RE: Nitro Models Cessna 421C build and fan page    Gallery
Logged in as Guest
    Search This Thread
Printable Version
1/5 Scale Don Smith's Henschel HS-129B - RTF
Seller:  Dumb Thumb
Details:   $2,750.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: Nitro Models Cessna 421C build and fan page
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
[Poll]
Yes, I''m interested in following this build thread
  90% (37)
I''m not too interested, but I think others would be.
  7% (3)
It''s been done for an electric, so probably not
  2% (1)
Total Votes : 41
(last vote on : 4/3/2009 8:20 PM)
(Poll ended: 4/5/2009 4:00 AM)
Login
RE: Nitro Models Cessna 421C build and fan page - 3/16/2009 10:51 PM
Chas
Score: 100
Last Login: 11/26/2010
Status: offline
quote:
ORIGINAL: trevtt600
Hello All. I am just about done with my Nitro 421. I will post some pictures when i get home. I am glad that more people are seeing the potential of this model. They did a very good job modeling it. I have flown the real airplane many times, and has come to be my favorite GA twin engine plane. I am using twin GMS .47 with inverted pitts mufflers, Robart 700 series retracts, LED light kit, and have added deice boots to the plane. After seeing the last few posted, i think i will be adding some static wicks, and a few other details. I did the first engine run this weekend, and boy what a great sound. I look forward to seeing everyones build!!
Pictures please. Look forward to them
Chuck.
Hide Signatures
(in reply to trevtt600)
       Post #: 26
RE: Nitro Models Cessna 421C build and fan page - 3/17/2009 9:20 AM
Bob Paris
Score: 110
Last Login: 5/20/2013
Status: offline
Hay P-Diddy,
Nice build...and I have had some great experiences with the K & B .45 Sportster. I've flown all the sportster engines and two differnt .45's. They were all reliable, easy to start and I was impressed the the power of the .45. They are inexpensive, good running and reliable. This is my personal experiece running these engines since they came out onto the market. I'll admit that I'm a K&B fan, and what I usually run on my models.
Soft Landings Always,
Bobby of Maui
_____________________________
AMA 15016
Say what you mean, mean what you say...and !#$& it if you can''t take a joke.
Hide Signatures
(in reply to Patto)
       Post #: 27
RE: Nitro Models Cessna 421C build and fan page - 3/17/2009 10:08 PM
Patto
Score: 103
Last Login: 3/17/2013
Status: offline
I have three K&B's at home that I have never run: 2 X .45 Sportsters and one .65 Sportster. I bought all of them on ebay. When I was younger I had a K&B .61 that ran great, lots of power, low idle, smooth transition...
It's amazing how cheap they are on ebay. Hopefully I'll find that I got a great deal and it won't be a headache getting them to run well.
Hide Signatures
(in reply to Bob Paris)
       Post #: 28
RE: Nitro Models Cessna 421C build and fan page - 3/18/2009 12:51 AM
Bob Paris
Score: 110
Status: offline
Hay P-Diddy,
Break-in, with the Sportser series engines is critical to good reliable running. It may take up to an hour to break-in each engine, and I would suggest that you run them for no longer then 10 minutes, let them cool down until you can place your fingers on the head of the engine...then run them again. I usually do this six to ten times until I can hold a flight needle valve setting in the vertical placement. Becareful and do not over heat the engines on break in...or have them seaze up on break-in. So keep them rich at first...and slowly lean them out. I also used an 11 x 6 on break-in and switched to a 10 x 6 for flight. Using a larger prop on break-in seems to me to give me a more reliable engine after the break-in is complete.
I like all castor fuel, with 15% nitro. I'll use a 50/50 mix if all castor is out of stock...but I believe all castor is best for K & B engines.
Bobby of Maui
< Message edited by Bob Paris -- 3/18/2009 12:52 AM >
AMA 15016
Hide Signatures
(in reply to Patto)
       Post #: 29
RE: Nitro Models Cessna 421C build and fan page - 3/18/2009 2:17 AM
cjtyped
Score: 105
Status: offline
Simple interesting additions to a 421...a 1/8" dark red dot between the left engine and fuselage ( this is a sight glass that the pilot looks at to determine if sufficient hydraulic fluid is present), 1/16" dots, one on top of the other, near where the pilot and copilot sit ( looks like a : ), this is for the static system and drainage.
