RE: Trex 450 CLONE WARS
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> T-Rex heli >> RE: Trex 450 CLONE WARS
Page: <<   < prev  1 [2] 3 4 5   next >   >>
Login
RE: Trex 450 CLONE WARS - 3/24/2009 4:45 AM
homeunt
Score: 100
Last Login: 10/27/2009
Status: offline
I must ask..
The reason that I got into Align helis is cause I got them used very cheap.
I got one with a lot of damages requiring the complete frame set to be replaced.
and the Align prices will try to swallow my wallet.
So what alternatives are there? Here are somethings that I'd like
1. 100% compatible with Align T-Rex 450 SE V2 and V1 at different times
2. Aluminum blocks between the frames.
3. Not plastic, most preferably aluminum frame but CF is acceptable.
4. Head parts, I have trouble finding T-Rex 450 SE V1 parts the washout mixer
is ..... to find alternatives?
_____________________________
This hobby is funny, if I got cash, I got no experience.
If i got experience, I see a giant hole on my wallet.
Hide Signatures
(in reply to FLYGUY09)
       Post #: 26
RE: Trex 450 CLONE WARS - 3/24/2009 11:49 PM
FLYGUY09
Score: 100
Last Login: 10/20/2009
Status: offline
I found this post on another forum, but it should answer a lot of questions about the HK-450...both the good and the bad:
quote:
I bought one (HK-450) as well, had it for a few weeks now. It obviously was made from a real Trex SA, I can see tool marks on the tailboom block where the Align logo was milled off before they used the part to make the mold.
The stock fiberglass blades that come with it are crap, one of them has a very visable warp in it, it doesn't and never will track straight.
The stock socket head screws are also crap, I had heads break off just trying to screw them in all the way, never mind tighten them down.
The plastic used for molding parts seems to be on the brittle side, more so than the stock Align pieces.
The good news is that virtually any Align Trex 450 part is bolt on. My very first heli was an SA, I still have the badly bent original frame from it, and other than the lack of a serial number, the clone frame is exactly the sale. I traded my original SA for my XCell Fury and soon decided I wanted another 450, so I bought the clone. Still had a fairly large stock of Align parts and upgrade bits that never got used on the first Trex, so I swapped them into the clone. I can't tell the difference flying the clone vs the real Trex SA, best $35 I've spent for a small heli.
Inspirational. What did we learn? Well, we have learned that you cant teach an old dog new tricks. Because its illegal and you will go to jail.
-Michael
Hide Signatures
(in reply to homeunt)
       Post #: 27
RE: Trex 450 CLONE WARS - 3/25/2009 7:49 PM
FLYGUY09
Score: 100
Status: offline
I just received my Hobby City order....two HK-450 kits with electronics. I've loosened and/or tightened every hex frame screw on both kits and none of them stripped or came close. I have a brand new quality 1.5 mm hex driver so maybe if you use a cheap or worn out one you'll have problems, but I'm not seeing any problems yet.
Hobby City even threw in 3mm screws for my motors (I forgot to add that in) and 2 Turnigy straps....both are turned out...LOL.
-Michael
Hide Signatures
       Post #: 28
RE: Trex 450 CLONE WARS - 3/26/2009 4:29 PM
jrizzle
Score: 100
Last Login: 4/16/2009
Status: offline
I just ordered a HK 450 with two of the $17.00 Zippy lipos. Total was around $70.00!! Amazing! I think with shipping I was still under $100.00. Thanks for the thread guys!
Hide Signatures
       Post #: 29
RE: Trex 450 CLONE WARS - 3/28/2009 11:10 PM
don_87
Score: 101
Last Login: 10/24/2009
Status: offline
quote:
ORIGINAL: Joe K
quote:
ORIGINAL: don_87
quote:
ORIGINAL: jeffk464
Anyone compare the HK to the exi. I know the exi is supposed to be completely parts interchangeable with the trex, is the HK the same way?
Yes, the HK450 is a Trex 450 SA clone, with a few differences......... Bottom plate on the HK is plastic, the SA is aluminum. Screw heads strip out easily( I purchased the SE screw set for mine). There is an issue with the "tail drive gear and pulley" spinning freely on some. Early models had mismatched blades.
I put the Copter X head and tail on mine.
Most all the info you need for that particular helicopter can be found here: http://www.rcgroups.com/forums/showthread.php?t=976255
Don
I have the SA the bottom plate is plastic. I think you are thinking of the motor mount, On the SA it is aluminum.
You are correct, I was thinking of the motor mount.
The HK 450 screws are junk, I purchased a new Align screw set for mine(just in case).
There are a few problems with the heli (and there is a huge thread on RC Groups covering it), but nothing that can't be changed easily.
