RE: Mach 1 Laser Kit Build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> Classic RC Pattern Flying >> RE: Mach 1 Laser Kit Build
Page: <<   < prev  1 2 [3] 4 5 6 7 8   next >   >>
Login
RE: Mach 1 Laser Kit Build - 3/20/2009 10:32 PM
Pattern One
Score: 100
Last Login: 5/20/2013
Status: offline
I made a run of Mach 1, Compensator and Sweetater canopies today. Pictured is one of my vacuum forming machines and the canopies. I hope to get the shear webs installed in the wing today if time permits. More to follow.
Leo
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
"Mankind has a perfect record in aviation.
We never left one up there!"
Hide Signatures
(in reply to Pattern One)
       Post #: 51
RE: Mach 1 Laser Kit Build - 3/21/2009 5:26 AM
Pattern One
Score: 100
Status: offline
I was able to get 1/2 of the shear webs installed tonight. The rest will be completed in the next day or two. The pnuematic air lines and servo extensions will be routed and placed in the wing also.
More to follow.
Leo
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 52
RE: Mach 1 Laser Kit Build - 3/21/2009 11:08 PM
JPBIII
Score: 100
Last Login: 5/18/2010
Status: offline
Looks great, what are the dimensions of this plane. Wing span and overall length?
Hide Signatures
       Post #: 53
RE: Mach 1 Laser Kit Build - 3/21/2009 11:46 PM
Pattern One
Score: 100
Status: offline
JPBIII,
The wing span is 62"
The wing area is 725"
The overall length from the tip of the spinner to the back of the rudder is 55"
Leo
Hide Signatures
(in reply to JPBIII)
       Post #: 54
RE: Mach 1 Laser Kit Build - 3/22/2009 5:42 PM
Deadstik
Score: 100
Last Login: 5/5/2013
Status: offline
Leo,
I've got to get one of those vacuum forming machines.... but for now, the oven and the vacuum box will have to do. Looks like you're having fun getting into the kit manufacturing business. Let me know when you've got them ready.
Dan
Carolna Custom Aircraft
Hide Signatures
       Post #: 55
RE: Mach 1 Laser Kit Build - 3/22/2009 6:20 PM
Pattern One
Score: 100
Status: offline
Hi Dan,
The vacuum forming machine in the picture is fairly simple to operate. The other machine I have is much more complicated. I will be adding more classic pattern canopies over time and making other parts that can be vacuum formed. I have a web site, but not sure if I should post the address or not? Dan @ Laser technologies is very skilled at cutting the short kits. He tells me that he will be adding more classic pattern planes to his line in the future.
Leo
Hide Signatures
(in reply to Deadstik)
       Post #: 56
RE: Mach 1 Laser Kit Build - 3/22/2009 8:28 PM
ww2birds
Score: 105
Status: offline
Leo,
I think it is legal per RCU rules if someone asks.... so....
Do you have a website? We really appreciate what you are doing for these classic planes!
Dave
Hide Signatures
       Post #: 57
RE: Mach 1 Laser Kit Build - 3/22/2009 10:00 PM
rv7driver
Score: 105
Last Login: 5/16/2013
Status: offline
Leo, I sure could use one of the Sweetater canopys, any chance buying one?? Pete
the old saying in aviation is keep the dirty side down!; how Boring!
Hide Signatures
(in reply to ww2birds)
       Post #: 58
RE: Mach 1 Laser Kit Build - 3/23/2009 12:36 AM
Pattern One
Score: 100
Status: offline
Dave,
Since you asked: www.klasskotemo.com
Pete,
I will send you a PM regarding the Sweetater Canopy. No problem. Dan at Laser Technologies has had a Laser cut Sweetater for awhile. I have been building one. The parts fit is awesome.
Leo
Hide Signatures
(in reply to rv7driver)
       Post #: 59
RE: Mach 1 Laser Kit Build - 3/23/2009 12:55 AM
JPBIII
Score: 100
Status: offline
Leo,
Thanks for the info.
Hide Signatures
       Post #: 60
RE: Mach 1 Laser Kit Build - 3/23/2009 1:14 AM
Pattern One
Score: 100
Status: offline
Hi Guys,
I worked on mounting the B&D retracts today. Dan left room for you to shim the retracts to skin level if needed depending on the brand of retract you are using. I added some ply as shims on mine. After mounting the retract units I added some 1/16" balsa around them and sanded flush with the rib profiles. The 1/4" square stock was added per plans to support the sheeting over the center section under the fuse. The shear webs have been completed. Next time I will be running the air lines, servo extension wires and working on the aileron servo mounting.
Leo
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 61
RE: Mach 1 Laser Kit Build - 3/25/2009 11:20 PM
Pattern One
Score: 100
Status: offline
Hi guys,
Dan just sent me an email saying that he shipped the Mach 1 short kits today that had been ordered and paid for. I should be able to get back to work on this Mach 1 in the next day or two.
Leo
Hide Signatures
       Post #: 62
RE: Mach 1 Laser Kit Build - 3/27/2009 9:34 PM
rv7driver
Score: 105
Status: offline
Dan emailed me said mine was on the way. Dan was very accommodating, I already had the foam wing and stab, he charged me just for the fuselage,plans and canopy. Not many people would do that, all or nothing! is what a some people would say. Thanks Dan
Pete
Hide Signatures
       Post #: 63
RE: Mach 1 Laser Kit Build - 3/28/2009 1:13 AM
rv7driver
Score: 105
Status: offline
The mailman just showed up with my Mach 1 kit from Dan, WOW! is all I can say. the best laser cutting I have ever seen. The canopy is perfect, I think Leo did the canopys, one of the coolest parts is Dans business cards same stuff that the fuselage templetes. see picture. Thanks so much guys, if anybody is thinking about Dans kits, get one you will not be disapointed!!
