RE: Byron Ryan ST-A    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> RE: Byron Ryan ST-A
Page: <<   < prev  1 [2] 3 4 5   next >   >>
Login
RE: Byron Ryan ST-A - 8/2/2010 2:30 AM
packet
Score: 100
Last Login: 12/3/2010
Status: offline
Gentlemen, I want to share with you what I did on a Piper Super Cub for wing struts. I also used the airfoil shaped aluminum but instead of inserting threaded rod, I filled them with epoxy. It does make them more heavy than you may want, but it probably wont make that much difference on a big bird, and as observed in a later crash, they held up very well.
_____________________________
An aircraft is a series of compromises flying in formation.
Hide Signatures
(in reply to foodstick)
       Post #: 26
RE: Byron Ryan ST-A - 8/5/2010 11:10 PM
roaddog2
Score: 120
Last Login: 6/10/2012
Status: offline
And I'm such a lucky guy, I've got a set o' 1/4 scale plans one o' th' members here donated a while back. 'Nice to hear a good "review" on th' airframe.
An STA is MOS' definitely in my future!
:O)
RD
Th'' Roaddog
Montross, Va
Hide Signatures
(in reply to packet)
       Post #: 27
RE: Byron Ryan ST-A - 8/17/2010 5:32 AM
Stickbuilder
Score: 346
Last Login: 6/17/2013
Status: online
My kit has the struts made from aluminum. It's odd, because my kit was packed over 20 years ago. It is complete, with all parts still in the original bags. This kit was actually unopened until I got it a few days ago. I've got a long row to hoe with this one. Anyone have a clue where to find one of the original universal engine mounts? I suppose that I can just build an engine box and fab it to the firewall/s. I'm thinking about letting Keoleo (sp?) do a scale exhaust for it. Anyone need any information from this one before I start to screw it together? I'll be happy to provide photos, measurements etc. For anyone who needs it.
Bill, Waco Brother #1
Its easy, just glue all the pieces together, and sand off everything that doesnt look like an airplane.
Hide Signatures
(in reply to roaddog2)
       Post #: 28
RE: Byron Ryan ST-A - 9/9/2010 6:58 AM
Stickbuilder
Score: 346
Status: online
Started screwing it together last evening. I have the aft bulkhead, the front cockpit rear bulkhead and the servo tray glassed in. I cut a new firewall from 3/8" A/C ply. The thin stuff seems a tad light to carry either a ST or Quadra engine. I'm going to run a 50cc engine in mine, thus the heavier firewall. Any thoughts on this?
Hide Signatures
(in reply to Stickbuilder)
       Post #: 29
RE: Byron Ryan ST-A - 9/9/2010 2:39 PM
Mud Duck
Score: 100
Last Login: 9/21/2012
Status: offline
Sounds great Stickbuilder! Have a great time and if possible post a photo or two along the way.
Fly until the last piece stops!
AMA 5642, IMAA, Waco Brotherhood #117
Hide Signatures
       Post #: 30
RE: Byron Ryan ST-A - 9/11/2010 4:23 PM
Stickbuilder
Score: 346
Status: online
I'll be doing some photos. Last evening, I got the landing gear trunions glassed in, and aligned. This is a fairly simple model, so far, but you have to keep the alignments correct, or its all off.
Hide Signatures
(in reply to Mud Duck)
       Post #: 31
RE: Byron Ryan ST-A - 9/14/2010 7:01 PM
JeffH
Score: 114
Last Login: 6/18/2013
Status: offline
quote:
ORIGINAL: Stickbuilder
I might have a byron's mount in my engine box. If I do, it will be drilled for either a G-38 or Q-35-42 engine though. I will look this week.
Hide Signatures
       Post #: 32
RE: Byron Ryan ST-A - 9/14/2010 7:28 PM
Stickbuilder
Score: 346
Status: online
That would be nice. Thanks,
Hide Signatures
(in reply to JeffH)
       Post #: 33
RE: Byron Ryan ST-A - 9/16/2010 10:08 PM
dragoonpvw
Score: 100
Last Login: 6/9/2013
Status: offline
Bill,
I hope you build the ryan. I love the plane and byrons is a solid kit. I am not sure which mount came with the Ryan since it is a long time since i opened one up. I think though, that Steve Thomas over at Bobs Hobbies had a bunch of Byron stuff. He bought a big box of mounts and mufflers a year or too back and I think he still has a lot. The best Ryan i saw I think had a g-38 on it but I thought the owner mounted it to the firewall. I have a couple of bent purrpower units but they are for the big and small sachs, so won't work for you. Good luck anyway.
By the way which engine are you planning on?
good luck
Paul
In this world, Elwood, you must be oh so smart or oh so pleasant
Well, for years I was smart. I recommend pleasant
Hide Signatures
       Post #: 34
RE: Byron Ryan ST-A - 9/17/2010 7:04 AM
Stickbuilder
Score: 346
Status: online
I'm planning to run the new SYSSA 30 gas engine. It's narrow, has a rear exhaust, and won't require cutting the cowl. I've got all the fuse glassed, and tonight, I mounted the main gear. It's moving really quickly, and is going to look very nice as well. I'm doing it like Maxey Hester did on the little one for SIG. Red, white and black, with checkerboard wing and stab bottoms. Sucker is actually fairly big too.
