My TNX gasser
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> My TNX gasser Page: [1]
Login
My TNX gasser - 3/2/2009 2:17 AM
CustomTamiyas4Life
Score: 105
Last Login: 2/26/2010
Status: offline
Finally my tnx is almost done. Running on a 27cc stihl engine, this thing has some serious torque. Let me know what you think.
_____________________________
TNX gasser/Brushless/4s revo 3.3/stampede with nearly nothing stock left/homemade lexan 2wd truck
Hide Signatures
       Post #: 1
RE: My TNX gasser - 3/2/2009 2:32 AM
jikkuria
Score: 105
Last Login: 3/16/2010
Status: offline
looks real nice, how much did it cost, and where did you get the stihl from?
some say Revo, some say Savage, and some say LST2, i say give me something i can get parts for.
Hide Signatures
(in reply to CustomTamiyas4Life)
       Post #: 2
RE: My TNX gasser - 3/2/2009 2:39 AM
CustomTamiyas4Life
Score: 105
Status: offline
It cost me a whole few bucks for a spark plug. I got the engine out of a weedwacker someone was throwing out. I knew it had a clutch so I grabbed it while I could. Everything else I already had or made/machines myself. I finally got to run this puppy in a gravel bank and it's just like the 5b vids you see where they power up dunes. It feels awesome to finally run it after so much work. Now I just need some steel rear driveshafts and some rear paddle tires. It's actually set up to be 4wd, I just need to find a short enough front shaft that will not bind. I may try a revo front shaft.
Hide Signatures
(in reply to jikkuria)
       Post #: 3
RE: My TNX gasser - 3/2/2009 2:52 AM
SlashBasher
Score: 110
Status: offline
wow! thats insane great work!
4s Slash- mamba max- turnigy 36-57 2600kv- flm adpters and 1/8 buggy badlands- tons of rpm and aluminum upgrades
Hide Signatures
       Post #: 4
RE: My TNX gasser - 3/2/2009 5:17 AM
gldngrk02
Score: 100
Last Login: 1/19/2010
Status: offline
Are you using stock internals in the trans? And any shots of how you mated the engine to the trans? Looks like a direct drive set up of sorts. Pretty cool!
Hide Signatures
(in reply to SlashBasher)
       Post #: 5
RE: My TNX gasser - 3/2/2009 2:07 PM
CustomTamiyas4Life
Score: 105
Status: offline
The internals are all stock, it's locked in second gear. I machined some heavy duty traxxas yokes to go over the clutch and tranny output shaft. I then drilled and pinned the yokes onto the shaft/clutch. It's holding up well so far, the weak link seems to be the shafts going to wheels as the center driveshaft is 3/8" solid steel if I remember correctly. I am going to be picking up some steel drive shafts and a maxx front shaft to modify so I can have 4wd.
Hide Signatures
(in reply to gldngrk02)
       Post #: 6
RE: My TNX gasser - 3/3/2009 2:41 PM
warheadforever
Score: 103
Last Login: 3/18/2010
Status: offline
quote:
ORIGINAL: CustomTamiyas4Life
It looks a bit odd, but great work!
I''m still alone, I''m still alive, I''m still unbroken
You can call me lost I call it freedom!
Hide Signatures
       Post #: 7
RE: My TNX gasser - 3/3/2009 9:05 PM
CustomTamiyas4Life
Score: 105
Status: offline
Ordered all tnx 5.2 steel driveshafts for all four corners and ordered a front center shaft so i can hook up the 4wd. Once that's all set I will try to remember to get some vids...if the snow ever melts.
Hide Signatures
(in reply to warheadforever)
       Post #: 8
RE: My TNX gasser - 3/11/2009 12:08 AM
CustomTamiyas4Life
Score: 105
Status: offline
Got all steel driveshafts and got a quick little video. It was 4wd for a little while but the plastic front sliding shaft proved to be the weak link in the drive line.
http://www.youtube.com/watch?v=Fme3os8TLNU&feature=channel_page
Hide Signatures
       Post #: 9
RE: My TNX gasser - 3/12/2009 3:41 AM
cummins driver
Score: 110
Last Login: 3/19/2010
Status: offline
That is sweet! What is the frame made out of? Looks like a pretty simple setup. At one time i had converted my t-maxx to a gasser, but i needed some better parts, and it was a lot of problem. The worst thing is that the driveline isnt made to hold the weight or torque of the motor, and it can cause problems, but they sure are neat.
