RE: Byron Ryan ST-A    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> RE: Byron Ryan ST-A
Page: <<   < prev  1 2 3 [4] 5   next >   >>
Login
RE: Byron Ryan ST-A - 8/12/2012 1:39 PM
hooker53
Score: 100
Last Login: 5/19/2013
Status: online
TK. Nothing like a good story to go along with a great model. I've wanted to built one of these for years but can not ever find one at a reasonable price like yours when I'm ready to build. I've seen these listed at prices that I could imagine anyone giving for some of these Byron kits. Good luck with yours and do post some photos and Mabey even a vid of the maiden.
_____________________________
Scratch it till it bleeds Convert it till it chokes
Hide Signatures
(in reply to TKFOKKER)
       Post #: 76
RE: Byron Ryan ST-A - 8/16/2012 5:21 PM
VNulk
Score: 100
Status: offline
Hey Tom,
How's the Ryan coming? Got any pictures for us yet? I'll forward to seeing it at Rhinebeck if you get it there.
Vern
Hide Signatures
       Post #: 77
RE: Byron Ryan ST-A - 9/3/2012 3:26 PM
lovehydro
Score: 100
Last Login: 5/16/2013
Status: offline
Dick T.
I know your offer is a couple of years old, however I am building Byron STA this winter and would love to ket a set of decals you showed on this thread. Please contact me at gnh9@comcast.net, Thanks. lovehydro
Hide Signatures
(in reply to Dick T.)
       Post #: 78
RE: Byron Ryan ST-A - 9/22/2012 2:56 PM
TKFOKKER
Score: 130
Last Login: 5/18/2013
Status: offline
Here are some photo's of my Ryan YPT-16 I took it to Rhinebeck and test flew it there. She went well,not over powered with a Quadra 35 believe me. Climb out over the aerodrome trees was nerve racking. Second flight went better after tweeking the needles a bit. Plane is very responsive on the controls, also a clean fast flier, no drag as I am used to with my WW-1 models. Comes in quick, but settles on the mains nice and a straight roll out each time. I have not used the flaps yet, next time. All and all it's a classy looking plane, that needs caution on take offs, but when in the air is a good flier. Came out at 21 lbs.
Also the model took first place at the Jamboree which was cool. I do have another kit in box which I will consider selling.
TK
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to lovehydro)
       Post #: 79
RE: Byron Ryan ST-A - 9/29/2012 3:33 AM
plmcdonnell
Score: 100
Last Login: 5/7/2013
Status: offline
Your Ryan looks very good TKFOKKER. I'm also building the Byron Ryan, but can't decide which scheme to go with. I've always liked the John Gosney scheme that Sig used, but it seems like Ryans were meant to be polished aluminum. What paint did you use for the aluminum on yours?
Hide Signatures
       Post #: 80
RE: Byron Ryan ST-A - 10/5/2012 1:43 PM
TKFOKKER
Score: 130
Status: offline
I used Rustoleum Chrome rubbed down after two weeks of drying time. This paint is very soft and takes time to dry because of the heavy metalic in it. Paint is not fuel proof so you need to always be careful. But it's the only way to get a finish like that unless you go with real aluminum tape. That is the reason for the venturey exstension tube. It keeps the fuel in the carb and not on the plane, plus better power. If I do another one I will go with the Red and cream color scheme, civilian. Too hard to produce a perfect all metal look.
TK
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to plmcdonnell)
       Post #: 81
RE: Byron Ryan ST-A - 10/5/2012 11:00 PM
hooker53
Score: 100
Status: online
TK. Please tell us a little more about your rub down process. They look real good. As close as you are getting I would do that before Alum tape in most cases. Thanks for posting.
Hide Signatures
       Post #: 82
RE: Byron Ryan ST-A - 10/7/2012 12:30 PM
Stickbuilder
Score: 346
Status: offline
Still have not completely given up on the idea of using the foam wings. What does everyone think about wrapping the leading edge with 1/64th ply and then filling and glassing? Maybe back to the spars?
Bill, Waco Brother #1
Its easy, just glue all the pieces together, and sand off everything that doesnt look like an airplane.
Hide Signatures
(in reply to hooker53)
       Post #: 83
RE: Byron Ryan ST-A - 10/7/2012 9:41 PM
Stickbuilder
Score: 346
Status: offline
I dug out a 4 foot by 12 inch piece of 1/64th ply and cut it to the appropriate size to be able to wrap around the leading edge from spar to spar. Left it to soak while we went to Church. When we got home, I wrapped it around the leading edge from spar to spar and held it in place with a couple of big ol' Ace bandages to dry. When it was dry, I took it off the wing, and am in the process of trimming it to fit precisely and to cut the holes for the plugs for the flying wires. I think this may work very well and will make the leading edge ding proof. I'll fill the junction with lightweight spackle and it should slick up nicely for the glass cloth. I'm laminating the wingtips using 1/16th spruce. Might even introduce some dummy ribs to get the correct effect.
Hide Signatures
(in reply to Stickbuilder)
       Post #: 84
RE: Byron Ryan ST-A - 10/14/2012 2:56 PM
Stickbuilder
Score: 346
Status: offline
Got the leading edges sheeted and the tips laminated. What a chore just to do what Byron should have done in the beginning. I guess it will be okay, but I still think that I'd be better off framing up a new set. We'll see.