Mt. Dora? Why don't you get in touch? I'm sending you a pm with my phone number. Call me tomorrow.
Hide Signatures
(in reply to dragoonpvw)
       Post #: 35
RE: Byron Ryan ST-A - 9/18/2010 5:23 AM
Stickbuilder
Score: 346
Status: online
It's standing on all 3 feet now, and I'm dry fitting the cowl. I cut a new firewall from 3/8" Aircraft Ply, since there is no way that I'm going to hang an engine off a piece of 1/8" ply. I'll start on the tail group next. I'm thinking about laminating the perimeter of the tail group and the leading edge of the wings and wing tips, just to keep dings away. I'm going to glass the foam parts with something on the order of 1.5oz cloth and use enviro tech for the finishing resin. Still have the wheel pant assemblies to go first.
Hide Signatures
       Post #: 36
RE: Byron Ryan ST-A - 9/20/2010 11:30 PM
Stickbuilder
Score: 346
Status: online
Here are a few photos of the build. Please excuse the mess in the shop.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 37
RE: Byron Ryan ST-A - 9/27/2010 6:05 PM
Stickbuilder
Score: 346
Status: online
Work continues.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 38
RE: Byron Ryan ST-A - 9/27/2010 6:27 PM
Vintauri
Score: 105
Last Login: 6/14/2013
Status: offline
Looking good Bill. It looks like you swapped out the stock struts for some robarts perhaps? If so which ones did you use? I'm looking to build my kit this next year and I've been gathering notes from people that have them in progress.
Steve
www.vintauri.com
Hide Signatures
       Post #: 39
RE: Byron Ryan ST-A - 9/27/2010 6:41 PM
Stickbuilder
Score: 346
Status: online
The Struts are the ones that Byron included in the kit. Everything is stock and original.
Hide Signatures
(in reply to Vintauri)
       Post #: 40
RE: Byron Ryan ST-A - 9/27/2010 7:50 PM
JeffH
Score: 114
Status: offline
did you still need the byrons mount? I have one, but like I said it has been drilled.
Hide Signatures
       Post #: 41
RE: Byron Ryan ST-A - 9/27/2010 8:58 PM
Stickbuilder
Score: 346
Status: online
quote:
ORIGINAL: JeffH
How much for it, shipped to 34748?
Hide Signatures
(in reply to JeffH)
       Post #: 42
RE: Byron Ryan ST-A - 9/27/2010 9:01 PM
JeffH
Score: 114
Status: offline
10 bucks. That should cover the shipping. Do you need me to send a picture first?
Hide Signatures
       Post #: 43
RE: Byron Ryan ST-A - 9/27/2010 10:18 PM
Stickbuilder
Score: 346
Status: online
Naah, I know what they look like, and if needed, I can cut a plate to bolt to the existing holes in the mount. I'll send you a pm tonight with my phone number, and we can get together with the addresses.
Hide Signatures
(in reply to JeffH)
       Post #: 44
RE: Byron Ryan ST-A - 9/28/2010 2:03 AM
Dick T.
Score: 136
Status: offline
If you are interested in dressing up the STA with period graphics let me know.
I have a Byron Ryan NIB so am following your build.
Click for fullsize
Click for fullsize
Click for fullsize
Dick Tristao
ModelGrafix
Hide Signatures
       Post #: 45
RE: Byron Ryan ST-A - 9/28/2010 2:39 AM
Stickbuilder
Score: 346
Status: online
Dick,
PM me with your phone number. There are several things that I have found in building this one so far that do not work as the manual suggests. Nothing major, but sometimes it helps to talk one another through the process. I'm interested in the Graphics that you show.
Hide Signatures
(in reply to Dick T.)
       Post #: 46
RE: Byron Ryan ST-A - 9/29/2010 4:35 AM
BillyJ
Score: 100
Last Login: 3/3/2012
Status: offline
looking good !!! just finished My Ryan, will let you know how it flys this week ... Dupont paint and DLE 30 cc
Hide Signatures
       Post #: 47
RE: Byron Ryan ST-A - 9/29/2010 4:39 AM
BillyJ
Score: 100
Status: offline
Byron STA
Click for fullsize
Hide Signatures
(in reply to BillyJ)
       Post #: 48
RE: Byron Ryan ST-A - 9/29/2010 1:17 PM
Stickbuilder
Score: 346
Status: online
Did you cover it with glass cloth and finishing resin?
Hide Signatures
       Post #: 49
RE: Byron Ryan ST-A - 9/29/2010 6:07 PM
Stickbuilder
Score: 346
Status: online
Fitted the Horizontal Stab and Vertical Stab last night. I'll start Glassing the stabs tonight. I'm using 0.5 oz/yd2 cloth and Envirotec resin. Looks like it is going to be a really nice way to do the foam.
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.875RCU1
