Mini Mgt 3.0 Upgrades???    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Team Associated - Monster GT >> Mini Mgt 3.0 Upgrades???
Page: [1] 2 3   next >   >>
Login
Mini Mgt 3.0 Upgrades??? - 3/11/2009 7:22 AM
Sicmaxx55
Score: 100
Last Login: 4/1/2009
Status: offline
Hey im picking up a mini mgt 3.0 this friday and i was wondering if there are any LARGE downsides that i should know about? And what upgrades should be bought for light bashing like small jumps and the occasional roll. One other question how hard is it to wheelie this truck?
Hide Signatures
       Post #: 1
RE: Mini Mgt 3.0 Upgrades??? - 3/11/2009 7:27 AM
ilanstylz
Score: 100
Last Login: 3/31/2013
Status: offline
Some people have no problems making their 3.0 wheelie, but a few like me do....... I run my very rich because of the weather here plus I'm new to rc's so right now I'm trying to learn more how to drive them then wheelie them ;-)....... But with the right tune you should be able to wheelie them pretty easily...... As far as upgrades, maybe some bigger tires using either the 17mm or 23mm hex adapters........ The only downside that I've experienced and I've read others have, is the stock engine tends to overheat, so you want to watch how much you lean it out and check the temp every now and then........
_____________________________
RC10GT-OS.18CVR/RC10gt-LRP.18/MMGT/MMGT-BB-HPI/MGT4.6-LRP.30/RC8/NTC3-OS.18CVR/TraxxasSport/HimotoEldorada/DuratraxRaze
Hide Signatures
(in reply to Sicmaxx55)
       Post #: 2
RE: Mini Mgt 3.0 Upgrades??? - 3/11/2009 7:35 AM
Sicmaxx55
Score: 100
Status: offline
Thanks alot. While running your lean does it still run good? Because my savage and lst2 run strong lean or rich. Any random weak partS?
Hide Signatures
(in reply to ilanstylz)
       Post #: 3
RE: Mini Mgt 3.0 Upgrades??? - 3/11/2009 8:01 AM
ilanstylz
Score: 100
Status: offline
It still runs good, and you will see the power difference..... I'm still learning to tune, so I don't want to risk having mine lean to much and do unnecessary damage to the engine....... I've bashed my 3.0 for over two weeks pretty hard, and so far the only thing that I've broken so far is the front bumper ring, which I dont feel is to important for me to worry about replacing anytime soon.......
Hide Signatures
       Post #: 4
RE: Mini Mgt 3.0 Upgrades??? - 3/11/2009 8:10 AM
sincityshooter
Score: 100
Last Login: 7/17/2011
Status: offline
there pretty sturdy trucks.
Like ilanstylz said the bumper rings tend to break.. i broke a rear one but if they break there doing there job
Associated MGT 3.0
Hide Signatures
       Post #: 5
RE: Mini Mgt 3.0 Upgrades??? - 3/11/2009 9:33 AM
Sicmaxx55
Score: 100
Status: offline
gotcha does anyone know where i can get some hop-ups for it?
Hide Signatures
(in reply to sincityshooter)
       Post #: 6
RE: Mini Mgt 3.0 Upgrades??? - 3/11/2009 9:48 AM
sincityshooter
Score: 100
Status: offline
you can find aluminum parts on ebay i think integy(sp) makes them.. new era models sells a kit to put a big block motor in it
Associated MGT 3.0
Hide Signatures
       Post #: 7
RE: Mini Mgt 3.0 Upgrades??? - 3/11/2009 9:25 PM
Sicmaxx55
Score: 100
Status: offline
i'd like to keep it small block and find a power house .18 to put in it. I want great wheelies on demand and still keep it around 37-39mph. A big block would be nothing put wheelies
Hide Signatures
       Post #: 8
RE: Mini Mgt 3.0 Upgrades??? - 3/11/2009 11:20 PM
sincityshooter
Score: 100
Status: offline
true, i like the stock motor, it smokes my friends mgt
Associated MGT 3.0
Hide Signatures
       Post #: 9
RE: Mini Mgt 3.0 Upgrades??? - 3/12/2009 1:14 PM
scott36
Score: 100
Last Login: 5/16/2013
Status: offline
if you add a set of new tires with 1/2 offset rims it will handle better and look cooler to. love mine.
Hide Signatures
       Post #: 10
RE: Mini Mgt 3.0 Upgrades??? - 3/12/2009 6:53 PM
breezerboat
Score: 100
Last Login: 6/4/2010
Status: offline
Scott36, which rims and tires do you suggest? Would bigger tires help with wheelieing?
< Message edited by breezerboat -- 3/12/2009 6:56 PM >
Hide Signatures
(in reply to scott36)
       Post #: 11
RE: Mini Mgt 3.0 Upgrades??? - 3/12/2009 7:23 PM
twomanytoys
Score: 100
Last Login: 4/23/2009
Status: offline
I use Maximizer beedlock whels with 1/2 offset. They are awsome.