Pete
Click for fullsize
Hide Signatures
       Post #: 64
RE: Mach 1 Laser Kit Build - 3/28/2009 3:59 AM
Pattern One
Score: 100
Status: offline
Pete,
I did make the canopies that Dan is shipping with his short kits. Post pictures of yours as you build it. I have all weekend to work on mine. Today was spent making three new Compensator plugs out of stronger material. The others were made from plaster and were too brittle. Ask me how I know.
Leo
Hide Signatures
       Post #: 65
RE: Mach 1 Laser Kit Build - 3/28/2009 11:59 PM
Pattern One
Score: 100
Status: offline
Hello Everyone,
I spent today making the remaining parts required to complete the build. Dan sent me an updated plan sheet that he sent out with his short kits. They are very detailed and spell things out clearly. The rudder parts were also completed. I detailed part of the layout on the wood showing the cross grain on the upper part of the fin. Here are a few pictures. I should have more to follow later today when some glue has dried.
Leo
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 66
RE: Mach 1 Laser Kit Build - 3/29/2009 2:14 AM
Pattern One
Score: 100
Status: offline
Hi Guys,
Finally! I now have everything I need to move forward and get this project going. I made the elevators per plans. They just need final sanding to shape the airfoil. The ailerons were cut out of 1/2" x 2" x 36" TE stock. I took some additional pictures showing everything laid out on the table. More to follow.
Leo, aka glockguy
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 67
RE: Mach 1 Laser Kit Build - 3/29/2009 2:42 AM
rv7driver
Score: 105
Status: offline
Leo, the Mach 1 is looking great! Pete
Hide Signatures
       Post #: 68
RE: Mach 1 Laser Kit Build - 3/29/2009 3:24 AM
ccpetersen
Score: 100
Last Login: 3/28/2013
Status: offline
Leo,
Could you give us an idea of the materials required over and above the short kit?
It would be helpful for some of us.
Expert in the art of making small pieces of balsa out of large pieces of balsa.
Hide Signatures
       Post #: 69
RE: Mach 1 Laser Kit Build - 3/29/2009 3:51 AM
Pattern One
Score: 100
Status: offline
ccpetersen,
I will post a list of the block sizes, stick sizes and quantites in the next day or two. Some are easy to figure out from the plans, others are not. Dan at Laser Technologies is considering drawing block templates in CAD. Not sure when he will make that decision.
Leo
Hide Signatures
(in reply to ccpetersen)
       Post #: 70
RE: Mach 1 Laser Kit Build - 3/29/2009 3:52 AM
Pattern One
Score: 100
Status: offline
rv7driver,
Pete,
Thank you for the compliment.
Leo
Hide Signatures
       Post #: 71
RE: Mach 1 Laser Kit Build - 3/29/2009 3:54 AM
Pattern One
Score: 100
Status: offline
Guys,
I am considering the following engines for the Mach 1. Your comments and ideas would be appreciated.
Webra Speed .61
OS Max .61 FSR
OS Max .61 SF
Leo
Hide Signatures
       Post #: 72
RE: Mach 1 Laser Kit Build - 3/29/2009 4:59 AM
rv7driver
Score: 105
Status: offline
Leo, got the sweetater canopy in the mail today, It looks great!! Thanks for the quick shipping also.
Pete
Hide Signatures
       Post #: 73
RE: Mach 1 Laser Kit Build - 3/29/2009 5:02 AM
Pattern One
Score: 100
Status: offline
ccpetersen,
Here is a listing of blocks and strips. This should help.
Balsa:
2 pcs: 8 5/8" long x 2 1/8" wide x 9/16" thick. Taper 9/16" down to zero at the other end so it looks like a door stop.
Top blocks, 2 pcs: 9/16" x 2" x 30 1/4". Bottom blocks under fuel tank: 2 pcs: 3/8" x 2" x 8 5/8". Front top blocks above tank: 2pcs 2 1/16" x 8 9/16 x 15/16".
Rear fuse block, 1 pc 7" x 2" x 15/16". Botom cowl blocks, 2 pcs 3 11/16" x 2" x 15/16". Top cowl block, above/around engine: 5" x 3 1/4" x 7/8" taper from 7/8' to zero, looks like a door stop. Filler blocks between F1 & F2: 2 pcs 8 5/8" x 5/8" x 5/16". 2 pcs: triangular stock: 1/2" x 8 3/8".
3/8" Sqaure stock: 2 pcs: 17 7/8", 2 pcs: 12 5/8", 2 pcs: 30 1/2". Tri stock: 2 pcs: 3/8" x 36".
1 pc: 1/8" x 1/4" x 36". Fuse bottom block: 3/8" x 3 1/4" x 15 5/8".
1 pc: 1/4" x 3/8" x 12. The front cowling blocks are 3/8" sheet. Wing tip blocks: 2 pcs: 1" SQ x 8 3/4". Stab tip blocks: 2 pcs: 1/2" x 5/8" x 4".
Hardwood:
Wing Hold Down Blocks: 2 pcs: 1/4" x 3/4" x 3 5/16"
1/2" Hardwood dowel to support wing hold down bolts.
This should give you a good start.
Leo
Hide Signatures
       Post #: 74
RE: Mach 1 Laser Kit Build - 3/29/2009 5:21 AM
ccpetersen
Score: 100
Status: offline
Leo, many thanks!
Hide Signatures
       Post #: 75
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.063RCU1