You can amaze your friends when they ask what these are!!
Hide Signatures
       Post #: 30
RE: Nitro Models Cessna 421C build and fan page - 3/21/2009 11:18 AM
Patto
Score: 103
Status: offline
quote:
ORIGINAL: Bob Paris
Hay P-Diddy,
Bobby of Maui
Bob, you seem to know your K&B's, so I'll take your advice on the break-in. Thank you very much.
-Pat
Hide Signatures
       Post #: 31
RE: Nitro Models Cessna 421C build and fan page - 3/21/2009 11:20 AM
Patto
Score: 103
Status: offline
quote:
ORIGINAL: cjtyped
Are the static ports raised? I remember on my Cessna 150, (full-scale, owned it several years ago) that there was a raised disc with the hole in the center of the disc.
These are great ideas, thank you.
Hide Signatures
(in reply to cjtyped)
       Post #: 32
RE: Nitro Models Cessna 421C build and fan page - 3/21/2009 12:27 PM
Jimmy Bananas
Score: 103
Last Login: 5/19/2013
Status: offline
Got mine when they were available....Really can't say too much good stuff about the Cessna 421..first of all, the horizontal lines on the firewall are way off...nothing lines up...had to add 3/8" ply to the firewall to make the back prop washer stick out of the nacelle...after two or three trys,finally got it right and now it's off to the left wing and get it set up...also noticed that my parts bag with the nuts and bolts is missing....haven't even started on the fuse yet...lord only knows what I'll find wrong with that..will work on it until I get my KMP SBD Dauntless,hopefully by the first of April..then the 421 goes into the corner and maybe sometime this summer ,I might start to work on it again....One thing for sure..no more planes from Nitro...going to stick with the good stuff...................
Hide Signatures
(in reply to Patto)
       Post #: 33
RE: Nitro Models Cessna 421C build and fan page - 3/22/2009 5:04 AM
cjtyped
Score: 105
Status: offline
RE Static ports. I know what you're talking about on the 150 and the disc, but not, the staitic ports on the 421 I am pretty certain are just holes. In scale on the NP421, I wouldn't make them any larger than 3/32"
Hide Signatures
(in reply to Chas)
       Post #: 34
RE: Nitro Models Cessna 421C build and fan page - 3/22/2009 5:17 AM
jetfixr
Score: 100
Status: offline
These are the static ports on a Turbo Commander. This is what most of them look like. I don't imagine a 421 would be much (if any) different. Different location of course.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 35
RE: Nitro Models Cessna 421C build and fan page - 3/22/2009 7:26 AM
Patto
Score: 103
Status: offline
quote:
ORIGINAL: Jimmy Bananas
I have had very similar problems with mounting the engines!! Oh, it was so frustrating trying to get them to match up with the cowl. The horizontal lines were way too low for where the cowl ends up. I had to drill it three different times trying to get it right, so I feel your pain.
The parts bags were all present in my kit, although some of the screws for the wheel collars were missing, and the pushrods were almost all useless since they were not threaded. On a plane this size, using EZ-connectors would not be a good option. Not to mention, the rods weren't all long enough for the elevators and the rudder. There were some short threaded rods for the ailerons and flaps, but none for the throttles or nose steering. I needed to use a pull-pull since I'm doing retracts anyway, so the last part didn't bother me, but I had to buy new pushrods for the elevators, rudder, and throttle controls.
I have now installed the nose retract and all of the gear to make it work and steer. Unfortunately, the plastic well for the nosegear was not deep enough for the wheel to fully retract and it interfered with the steering cables, so I had to butcher it quite a bit. I may end up taking it out completely.
I ran into a bit of a problem with the cables in that when the nose gear retracts, the cables go slack and end up falling out the bottom of the fuse or just flop around inside the fuse. Anyone have a good solution for that? I thought about running a rubber band under it and attach the band to the fuse sides above the nose-steering servo to take the slack out. I would have to put a plastic tube or something similar over the rubber band to keep it from getting ripped up by the cables, but I think it may eliminate this problem.
Thanks for the info. on the static ports!
