SpudRacer
Joined: 11/15/2004 From: Bryson City, NC, NC, USA Status: offline
OK, I need some help. I just finished installing the flap servos and testing them with my JR PCM10X radio. I have one side all set up, but when I try to adjust the linkage for the other side, I'm finding that the servo is working backwards. I've ordered a couple y-cables from Tower Hobby to run both flaps on a single channel, and the ailerons on a single channel, but is this going to fix the problem or do I have to wire up my own y-cable so both servos work in the same direction? Advise from the pros here is appreciated. I'll be starting the landing gear soon, and I hope you're all happy to know that my wife did get me a Hobbico Nexstar trainer, and I'm so glad I listened to you guys. It comes with a computer program and I found I really stink at landings. I can fly a real plane easier than trying to do it from a spot on the ground. I can take off fine, and if I pilot carefully, I have no problem flying either, but landing with the plane flying towards me is so difficult to learn. Any pointers? Thanks again guys, and my P-51 thanks you too! Tom