But for 35 bucks..............can't beat the hk 450....IMHO ( I bought 2)
Don't forget to check out Tech Model Products for parts also. Good place to do business with. http://www.techmodelproducts.com/index.htm
Hide Signatures
(in reply to Joe K)
       Post #: 30
RE: Trex 450 CLONE WARS - 3/29/2009 1:27 AM
FLYGUY09
Score: 100
Status: offline
On the motor mount, where they pre-drilled the slots for the motor screws where you can slide the motor back & forth has warped on one side. It bent out a little bit but it's holding. I'm going to order 2 sets of Align's aluminum motor mounts for both of my kits. I already have a few items to order for some of my other heli's so I'll add this to my list.
So far, that's the only problem I've had with the build.
-Michael
Hide Signatures
(in reply to don_87)
       Post #: 31
RE: Trex 450 CLONE WARS - 3/29/2009 5:44 AM
dude7422
Score: 102
Last Login: 11/5/2009
Status: offline
i see you dont get my humor
quote:
ORIGINAL: grawyl
He said "Thingys"...hu hu hu...
Dude, you should get that...
or do you get i was being funny )
Hide Signatures
(in reply to grawyl)
       Post #: 32
RE: Trex 450 CLONE WARS - 3/31/2009 3:46 AM
FLYGUY09
Score: 100
Status: offline
Just got the HK-450 mostly put together and shot a video of the completed setup with a bench test using the Watts Up meter (less main & tail rotor blades on it).
HK-450
TP2415-7T 3850Kv motor
11T pinion gear
Zippo 2,200 mAh, 20C - 30C, 3S1
Turnigy 40A ESC, 3A BEC
Hextronik HXT 900s for cyclic
Telebee GR302-A/D
Hitech 5084MG Tail Servo
HK-450 bench test
< Message edited by FLYGUY09 -- 3/31/2009 5:04 AM >
-Michael
Hide Signatures
(in reply to dude7422)
       Post #: 33
RE: Trex 450 CLONE WARS - 3/31/2009 6:28 AM
jrizzle
Score: 100
Status: offline
Test looks good. LMK how it flies. Mine shipped today.
Hide Signatures
       Post #: 34
RE: Trex 450 CLONE WARS - 3/31/2009 8:41 AM
J-MICHAEL
Score: 124
Last Login: 11/8/2009
Status: offline
quote:
ORIGINAL: dude7422
quote:
ORIGINAL: grawyl
I believe Grawl was being funny back, by saying "He said "Thingys"...hu hu hu..." A quote that Beavis or Butthead would say so to speak... I think you didn't get his humor...
Mikado Logo 10 ~ Trex 500 ~ Trex 450 ~ E-Flite Mini Funtana X ~ Parkzone Typhoon 2 3-D
Fly em like there not yours !
Hide Signatures
       Post #: 35
RE: Trex 450 CLONE WARS - 3/31/2009 7:37 PM
aythomps
Score: 100
Last Login: 9/19/2009
Status: offline
I have Exi 450, I was looking on hobby city. What would be a good tail servo for the 450. I see flyguy using a Hitec 5084mg on the tail. Any suggeustion?
Hide Signatures
(in reply to J-MICHAEL)
       Post #: 36
RE: Trex 450 CLONE WARS - 3/31/2009 8:28 PM
noobflyer01
Score: 147
Last Login: 11/7/2009
Status: offline
quote:
ORIGINAL: aythomps
futaba 9650, 9257. jr 3500g
Trex500ESP
EXI 450
Hide Signatures
(in reply to aythomps)
       Post #: 37
RE: Trex 450 CLONE WARS - 3/31/2009 9:00 PM
J-MICHAEL
Score: 124
Status: offline
quote:
ORIGINAL: aythomps
Noob suggested some great popular servo's, but the one you were inquiring about is also a superb servo in which I know a few gents who love it...
http://www.servocity.com/html/hs-5084mg_servo.html
Cheers,
~ Jeff
Hide Signatures
       Post #: 38
RE: Trex 450 CLONE WARS - 4/1/2009 7:06 AM
jrizzle
Score: 100
Status: offline
Just wondering if anyone has verified that the HK 450 is 100% compatible with the Trex?
Hide Signatures
       Post #: 39
RE: Trex 450 CLONE WARS - 4/1/2009 1:12 PM
FLYGUY09
Score: 100
Status: offline
It is a 100% clone of the T-Rex 450 SA. I d/l the 450SA manual and all the parts are the same....I think maybe 1 or 2 parts are plastic vs aluminum, but that doesn't affect compatibility.