Hide Signatures
       Post #: 85
RE: Byron Ryan ST-A - 10/24/2012 12:40 PM
Stickbuilder
Score: 346
Status: offline
Now I have the wings about ready to finish. Just glued on the sub-rib this morning and when dry, I will finish sanding the wing and get it ready to fiberglass. I'll try and get some pictures to post of the job. I think it will be okay. It is stronger and more ding resistant than the pure foam wing was. I'm still going to frame up a set of wings and compare the look. I have a feeling that the framed up wings will win out.
Hide Signatures
       Post #: 86
RE: Byron Ryan ST-A - 10/27/2012 2:10 PM
mikmerl
Score: 100
Last Login: 3/13/2013
Status: offline
Stickbuilder I have a Byron Pitts special (foam wonder) that I started to do with the foam wings exactly what you have done.
About 2/3’s of the way through I decided to toss them aside and build balsa and spruce wings. I couldn’t be happier with the result; they are lighter and stronger than the originals.
I also have a NIB Byron Ryan that will get the same treatment when I get around to building it.
mke
Nothing is foolproof because fools are so ingenious.
Hide Signatures
       Post #: 87
RE: Byron Ryan ST-A - 11/4/2012 9:32 AM
Stickbuilder
Score: 346
Status: offline
quote:
ORIGINAL: mikmerl
mke
Yep, the foam wings are crap. I drew up a set of plans for the wings and here is one ready to sheet.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to mikmerl)
       Post #: 88
RE: Byron Ryan ST-A - 11/4/2012 11:06 PM
Stickbuilder
Score: 346
Status: offline
Got the top sheeted and the cap strips in.
Hide Signatures
       Post #: 89
RE: Byron Ryan ST-A - 11/27/2012 12:44 PM
Stickbuilder
Score: 346
Status: offline
Here it is all ready to sand the fuse and cover the wings and start painting and detailing. I do wish this forum had a little life in it.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 90
RE: Byron Ryan ST-A - 11/27/2012 12:54 PM
TomCrump
Score: 116
Status: offline
Nice job on the wings, Bill.
Tom C
Hide Signatures
       Post #: 91
RE: Byron Ryan ST-A - 11/27/2012 1:47 PM
Vintauri
Score: 105
Last Login: 5/17/2013
Status: offline
Very nice job on the wings. I have not started my kit yet and I might have to consider doing the same. Keep us updated on how it goes.
Steve
www.vintauri.com
Hide Signatures
(in reply to TomCrump)
       Post #: 92
RE: Byron Ryan ST-A - 11/27/2012 5:06 PM
Stickbuilder
Score: 346
Status: offline
Thanks all. The wings are ready to cover. Here are a few more shots that are larger. I'll be surprised if they don't fly better than the foam versions. I'll think they do at least. Anyone need a wing plan? I have it rolled up.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Vintauri)
       Post #: 93
RE: Byron Ryan ST-A - 11/27/2012 5:08 PM
Stickbuilder
Score: 346
Status: offline
and 2 more
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 94
RE: Byron Ryan ST-A - 11/27/2012 11:46 PM
hooker53
Score: 100
Status: online
I would love to build one of these before it's all over with. I have several Byron kits that's never been open that I would bypass to build this one. Been waiting for mine to go up for sell here. Wink. Ha. Ha. Your doing a great job with this one.
Hide Signatures
       Post #: 95
RE: Byron Ryan ST-A - 11/29/2012 2:58 PM
lovehydro
Score: 100
Status: offline
I would love to have a copy of your wing plans. Do you show the wing rib template that you used? I have a new in the box kit I am ready to start and I hate the foam wings.
Please e-mail me on how we can work out getting your plans.
gnh9@comcast.net
Thanks, Paul
Hide Signatures
       Post #: 96
RE: Byron Ryan ST-A - 12/1/2012 10:32 AM
Stickbuilder
Score: 346
Status: offline
Paul, yes there will be a template of the rib. I'll send you an email when I get a minute, and will be happy to send you the plan. It is only one panel, and you reverse it to build the other wing. Seems to be very strong. I used 1/8 X 3/4 aluminum from Lowe's for the wing joiner plate. Shown on the plan.
Hide Signatures
       Post #: 97
RE: Byron Ryan ST-A - 12/1/2012 3:52 PM
lovehydro
Score: 100
Status: offline
Bill,
Thank you so vary much, I look forward to your e-mail.
Paul
Hide Signatures
       Post #: 98
RE: Byron Ryan ST-A - 12/1/2012 6:19 PM
Vintauri
Score: 105
Status: offline
Bill If I could get a copy of the plans I could scan them in at work and make a PDF file for you to share. I'd love to have them for when I get around to building mine perhaps this winter!
Steve
www.vintauri.com
Hide Signatures
       Post #: 99
RE: Byron Ryan ST-A - 12/2/2012 12:26 AM
Stickbuilder
Score: 346
Status: offline
How bout I just send the plan to lovehydro, and when he finishes with them, he can send them to you, and you can do a PDF of them and then make them available to anyone you like?
Hide Signatures
       Post #: 100
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.139RCU1
