Seagull Ultimate biplane 90 size    Gallery
Logged in as Guest
    Search This Thread
Printable Version
SAB Goblin 770 Helicopter - RTF
Seller:  mariogonzales
Details:   $2,500.00   |  5/14/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> Seagull Ultimate biplane 90 size
Page: [1]
Login
Seagull Ultimate biplane 90 size - 3/1/2009 9:24 PM
Bladejunkie
Score: 105
Last Login: 5/20/2013
Status: offline
Good morning all,I've got a Seagull Ultimate biplane,and two possible engines for it.My first choice is a well tested BCMA sport 26,it used to pull my USL 120 around pretty well,until I bought one of those CRRC pro 40 kits.My other choice is a brand new Saito 100 it has about a half gallon of fuel through it now on the test bench.I want enough power to do scale like aerobatics,I'm not good enough or into 3D.My USL 120 weighs about 10.5(probably more!!!) pounds so the BCMA 26 should be able to pull the Ultimate around pretty good at 9.2-10.6 pounds.Any thoughts?I would really like to hear from you guys who have used these engines in this size Ultimate.I have read all I could find here and over at RCG's.I didn't find any one who have used a gasser in this aircraft,some said they were thinking about it,but never said if they had.I'm really leaning towards the gasser,I love the ease(cheap)of gas power.
Thanks for any imput Jim.
Hide Signatures
       Post #: 1
RE: Seagull Ultimate biplane 90 size - 3/2/2009 8:59 AM
Bladejunkie
Score: 105
Status: offline
Anyone out there????
Hide Signatures
(in reply to Bladejunkie)
       Post #: 2
RE: Seagull Ultimate biplane 90 size - 3/2/2009 3:31 PM
kevinelp
Score: 100
Last Login: 1/28/2010
Status: offline
quote:
ORIGINAL: Bladejunkie
Yes
But I have a 120-ax in mine, so can't really answer your queries.
Hide Signatures
       Post #: 3
RE: Seagull Ultimate biplane 90 size - 3/2/2009 6:42 PM
daveopam
Score: 191
Last Login: 5/18/2013
Status: offline
I had a Saito 1.25 in one. For me it was underpowered. It would sport fly it fine. Most of my planes are 3D type and it just felt down on power. Hover for example would be 90% throttle. WIth a 1.00 I don't know if it would hover at all. Maybe mine was a heavy example but it was close to 13lbs. Way to much for a Saito 1.25. Your gasser might be a better option. If you go that route plane on moving the elev servos to the tail. This should help with the CG.
David
_____________________________
"You only live once. But if you do it right,once is enough."Mae West
Hide Signatures
(in reply to kevinelp)
       Post #: 4
RE: Seagull Ultimate biplane 90 size - 3/3/2009 12:05 AM
lou1947
Score: 105
Last Login: 3/7/2013
Status: offline
I have a Saito 125 on mine and it flies very well although I don't do 3d.Vertical climb is unlimited and for the type of flying that I do it is more than enough I usually fly at 2/3 throtle. If you plan to fly scale the 100 Saito would do.If you want a rocket i would use a 150 or 180 Saito or go to a 26 to 35 cc gas. I personally dont think the airframe would handle much over a 150. Hope that helps.....
Hide Signatures
(in reply to daveopam)
       Post #: 5
RE: Seagull Ultimate biplane 90 size - 3/3/2009 6:32 AM
Bladejunkie
Score: 105
Status: offline
Thanks guys,I'm going to go with the gasser.I really didn't want to use a slimer,no starters,no glo plugs,and no clean up!!!I've got all the dodads for the little gasser,so no additional cost either.All I've got to do is get it put together and go fly.
Thanks again Jim
Hide Signatures
(in reply to lou1947)
       Post #: 6
RE: Seagull Ultimate biplane 90 size - 3/3/2009 10:50 PM
meshari14
Score: 100
Last Login: 5/19/2013
Status: offline
HI there,
I have ultimate with saito 125 engine, i have a problem if i increase power to full the plane nose went down but with half power it is ok, could anyone help me please and tell me the reasons of that with solutions if possible? Thanks
Hide Signatures
       Post #: 7
RE: Seagull Ultimate biplane 90 size - 3/4/2009 1:57 AM
kevinelp
Score: 100
Status: offline
quote:
ORIGINAL: meshari14
HI there,
Sounds like too much "down thrust" on the engine mount - install a washer between the engine mount and the firewall on the two lower mount points on the firewall to reduce the down thrust, and see if it flys better.
