??? About Novak Brushless
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> ??? About Novak Brushless
Page: [1]
Login
??? About Novak Brushless - 6/13/2003 10:46:06 PM
fishtale17
Status: offline
Just installed my novak brushless in my losi xxx-t. My question is when I go to reverse there is about a 2 second delay before the car goes into reverse, I am using setting number 1. Any one using this motor is this common or do I have something screwed up. Thanks
       Post #: 1
??? About Novak Brushless - 6/14/2003 12:11:06 AM
SixVi6-Camaro
Status: offline
that is how its supposed to be. if it went directly into reverse right away, especially if you were still moving forward, it could damage your driveline. your novak SS is fine.
(in reply to fishtale17)
       Post #: 2
??? About Novak Brushless - 6/14/2003 12:57:34 AM
fishtale17
Status: offline
thanks, When I first hit the brakes it slows to a stop, then I release and go to reverse is where there is a slight delay.. thanks again.
       Post #: 3
??? About Novak Brushless - 6/16/2003 4:08:09 AM
teamprodigy
Status: offline
hey im curious about how fast does the brushless actually make your car go? in MPH
       Post #: 4
??? About Novak Brushless - 6/16/2003 9:03:34 PM
fishtale17
Status: offline
Not sure, but I will try to get my neighbor to shoot it with his radar within the next couple of days.. Of course it is much faster than my 19t I replaced it with. and as everyone has stated it has [SIZE=4]TONS OF TORQUE[/SIZE].
       Post #: 5
??? About Novak Brushless - 6/16/2003 9:06:42 PM
whitexj
Status: offline
Is it worth buying the system or staying withed brushed motors? I was thinking about it for a xxx and possibly a xxxt. I have not heard anything bad so far. Any complaints?
_____________________________
XXXNT-rb x.12
XXXkinwald-13x2
       Post #: 6
??? About Novak Brushless - 6/16/2003 9:32:14 PM
usagi
Status: offline
[QUOTE]Originally posted by whitexj
Is it worth buying the system or staying withed brushed motors? I was thinking about it for a xxx and possibly a xxxt. I have not heard anything bad so far. Any complaints? [/QUOTE]
I think it worth it. Think about it less money on brushes. Run times are increased and down time is less. WOW more play time!
       Post #: 7
??? About Novak Brushless - 6/17/2003 6:18:42 PM
Isphius
Status: offline
Do brushless motors get as hot as brushed motors do? i want to put one i my pan car and go 90mph. does Anybody know a really stable body for speed runs? i want front and rear down force for handling too, but not too much. Nascars have this stuff and i can get a bolink nascar monte carlo body at my lhs. Anyone think its good?
Check this out
http://www.geocities.com/killerbeeze/home.html
       Post #: 8
??? About Novak Brushless - 6/18/2003 8:06:28 PM
A4DTM
Status: offline
you will NOT hit 90mph with the novak
just so you know, novak is fairly WEAK compared to most other brushless'
       Post #: 9
??? About Novak Brushless - 6/18/2003 8:22:34 PM
jtrnp2001
Status: offline
I saw an article in RCCA about an 111 mph car. It used an Aveox brushless.
- Travis
       Post #: 10
??? About Novak Brushless - 6/18/2003 9:50:19 PM
SixVi6-Camaro
Status: offline
yeah ther is not way you will 90 with a Novak BL. Its a great easy and reliable BL setup for 6-7 cells but its not made for extreme speed and tons of cells. if you want to go 90 mph I'd not start with a Novak.
       Post #: 11
??? About Novak Brushless - 6/19/2003 12:10:51 AM
Isphius
Status: offline
i was exagerating anyway. If it went 90mph i would have no where to drive it. i want about 65-70. The car now gets up to ~55 with 12 cells and a 12 turn motor. The aevox brushless powered pan car in that article was a 2 turn running on 24 cells. The other 96mph touring car had a one-off 6 turn brushed motor made by mike reedy himself and 18 cells. I could use either one of those motor setups in my car...
Check this out
       Post #: 12
??? About Novak Brushless - 7/29/2003 11:15:04 PM
skate5290
Status: offline
your going 55 why do you want go faster?
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