HPI Savage(axial .28) - Traxxas Stampede(14.4 volts/HPI GT550 motor) - XL-5 Stampede(Electrifly S-600) - Electric Monster GT
Hide Signatures
       Post #: 10
RE: My TNX gasser - 3/12/2009 3:45 AM
CustomTamiyas4Life
Score: 105
Status: offline
Thanks. The chassis is 14" lexan with 3/4" angle aluminum reinforcements. It would snap driveshafts by the minute, so i got all steel dogbones and the tranny and diffs seem to be holding up. Still running only in 2wd because I need to find a strong enough replacement front center shaft.
Hide Signatures
(in reply to cummins driver)
       Post #: 11
RE: My TNX gasser - 3/12/2009 4:52 AM
cummins driver
Score: 110
Status: offline
Does it seem very top heavy? I ended up making a plate to bolt to the bottom of the diffs that was kind of like a "pan" chassis. It sat down about like a buggy does. I never got to run it that way, but id have to think it would have handled good. You might try it later on down the road if you wanted to mix it up.
Hide Signatures
       Post #: 12
RE: My TNX gasser - 3/12/2009 6:49 AM
fabrimacator21
Score: 100
Last Login: 1/29/2010
Status: offline
Haha... your neighbors must be waiting for trees to fall down. lol.
Tmaxx/Picco P3 .28/Futuba S9351 steering/RRP steel tranny/ MIP CVDs/ RPM arms/ FLM ext ice chassis/ RPM offset claws/mashers
Hide Signatures
       Post #: 13
RE: My TNX gasser - 3/12/2009 3:39 PM
warheadforever
Score: 103
Status: offline
That looks great! LOL and sounds good to! LOL
Hide Signatures
       Post #: 14
RE: My TNX gasser - 8/30/2009 7:04 PM
coolink13
Score: 100
Status: offline
Hey!!!!! I know this is 6 months old. But I had to respond! I was a Google search On the TNX, Because I'm in the middle of a Brush less conversion myself. That's GREAT JOB! Totally AWESOME WORK!! It looks like its slow? Is it? Again AAAAAA++++++++++ For effort and design! Its more fun making something work than buying something of the shelf!!
Hide Signatures
       Post #: 15
RE: My TNX gasser - 8/31/2009 2:50 AM
CustomTamiyas4Life
Score: 105
Status: offline
Thanks! It does 25+ which I would consider fast enough for a model of such size and weight. Unfortunately it's back to the drawing boards with a few parts which have failed on me since the first few runs. Needs a carb cleaning as well.
Hide Signatures
(in reply to coolink13)
       Post #: 16
RE: My TNX gasser - 9/6/2009 6:34 AM
SAVAGEJIM
Score: 175
Last Login: 3/15/2010
Status: offline
Now this is a nice custome work. I have seen all sorts of gassser mods: from Savages to MGTs.
I bet the guys at the giant scale might get a kick out of this mod!
I hate stray Tomcats
Hide Signatures
       Post #: 17
RE: My TNX gasser - 9/18/2009 2:30 PM
Damo_MadTruck
Score: 105
Status: offline
Thats awesome!!
I found a Ryobi whipper snipper (weed wacker) with a Scorpion 26cc engine today that someone threw out. It didn't start but i am taking it apart to clean it because it really dirty. The spark plug gave no spark and the fuel like was hard as rock and it cracked. Once i finish cleaning it i will put it back together and i will try to get it running. Then hopefully one day i will be able to buy a baja roller and stick this engine in it.
www.youtube.com/DamoHonda5
www.photobucket.com/albums/ss201/DamoSavage/
Hide Signatures
(in reply to SAVAGEJIM)
       Post #: 18
RE: My TNX gasser - 10/22/2009 9:55 PM
tizdaz
Score: 100
Last Login: 11/4/2009
Status: offline
so true, when i switched to largescale from nitro (used to have a shummy 21XT which hit 60mph pretty much stock) my FG hits about 40 stock, slower yup, but the size & power compared to my shummy more than makes up for it!
nice work dude ..what shell u gunna use.. a nice ST shell will work well with that
Largescale info: http://www.tizdaz.co.uk \o/
Tizdaz - (aka rctruckz!)
Hide Signatures
       Post #: 19
RE: My TNX gasser - 10/23/2009 4:19 PM
The_Collector
Score: 100
Last Login: 3/6/2010
Status: offline
Stihl. A fine choice. One out of the trash is just as good as one out of the showroom. Usually they give up on them when the carb stops working, or when the points on the older ones quit. Which is a shame because the engines themselves are pretty tough. Alot of them can be woke up with just a new ring and some light sanding on the cylinder.
There are only two sides...and the time has come. Choose.
Hide Signatures
(in reply to tizdaz)
       Post #: 20
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.234RCU1
