Dr Nitro
Joined: 11/12/2002 From: The Great Midwest, USA Status: offline
Woodie: Well, maybe if I actually knew what nitro percentage was in there, I would have tried it in an engine that was a little lower compressed to handle a higher nitro percentage. Maybe I should have run it in my YS 91 or 120 or one of my Saito's or even in one of my heli's? I guess I would have been in for a real treat if I had run it in one of my Lapped Iron, bushing Fox engines which like high percentages of castor and very little nitro. If I had damaged one of my Fox lapped/bushed engines, would the fuel company have fixed it for me?, I doubt it. See what I mean when I say I like to know the contents. I run several different fuel blends since one blend does not fit all. I am certainly not going to put a low nitro / high castor control line fuel in my YS engines, and I'm not putting 30% heli fuel in a lapped engine. On average, I will run about 150 gallons total of all types per year. When it comes to looking at wear on an engine, yes, I can tell. I may not be a "Fuel Expert" such as a few of the manufacturers, but I do know which engines need which type of fuel, and I do use fuel by a manufacturer that does list contents by volume and has 20% in all his airplane blends. Cooper's even lists the amount of synthetic and castor as well as the nitro. Yes, Don Nix had the same philosophy as magnum, and I did'nt use his powermaster fuel either. For heli's, I have over 94 gallons through the same YS 61 and over a hundred through an OS 61WC, (wish the helis would last as long as the engines). Yep they're older now but they put out great power and fantastic reliability. I guess my fuel is good too! I know competitive heli guys flying magnum 30 heli and they used to fly cool power when it was free or dirt cheap too, now that I think of it, they ran powermaster when the same free / cheap thing occured. As far as being used in certain events with pattern or heli, keep in mind that the vast majority of these guys competing won't fly anything if they have to pay for it, or pay anywhere close to retail. So don't judge a fuel by so many wins in contests, these guys and gals are going to place just as well if they used almost any brand of fuel. Show me a national competator in heli, pattern or any high profile event that makes his own decisions on what he flys for fuel and pays retail like the rest of us or at leas darn close to it, I'll then give the "event hype" a lot more credibility. Bottom line is; You tell me what is in the bottle, I'll make my own dicisions based on that. I will trust the company that labels fuel to insure the contents are as listed. The "Just trust me, its fine" philosophy don't cut it. If the blend with full disclosure does'nt work for me, I'll try another one that has full disclosure. I can tell when a lubricant is doing its job or not after a few gallons, so finding out does not take long. Am I as picky with my automobile gas and oil, you bet!, I know the grade I'm putting in because its disclosed on the pump, and for oil, the grade and the SAE classification is clearly listed on the bottle.
< Message edited by Dr Nitro -- Jun 17 2003 1:21AM >
_____________________________
Dr Nitro
