angle correct. We used water quenched drill rod rather than piano (music) wire because the latter is not straight. The other problem is the quality and durability of the 'U' joints. They wobble and wear resulting in vibration and constant maintenance. If you keep a flex shaft well lubed they are almost fool proof.
John
(in reply to TwistedLiquid)
       Post #: 6
RE: Straight solid shaft vs Flexishafts - 7/18/2006 4:47:48 PM
Hydro Junkie
Status: offline
On the other hand, there are still people that use solid shaft drives in hydros. These are mainly purists, trying to set up their boats like the full sized ones. I have seen some of these set up so well that they can and do outrun the flexshaft boats
(in reply to John Palica)
       Post #: 7
RE: Straight solid shaft vs Flexishafts - 7/19/2006 11:49:15 AM
xism
Status: offline
flex flex flex..... bah! sometimes u doesnt have any choice.... u must use a solid axel
(in reply to Hydro Junkie)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.533RCU3
