Spinners    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> RC Pattern Flying >> Spinners
Page: [1]
Login
Spinners - 3/13/2009 10:28 AM
gaRCfield
Score: 156
Last Login: 6/19/2013
Status: offline
I can't believe I'm making a post about spinners, but...
Before I drop $30 to $50 or more on a spinner, what are the major differences between brands? So far I've found Dave Brown, Tru Turn, Great Planes of course, and I just found some called Spin Right and ProSpin - anyone know anything about these? Is there anything I need to know, or just pick what looks good and fits? The Venus came with spinners so I have yet to buy one.
< Message edited by gaRCfield -- 3/13/2009 10:35 AM >
_____________________________
Joe Marri
Enjoying all things aviation.
Hide Signatures
       Post #: 1
RE: Spinners - 3/13/2009 10:44 AM
Rendegade
Score: 105
Status: offline
take a look at the precision aerobatics ones, they're light, carbon and straight!
It''''s easy to fly, just throw yourself at the ground and miss!
Hide Signatures
(in reply to gaRCfield)
       Post #: 2
RE: Spinners - 3/13/2009 4:34 PM
Planeclaims
Score: 100
Last Login: 6/14/2013
Status: offline
Not all spinners are created equal, especially for 2M pattern airplanes equipped with high performance 4 cycle 140 - 170 motors. My Tru-Turn aluminum spinner, lightweight backplate, adapter assembly and misc. mounting accessories are very durable and reliable, especially when cranking the engine with an electric starter hundreds of times each year. For me, they're worth the extra money I.M.H.O.
Steve
Hide Signatures
       Post #: 3
RE: Spinners - 3/13/2009 6:11 PM
rcpattern
Score: 100
Status: offline
Joe,
I have to agree with Steve. Get a Tru turn and forget it. The plastic ones look OK, but when you use an electric starter they don't last very long. Carbon ones are great, but they don't work well with Electric Starters. As long as you are flying 2 strokes, it really doesnt matter as a starter isnt really a requirement.
Arch
Team Futaba, Castle Creations, Tech Aero Designs, Hacker Motors, F3A Unlimited, Team BJ Craft,
Hide Signatures
(in reply to Planeclaims)
       Post #: 4
RE: Spinners - 3/13/2009 6:32 PM
Ryan Smith
Score: 103
Status: offline
Tru-Turn.
You'll only cry once.
Hide Signatures
(in reply to rcpattern)
       Post #: 5
RE: Spinners - 3/13/2009 8:41 PM
Jeff-RCU
Score: 100
Last Login: 4/25/2013
Status: offline
Till that YS backfires and wads up the spinner!
Jeff
Hide Signatures
(in reply to Ryan Smith)
       Post #: 6
RE: Spinners - 3/13/2009 9:17 PM
gaRCfield
Score: 156
Status: offline
Thanks guys. This is for a YS, not a two stroke. I'll get the Tru-Turn.
Joe Marri
Hide Signatures
(in reply to Jeff-RCU)
       Post #: 7
RE: Spinners - 3/13/2009 9:48 PM
Robbidos
Score: 100
Last Login: 6/16/2013
Status: offline
Tru-turn. Especially with a YS.
- Robert Beaubien
- Sun Valley Fliers
Hide Signatures
       Post #: 8
RE: Spinners - 3/13/2009 9:49 PM
kcnelson
Score: 100
Last Login: 1/31/2013
Status: offline
.... answered for Electric before seeing that YS was being used.....
For those who care, see http://www.escomposites.com/spinners.htm
Ken
< Message edited by kcnelson -- 3/13/2009 9:52 PM >
Hide Signatures
       Post #: 9
RE: Spinners - 3/13/2009 10:15 PM
jim woodward
Score: 100
Status: offline
I've been using CAModels Carbon Fiber spinner for over 200 flights, no issues at all. The spinner is CF with a very lightened up backplate. The CF cone has an epoxy glassy look to it. I've used the YS 170 all the time, and used electric starter every flight. The CF shows zero sign of wear from the spinner. The Rubber cone will leave some rubber on it after a while, which is wiped off easily. If you model is nose heavy, this is an easy fix because it is arouond 0.75 oz lighter than a TT lightened spinner.