Hide Signatures
(in reply to meshari14)
       Post #: 8
RE: Seagull Ultimate biplane 90 size - 4/1/2009 6:43 AM
vet61man
Score: 100
Last Login: 7/13/2009
Status: offline
I just picked up one of these and was also planning on going with the 120ax. What size prop do you use and how does it fly?
thanks!
Kevin
Hide Signatures
       Post #: 9
RE: Seagull Ultimate biplane 90 size - 4/1/2009 6:30 PM
daveopam
Score: 191
Status: offline
APC 17x6 on the prop. I switched back to the GB Ult and have the 1.20AX and APC 17x6 on it.
david
Hide Signatures
(in reply to vet61man)
       Post #: 10
RE: Seagull Ultimate biplane 90 size - 4/14/2009 6:51 PM
olflyr
Score: 100
Last Login: 12/31/2012
Status: offline
I have an OS 1.60FX in mine and it will nearly pull the airframe out of the Ultracote. I love it!
Hide Signatures
       Post #: 11
RE: Seagull Ultimate biplane 90 size - 4/19/2009 7:02 PM
cracker
Score: 100
Status: offline
16x8. I have 3 of these and this seems to me to be the best all around prop for that engine. I like them. I have a Goldberg Ultimate (kit) with a Magnum 91 xls and it hauls. I have the Seagull with the 120ax and it flies, speedwise, more scale like. Good combo!
Fly Fast, Fly Hard, Die Happy!
It's only bad if you can't fix it!
Hide Signatures
       Post #: 12
RE: Seagull Ultimate biplane 90 size - 4/28/2009 6:30 PM
FATBOY
Score: 100
Last Login: 5/28/2012
Status: offline
quote:
ORIGINAL: kevinelp
Yes
kevinelp
How much did you have to chop the cowl to fit the OS 120AX? IOW's will the OS 120AX fit inside the cowl w/o chopping?
Hide Signatures
       Post #: 13
RE: Seagull Ultimate biplane 90 size - 4/29/2009 3:39 AM
kevinelp
Score: 100
Status: offline
It is a bit hard to answer in text, yes I had to cut the cowl a bit - mainly to allow the muffler to poke through.
It is better describe with a pic, have a look at the pic about half way down, and also how the 120-ax mounts and the next page.
http://www.rcuniverse.com/forum/m_4713909/mpage_7/key_/tm.htm
cheers
- Kevin
Hide Signatures
(in reply to FATBOY)
       Post #: 14
RE: Seagull Ultimate biplane 90 size - 6/5/2009 8:58 PM
Connery
Score: 100
Last Login: 11/2/2009
Status: offline
How are your Ultimates flying with the engines you have chosen for them?  I'm thinking about the new Evolution 1.20 for mine.  I'm using the Evo 1.00NX on my Skyshark Edge 540 and really like how this engine runs.  After it was broken in and tuned properly, it has a really smooth idle and very good transitions from idle to WOT.
Hide Signatures
       Post #: 15
RE: Seagull Ultimate biplane 90 size - 7/13/2009 12:36 AM
Bladejunkie
Score: 105
Status: offline
Hey all,I know this thread is pretty well dead,but we maidened the Ultimate yesterday.All I can say is wow,to all who think a 26cc gas engine is not enough,your are wrong.The little BCMA26 sport is more than enough.I only wish the plane was still mine!!!For the price of this combo you can't go wrong.
Jim
Hide Signatures
(in reply to Connery)
       Post #: 16
RE: Seagull Ultimate biplane 90 size - 7/13/2009 7:28 PM
Connery
Score: 100
Status: offline
I'm planning of going with gas on mine as well.
Hide Signatures
       Post #: 17
RE: Seagull Ultimate biplane 90 size - 5/23/2011 2:33 AM
mgrande11
Score: 105
Last Login: 2/24/2013
Status: offline
I have a Saito 180 that needs a good home, will it fit in this plane?
Gravity sux
Hide Signatures
       Post #: 18
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.672RCU1