The one with the most toys wins. I think I may have a good chance of winning.
Hide Signatures
(in reply to breezerboat)
       Post #: 12
RE: Mini Mgt 3.0 Upgrades??? - 3/12/2009 7:41 PM
breezerboat
Score: 100
Status: offline
Holy Cheetoes!!! those things aren't cheap. What tires? What does 1/2 inch offset mean?
Hide Signatures
(in reply to twomanytoys)
       Post #: 13
RE: Mini Mgt 3.0 Upgrades??? - 3/12/2009 8:14 PM
twomanytoys
Score: 100
Status: offline
1/2 offset means the wheels will set the width of the truck wider than stock. The center of the wheel where the hex is bolted is set 1/2 inch closer to the hub. Axial also makes good beadlocks. Yes they are not cheap but well worth it. You wont ever have to buy wheels again. No gluing and if you break a wheel you just replace the broken part for about $4.00 instead of buying a whole wheel. Pro line Badlands are one of the best tires you can get. Very agressive tread and awsome traction in any condition.
Hide Signatures
       Post #: 14
RE: Mini Mgt 3.0 Upgrades??? - 3/12/2009 10:47 PM
scott36
Score: 100
Status: offline
http://www3.towerhobbies.com/cgi-bin/wti0001p?&W=001147837&I=LXTTD1&P=K
these are the ones i use and they look cool to. i dont think bigger tires will help with doing whellies tho.
Hide Signatures
       Post #: 15
RE: Mini Mgt 3.0 Upgrades??? - 3/12/2009 11:01 PM
scott36
Score: 100
Status: offline
here is a pick of full off set tires and rims, cant find the pics with the 1/2 off set put you will get the idea here, the truck mesures a full 17.5 inchs wide with full off set rims and tires.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 16
RE: Mini Mgt 3.0 Upgrades??? - 3/12/2009 11:39 PM
breezerboat
Score: 100
Status: offline
GEEZE LOUIS!!! That thing is wide. And do you ever drive it? It's clean as new and no scratches.
< Message edited by breezerboat -- 3/13/2009 12:28 AM >
Hide Signatures
       Post #: 17
RE: Mini Mgt 3.0 Upgrades??? - 3/13/2009 12:40 AM
scott36
Score: 100
Status: offline
yep i do drive it , its been winter here so getting dirty is on the summer list of things to do.
Hide Signatures
       Post #: 18
RE: Mini Mgt 3.0 Upgrades??? - 3/13/2009 7:14 PM
jologs
Score: 100
Last Login: 12/12/2010
Status: offline
hey guys, i'm planning to change the stock engine to toki .27. Any suggestions???
Hide Signatures
       Post #: 19
RE: Mini Mgt 3.0 Upgrades??? - 3/14/2009 12:44 AM
jermainezey
Score: 100
Last Login: 4/6/2013
Status: offline
am new to rc nitro and i have the mmgt 3.0 i been using traxxs top fuel 20 per cent and my truck dont over heat no more now have lean it out and it have all sort of power and does wheelie easy
jermaine dawkins
Hide Signatures
       Post #: 20
RE: Mini Mgt 3.0 Upgrades??? - 3/14/2009 1:18 AM
sincityshooter
Score: 100
Status: offline
quote:
ORIGINAL: jologs
throttle control
Associated MGT 3.0
Hide Signatures
(in reply to jologs)
       Post #: 21
RE: Mini Mgt 3.0 Upgrades??? - 3/14/2009 5:45 AM
jermainezey
Score: 100
Status: offline
what kinda fuel do u use in your 3.0
jermaine dawkins
Hide Signatures
       Post #: 22
RE: Mini Mgt 3.0 Upgrades??? - 3/14/2009 5:54 AM
twomanytoys
Score: 100
Status: offline
quote:
ORIGINAL: jologs
You dont want a toki engine. Yuck! Get a better mill. You want great low budget power then look at a Sportwerks 26v2 or 21v2. Best engine for about 120.00. The Toki will not last long and have heat and air leak problems.
Hide Signatures
       Post #: 23
RE: Mini Mgt 3.0 Upgrades??? - 3/15/2009 6:45 AM
kuade
Score: 100
Last Login: 7/7/2009
Status: offline
I can kind of do wheelies if i take out the front drive axles....
< Message edited by kuade -- 3/15/2009 6:46 AM >
Hide Signatures
       Post #: 24
RE: Mini Mgt 3.0 Upgrades??? - 3/16/2009 10:50 AM
Sicmaxx55
Score: 100
Status: offline
I run 30% trinity monster horsepower fuel and i run it rich my motor stays cool around 220 and will wheelie almost on demand. Very good set-up.
Hide Signatures
(in reply to kuade)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.813RCU1
