Too much vacuum crushes white foam - need regulator or other technique
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Composites Fabrication And Repair >> Too much vacuum crushes white foam - need regulator or other technique
Page: [1]
Login
Too much vacuum crushes white foam - need regulator or ... - 6/13/2003 5:55:46 AM
DMcQuinn
Status: offline
This is what happens when there is too much vacuum. The foam collapsed into the hole that I had drilled for the servo wires. This is a 35% Cap wing made of 1Lb white foam covered with 1/16 balsa. I had prepared the wing core by drilling out a hole for the phenolic tube and another hole for the servo sires to run through. I installed the phenolic before the balsa skin and I put plywood support at the end of the phenolic.
There are two problems with this I think. First, you should not cut the servo wire hole until the skins are attached. Secondly, I think I have way too much vacuum, because the entire wing is compressed even in areas away from the access hole.
The phenolic tube seems to have survived the vacuum process, so I guess it is OK to install it first (you really need to in order to get the end support installed.
I am using a vacuum pump acquired for free that has no gauge or regulator. I have successly covered smaller sample pieces without problem, but obviously for this large wing I need less vacuum.
Is there any simple technique to reduce pressure (like putting a pin-hole in the vacuum line)? CST has a gauge/regulator for $63.
In the picture, the blue stripes are masking tape strips I use to hold the balsa together. You can see the indentation and wrinkles of the over-compressed wing. The thickness of the wing at its thickest point is about 1/2 inch less than it is supposed to be.
Click to see fullsize image.
Click for fullsize
       Post #: 1
Too much vacuum crushes white foam - need regulator or ... - 6/13/2003 6:15:52 AM
A5fly
Status: offline
I can sympathize. One of the first white foam parts I made, I not only used too much vacuum, I used too much temp in the oven. Imagine what cottage cheese would look like if you covered it in carbon and you have the idea...
You can make a low cost vacuum reducer with a simple 2-way air hose valve. You can do it one of two ways: First, put it in-line with the hose that goes from the vacuum to the bag. Closing the valve reduces pressure. The other way that I prefer) is to use it as a bleed system. Put a "T" fitting after the pump. One line will go to the bag, the other line will go to the 2-way valve. Opening the valve will reduce the vacuum pressure.
Hope that helps.
(in reply to DMcQuinn)
       Post #: 2
Too much vacuum crushes white foam - need regulator or ... - 6/13/2003 9:28:55 AM
probligo
Status: offline
I have seen two (#8 wire) versions of this...
First - used a vaccuum advance mechanism off an old carby to operate a microswitch, which turned the pump on and off. He had a small scale pre-calibrated using a guage (borrowed) to create a scale for adjusting the vacc level.
Second used a small bowl (metal) with input and output tubes as an oil trap. The top of the oil trap was a neoprene sheet (thickness unknown but I imagine fairly substantial). The arm to a microswitch was set in the middle of the neoprene to "measure" the vacc level and operate the pump. Total movement of the neoprene was about 5mm when operating.
       Post #: 3
Too much vacuum crushes white foam - need regulator or ... - 6/13/2003 10:12:25 PM
Mluvara
Status: offline
Usually, you don't want more than 6" of Hg on white foam.
I built a vacuum bagger that has a reservoir and a switch that is selectable for its amount of pull between 0 and the max pump rating. Attached here is the switch that I use and have found at local surplus stores for $5-10. It's part # is E1S-H-VAC and is made by Barksdale, witha 0 to 30" Hg range. The switch is simply connected to the reservoir, and inserted in the circuit to the pump so it turns the pump on and off as needed.
Info:
http://www.barksdale.com/products/pressure/e1s_e1sh_vac.html
http://www2.barksdale.com/draw/3395.pdf
http://www.barksdale.com/products/pressure/PDF_Press/E1S_pg12.pdf
You'll need either a one way valve or a solenoid that activates so that from the reservoir to the vacuum bag is sealed. Otherwise, it will leak out the pump.
Michael
Click for fullsize
_____________________________
Michael Luvara
RCATS - http://www.rcatsystems.com
Luvara Air Racing - http://www.LuvaraAirRacing.com
       Post #: 4
Too much vacuum crushes white foam - need regulator or ... - 6/14/2003 9:38:41 AM
A5fly
Status: offline
If your pump is a type that can run continuously (such as the diaphragm types), you won't need a reservior or a regulator. Just the simple bleed will do nicely, and it is the lowest cost option.
       Post #: 5
Too much vacuum crushes white foam - need regulator or ... - 6/15/2003 6:22:38 AM
canadianjosh
Status: offline
I ran into this problem when i first built my vaccum bagger. I have a simple solution. Put a brass T fitting inline in the tube that goes from the vaccum to the bag, on the open end of this put on some more tubing, then install a fine thread screw gate type valve, this will alow you to bleed different amounts and even to turn off the bleed. works great for me.
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.654RCU3
