Wookie
OR, USA Status: offline
I've got a Peak Racing Hellfire RS 24 which is a 27 turn stock class motor. It's pretty quick for a stock class motor but tops out around 22 - 23 mph. I get a good 12-15 minute of run time out of it with a non matched 2400 NiCad pack. I've recently upgraded my B3 to a Trinity Speed Gem 2 Amythest, 17 turn double wind motor. This motor gets my B3 up to the upper 20's to low 30's and still gives me about 11 minutes of run time on the same battery pack. I haven't upgraded to matched NiMh's yet, but am planning on doing so within the next month or two. With a 3300 NiMh pack you should get about 12 - 15 minutes with a 17 turn motor like the speed gem. If you are going to be racing a savage I would look at something like a 15 turn motor, assuming the savage is still running the stock engine. This would give you about the same top speed as the Savage, maybe a little more but would be much quicker than a Savage. As for tires any buggy tire will work. Most rims will probably work as well, but you can just re-use the ones you have now. To take them off put them in a pot of boiling water for 20-30 minutes, pull them off and with a towl around them press in on the seam of the tire/wheel and they should come right apart. Clean up any glue left with a razor blade, flat head screw driver, etc. and you can now mount new tires on them.