< Message edited by FLYGUY09 -- 4/1/2009 1:14 PM >
-Michael
Hide Signatures
(in reply to jrizzle)
       Post #: 40
RE: Trex 450 CLONE WARS - 4/2/2009 8:38 PM
dude7422
Score: 102
Status: offline
so what motor is everyone using in EXI450 HK450 AND others?? you know if the clones were more in kit form and no parts put together how cheap would they be then good idea if i say so myself
Hide Signatures
       Post #: 41
RE: Trex 450 CLONE WARS - 4/3/2009 11:10 PM
aythomps
Score: 100
Status: offline
I'm using the align 430L in the EXI450. Would a hitec 65hb servo be good for tail servo?
Hide Signatures
       Post #: 42
RE: Trex 450 CLONE WARS - 4/3/2009 11:44 PM
baurwin
Score: 121
Status: offline
scorpion -8 here, in a cx450 v2
blade 400/ trex 250se/ trex450sev2/ trex 500 esp/ savage 25
Hide Signatures
       Post #: 43
RE: Trex 450 CLONE WARS - 4/5/2009 11:53 PM
aythomps
Score: 100
Status: offline
Hey guys, I want to thank you all the great advice on the hs-65 servos. I just did a test to see if I had the gyro setup correct. Man, it held the tail with no problem. I only thing now it to get my pitch setup. At half stick I got 0 pitch, but at 100% stich i'm only getting +9 pitch and -11 at 0% stick. I think if, I increase my travel range to see if that will help. Any ideal that help me??
Hide Signatures
(in reply to baurwin)
       Post #: 44
RE: Trex 450 CLONE WARS - 4/7/2009 9:44 AM
pck
Score: 100
Last Login: 8/21/2009
Status: offline
I was about to order the HK450 from HobbyCity when i stumble upon this one instead! It's a 450SE V2 clone which basically comes with 4mm feather shaft and a CF body! I couldn't resist it and ordered one instead!
http://aerialhobby.com/index.php?main_page=product_info&cPath=1&products_id=39
Hide Signatures
       Post #: 45
RE: Trex 450 CLONE WARS - 4/7/2009 7:58 PM
jrizzle
Score: 100
Status: offline
I have seen this one as well. Let us know how you like it.
Hide Signatures
(in reply to pck)
       Post #: 46
RE: Trex 450 CLONE WARS - 4/7/2009 9:53 PM
Ramessinger
Score: 100
Last Login: 8/18/2009
Status: offline
I'm looking forward to also seeing how the V2 copy is when delivered! Did you order the servo's and gyro from Singapore also ?
Hide Signatures
       Post #: 47
RE: Trex 450 CLONE WARS - 4/8/2009 3:12 AM
pck
Score: 100
Status: offline
I received a call from aerialhobby and they asked if i like to collect the heli directly from their warehouse instead and i will save on the shipping fee. Since i am only a short drive away, i will probably pick it up from their warehouse later on.
I will post some pics of the V2 clone once i get it and post them here. I am planning to use the following for my setup:
HS65MG for cyclics
Scorpion 2221-10 w/ 15T for power
Reuse my FutabaGY401B gyro from my mini titan heli
MKS9660 servo which i got from hobbycity for tail
One of the main reason why i choose to buy this heli over the HK450 at HC is that this is using a 4mm feather shaft instead of the 3mm one (i called them to confirm before i ordered). At this point of time, the overall cost of this is cheaper than getting the HK450. I am hoping that i will not be disappointed with the quality. (fingers crossed)
Hide Signatures
(in reply to Ramessinger)
       Post #: 48
RE: Trex 450 CLONE WARS - 4/8/2009 8:30 AM
pck
Score: 100
Status: offline
Ok, I just picked up the clone SEV2 from Aerialhobby 1 hour ago. I attached some pictures I took below. Few things i noted:
1) There was no manual attached. Although i was assured that the TRex SEV2 manual can be used.
2) Ok, the box was nowhere near that of Align. But at least, it looks better than the while box of HK450...
3) The entire head has already been pre-assembled. But i think i am going to strip everything apart to check for loctiite. For this price, i am skeptical if loctite had been used in the assembly.
4) The tail is also pre-assembled. You just need to insert the belt down the boom.
5) Black CF body, tail and stabiliser fin.
6) Fibreglass canopy (as shown in one of the attached pics below)
7) A pair of fibreglass 325mm blades are bundled in.
8) No decals...
Overall, a very nice looking clone. Head and tail assembly is full metal so no upgrades are necessary. First glance of the heli, it does indeed looks like the TRex SEV2. In fact, I am pretty sure it's a 100% replica...
Now the only question is if it will fly as well....
Can't wait to set it up and do a test flight on it!
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to pck)
       Post #: 49
RE: Trex 450 CLONE WARS - 4/8/2009 8:32 AM
pck
Score: 100
Status: offline
opps.... sorry for posting the pic of the box twice!
Hide Signatures
(in reply to pck)
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.267RCU1