-Pat
Hide Signatures
(in reply to Jimmy Bananas)
       Post #: 36
RE: Nitro Models Cessna 421C build and fan page - 3/22/2009 2:58 PM
Chas
Score: 100
Status: offline
quote:
ORIGINAL: P-Diddy
-Pat
Pictures Please.
Hide Signatures
(in reply to Patto)
       Post #: 37
RE: Nitro Models Cessna 421C build and fan page - 3/23/2009 12:26 AM
Patto
Score: 103
Status: offline
Here are the pictures of the engine installations thus far. As previously mentioned, the horizontal lines are placed incorrectly for lining up with the cowl. It took me three tries to install the first engine but only one for the second. The first time I just trusted the lines, which didn't work out well.
I still think that, so far, this plane is an excellent value, even with some hardware issues and that alignment problem.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Chas)
       Post #: 38
RE: Nitro Models Cessna 421C build and fan page - 3/23/2009 12:28 AM
Patto
Score: 103
Status: offline
Some pictures of the retract installation.
Yes, I've been jumping around a little bit as far as the order in which I'm building. I can't help it. I get bored or frustrated with one thing so I move on to a different part of the manual. I've always done that. I think I'm just a little impatient...
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Patto)
       Post #: 39
RE: Nitro Models Cessna 421C build and fan page - 3/24/2009 11:41 AM
Patto
Score: 103
Status: offline
I don't have pictures of it yet, but I finished installing all the retracts and I've fitted the wings to the fuse. Seeing as I would have a lot of wires to disconnect along with the air lines, I'm going to TRY and keep it one piece unless I have work to do on it. The nylon bolts for the wings did not fit the blind nuts inside the wings, but a set of metal bolts were included as well, so I used those with a small amount of thread lock. The retracts were a pain to get installed and working happily together. I also found that unless they are fully charged up, they don't like to lock in place. The PSI has to be above 80 for them to work really well, so they can cycle twice, maybe three times before they are needing more air.
I have not yet installed throttle linkages, but that's next on my to-do list. I had to cut the heck out of the cowl, (one done so far) to get the engine and muffler to clear. It's not nearly as pretty as I had hoped for. I don't think I'll post any pictures that show my handywork on the cowls in any great detail...
The nylon bolts included for mounting the cowls/nacelles are too short. I can go buy new ones or drill into the wing a little bit to have them recessed and then they will have enough bite to get into the blind nuts, although I'll check to make sure they actually FIT the blind nuts before going to all that trouble, of course.
After finishing with the throttle linkages and the other cowl, I'll be fitting the canopy. After that, there is some clean-up and organization of the wires and receiver. Then, balancing....
The manual says the CG is at 3.5" behind the leading edge of the wing. Has anyone flown it with that CG yet and, if so, how did it turn out?
-Pat
Hide Signatures
(in reply to Patto)
       Post #: 40
RE: Nitro Models Cessna 421C build and fan page - 3/24/2009 3:12 PM
Chas
Score: 100
Status: offline
quote:
ORIGINAL: P-Diddy
-Pat
Pat, did you use stock muffler?? I figured if a person went with a inverted engine and used stock muffler there would be some major cutting of cowl.
Hide Signatures
(in reply to Patto)
       Post #: 41
RE: Nitro Models Cessna 421C build and fan page - 3/24/2009 10:15 PM
Patto
Score: 103
Status: offline
You figured right!
The engines could not be mounted on their sides and still align properly. I searched for pitts style mufflers, but since I just HAD to use the K&B's, I ended up not being able to find anything that would fit.
Hide Signatures
(in reply to Chas)
       Post #: 42
RE: Nitro Models Cessna 421C build and fan page - 3/26/2009 11:04 PM
trevtt600
Score: 100
Last Login: 12/14/2009
Status: offline
Hello All. Sorry it has taken me so long to upload some pictures. Here is what i have so far. When the weather is nicer, i will head outside and take some better ones. I am pretty much done. Need to add a few more scale details, and she will be ready to go. Im going to try and get the engines broke in in the next day or so. I spend sometime and made some scale gear doors for the mains. If i really want to get adventerous, i might try and make some doors for the nose gear. Let me know what you think.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Patto)
       Post #: 43
RE: Nitro Models Cessna 421C build and fan page - 3/27/2009 3:19 AM
Patto
Score: 103
Status: offline
Looking really good. I like the gear covers. Let me know when you make the first flight, and try and get video!
