Countryboy
KY, USA Status: offline
[QUOTE]Originally posted by P-51B The MVVS 1.6 sounds interesting, hope someone can comment! By the way, does this plane seem somewhat overpriced, or is it just me? H9 sells the 65.5 inch span version for $255. It seems that the 77 inch version is the same construction and detail, so the only difference in cost should be due to the size. 77/65.5 gives a factor of 1.18. Now, given the fact that sheeting is not linear, but rather an area, the factor is probably slightly higher...somewhere around 1.35ish. That would put the price around $344, pretty far from $500! I realize that the math is somewhat fuzzy, but $500 compared to $255? [/QUOTE] I quess it depends on how much your LHS want's to gouge you on price. Got mine for the out the door price of $413 Same holds true for other items such as retract air line tubing ... $6.00 for ten feet if purchased at a LHS. I have found a source where it can be purchased in fifty foot rolls for under ten bucks. Same holds true for Tygon tubing... fifty feet for $27.00 compared to $4.70 for three feet at the LHS These people are as bad as my local Snap-On rep.