Jim
Hide Signatures
(in reply to kcnelson)
       Post #: 10
RE: Spinners - 3/13/2009 10:47 PM
mups53
Score: 105
Status: offline
Jim does Netbox sell that spinner? Thanks, Mike
F3AUnlimited Customer Service
1 800 591 2875
Hide Signatures
(in reply to jim woodward)
       Post #: 11
RE: Spinners - 3/13/2009 11:42 PM
gaRCfield
Score: 156
Status: offline
One more question: My plane is requiring a gross amount of nose weight to balance. I know they make weighted spinners, and also weighted prop washers. My thinking was that these would create a greater load for the engine and is not desirable. Is this correct?
I hate adding weight to a plane, but the only options I can think of, other than straight lead, are a weighted spinner and a redundant battery pack.
Joe Marri
Hide Signatures
(in reply to mups53)
       Post #: 12
RE: Spinners - 3/13/2009 11:52 PM
mups53
Score: 105
Status: offline
Joe I think it's best to stay as light as possible. The added strain on the motor is not good. Plus it could cause more of a gyroscopic effect when your heavy on the shaft. I know with electric as well it's better on the motor to keep things as light as you can. Mike
1 800 591 2875
Hide Signatures
       Post #: 13
RE: Spinners - 3/14/2009 1:27 AM
gaRCfield
Score: 156
Status: offline
What's the right size spinner for a YS110? 2.75-3.5?
Joe Marri
Hide Signatures
       Post #: 14
RE: Spinners - 3/14/2009 1:58 AM
petec
Score: 101
Status: offline
The diameter of the spinner is more a function of the area where the backplate meets the cowl on the plane than the engine size.
Does the manufacturer of your plane have a recommended spinner size?
Team YS, Team Airtronics
Pattern Junkie, Revver Brother #82, Gear Head
Hide Signatures
       Post #: 15
RE: Spinners - 3/14/2009 2:25 AM
rcpattern
Score: 100
Status: offline
Joe,
check the front of the cowl on your plane and measure that area. Then buy the spinner that fits properly.
Arch
Hide Signatures
(in reply to petec)
       Post #: 16
RE: Spinners - 3/14/2009 2:27 AM
gaRCfield
Score: 156
Status: offline
Thanks, I guess I'll have to figure it out then. I thought a 3.5in looked really great, but then realized it would block a lot of cooling air from the engine.
Joe Marri
Hide Signatures
(in reply to petec)
       Post #: 17
RE: Spinners - 3/14/2009 2:29 AM
rcpattern
Score: 100
Status: offline
Joe,
Most cowl's have the ring build in on the front, or the manufacturer will tell you a recommended size. It should flow nicely with the front of the airplane, without sticking up and such. What airplane is it?
Arch
Hide Signatures
       Post #: 18
RE: Spinners - 3/14/2009 2:37 AM
gaRCfield
Score: 156
Status: offline
It's for my back-up plane - a 120 size Yak.
Click to see fullsize image.
Click for fullsize
< Message edited by gaRCfield -- 3/14/2009 12:36 PM >
Joe Marri
Hide Signatures
       Post #: 19
RE: Spinners - 3/14/2009 10:31 PM
rcpattern
Score: 100
Status: offline
On a Yak, you can use about anything. The spinner on that plane looks good.
Arch
Hide Signatures
       Post #: 20
RE: Spinners - 3/14/2009 10:57 PM
jim woodward
Score: 100
Status: offline
Yes - Netbox sells the CF spinners - just put 4 more in this morning
Jim
Hide Signatures
       Post #: 21
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.266RCU1