Hide Signatures
       Post #: 44
RE: Nitro Models Cessna 421C build and fan page - 3/30/2009 1:01 AM
kcforsythe
Score: 100
Last Login: 3/4/2013
Status: offline
Hi All,
I just recently took delivery of my 421 and I'm about half way done with my build. Waiting on some robostruts for my retracts, one more engine and my Slimline mufflers to arrive. I'm going to be using two OS 46LA engines with Slimline Pitts mufflers. My fuselage arrived with some damage; a small (about the size of a pencil eraser) chip in the front top of the fuselage near the nose. I decided it was going to be easier to repair it myself then send it back. During my repair I was worried about matching the paint color due to the limitless shades of orange out there. I absolutely lucked into an EXACT match at Home Depot and wanted to share it with you guys in case anyone else is in this situation. It is Rustoleum Painter's Touch Gloss paint and the color is Real Orange. I did a coat of clear coat over top and it looks great. The color is a perfect match.
Once I have pictures taken, I'll get them out here for everyone to see.
Kent
Hide Signatures
(in reply to Patto)
       Post #: 45
RE: Nitro Models Cessna 421C build and fan page - 3/30/2009 9:10 PM
Patto
Score: 103
Status: offline
Thanks for the info about the paint. How is the build going other than that? Any issues?
Hide Signatures
(in reply to kcforsythe)
       Post #: 46
RE: Nitro Models Cessna 421C build and fan page - 3/31/2009 5:39 AM
jebiga
Score: 100
Last Login: 1/3/2011
Status: offline
Heelo, ALL
I recentle also bought the Cessan 421 from Nitro Planes. I am concerned about the weight , about 11-12lb using O.S. .46. do you think this will work out? Also what CG are you all goinf by? The manual says 90mm, but measuring the MAC my calculations show it is around 62mm fro leading edge.
Any imput?
Bill
Hide Signatures
(in reply to Patto)
       Post #: 47
RE: Nitro Models Cessna 421C build and fan page - 3/31/2009 8:05 PM
Patto
Score: 103
Status: offline
I don't think you'll be lacking in power. If you consider that .40 size 3D planes are usually in the 5 lb. range, and you will have two .40-.46 size engines, roughly doubling your thrust, and that this is a scale plane... well, I think there will be plenty...
As far as the CG goes, mine is not yet complete, so we'll have to wait and hear from someone who has tried flying on the recommended CG. Anyone?
Hide Signatures
(in reply to jebiga)
       Post #: 48
RE: Nitro Models Cessna 421C build and fan page - 3/31/2009 9:48 PM
kcforsythe
Score: 100
Status: offline
P-Diddy,
The build is going fine. I have mixed opinions on the kit itself. The quality of the hardware is not very good and I've had a few issues with the glass work internally. Had to cut away some fiber cloth that did not get glassed down well. Most of the external quality of the finish is very good and I think the end result will be a real eye catcher. I'm not happy with the way my canopy fits down on the fuselage but that's my fault. Eventually I want to order another canopy to redo it.
I'm working on mounting my O.S. 46LA engines right now. I don't have the mufflers yet (backordered) so it will be tough to complete everything. I'm going to use the Slimline Pitts mufflers. After that, I just need to put servos in and hook everything up. Assuming the mufflers come in the next week, I should be airborne in two weeks.
Are people using the standard control rods for the elevator and rudder that came with the kit? The elevator rods seem to work fine but the rudder one seems to bind a little. I'm curious if anyone has removed the pushrods and gone with something solid without an outer tube.
Pictures still to come.......
Kent
Hide Signatures
(in reply to Patto)
       Post #: 49
RE: Nitro Models Cessna 421C build and fan page - 3/31/2009 11:38 PM
jebiga
Score: 100
Status: offline
Hello kent
On the push rods, I bought some others. My kit came with just plain straight music wire, the length was even too short. I also just recenieved mu pitts style mufflers for my O.S. 46. Advantage Hobby has some in stock, same price but no charge on shipping.
Bill
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.969RCU1
