Zenoah G-45 Plug Gap?
Tower Hobbies
Logged in as Guest
  Printable Version
XYZ-50cc Gas Engine by Southeast R/C Engines, LLC.
Seller:  XYZUSA
Details:   $259.95   |  11/10/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> Zenoah G-45 Plug Gap?
Page: [1]
Login
Zenoah G-45 Plug Gap? - 3/24/2002 11:25:13 AM
winship
Status: offline
I purchased a new Zenoah G-45 engine and the plug that came with it had a gap of .042 What is the proper plug gap for the stock Champion plug that comes with the engine?
Also, does anyone use NGK plugs in their gas burners?
       Post #: 1
Plug gap - 3/24/2002 12:03:32 PM
rcign-RCU
Status: offline
Not critical..Anywhere .025-.045 If it runs well and doesn't miss it's good..(Don't believe it ? try it)
Champion RCJ7Y
NGK BPMR6A (except Zenoah G23, NGK BMR6A, or two washers under the plug)
Bosch WSR6F
Any plug will work if it's a resistor type..
The engines using NGK CM6 non resistor plugs come with shielded wires and caps...There is no 10mm resistor plug...
(in reply to winship)
       Post #: 2
Zenoah G-45 Plug Gap? - 3/24/2002 8:35:56 PM
winship
Status: offline
Thanks for the input. .042 seemed a little large so I narrowed it to .035 and it seems to run well. I just wanted to make sure I wasn't out of the ball park.
The info on the shielded plug wires and resistor plugs also cleared up another question.
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.268RCU3
